Yammm: Metadata, Artwork, Rename, Playlist, Service... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 05-19-2009, 09:56 AM - Thread Starter
mikinho's Avatar
Yet Another Media Meta Manager (Yammm)
Home Page (Will be moving soon)
YammmSetup.msi
Not that we need another meta manager but none of the ones available that I've tried (quite a few) really suited my needs so I developed Yet Another Media Meta Manager (Yammm). It isn't for everyone as it has no GUI (though a MCML will be coming for choosing artwork) but for me it as worked well and I would like to add features so please leave feedback and\\or feature requests.
Yammm runs as a Windows Service and will download meta data, artwork, rename folders and\\or create playlists. Metadata can be any combination of dvdid.xml, mymovies.xml and\\or XBMC nfo file. All meta information and artwork is provided via either themoviedb.org or thetvdb.com. If you haven't checked them out please do so and contribute where possible.
I created Yammm because I haven't used any meta manager that runs "headless" without ANY user interaction and used folder.jpg instead of custom artwork locations. This is important to me as I use various htpc software depending on the situation and development. I also found that most did not match well. Yammm uses various checks other than the provider's score value.
Folder Structure
Yammm currently only looks as movie folders (TV support is currently being tested). This means as a folder is checked the name will be used for matching. A folder name is broken into three parts. The title, year and "tags". i.e. For "Cidade de Deus (2002) [City of God] [Director's Cut]" the year is 2002, the tags are City of God and Director's Cut and the title is "Cidade de Deus". Yammm will ignore any tags when searching for a matching movie but will preserve them when renaming the folder.
Movie Rename
Yammm will optionally rename matching movie folders to "Title (Year) [Tags]". If the movie is a foreign film Yammm will also attempt to append the local title as a tag. i.e. "City of God" will be renamed to "Cidade de Deus (2002) [City of God]".
File Rename
Yammm determines the "primary" movie in a folder by grouping similar named files togethor. The largest combined size is considered the primary movie. This is to prevent trailers and samples files from being touch.
If it a single file then it renames it to "Title (Year)". If there are multiple files then they are renamed to "Title (Year) [# of ##]". All associated files are also renamed.
To give an example:
Seven Swords (2005) [1 of 2].avi
Seven Swords (2005) [1 of 2].idx
Seven Swords (2005) [1 of 2].sub
Seven Swords (2005) [2 of 2].avi
Seven Swords (2005) [2 of 2].idx
Seven Swords (2005) [2 of 2].sub
Seven Swords (2005).dvdid.xml
Seven Swords (2005).wvx
The files were renamed and the playlist created for it. Thoughts?
Playlist Create
Yammm will optionally create playlists for movies spanning over several files. It can also optionally hide the actual files so only the playlist is shown and not the individual files.
Media Center DVD ID Metadata
If enabled Yammm can create dvdid.xml files for matching movies. When possible it will use the real ID (CRC64) otherwise it will create one. When enabled you must specifiy which accounts to create the corresponding cache files. This allows you to keep your HTPC and media center extenders Movie Library metadata in sync. If present Windows 7 (RC1) Movie Library will display the metadata as well.
In the works....
The below items are currently being tested
- Renaming files
- TV Series support
- Custom folder\\file renames
- Media Center plugin (MCML) for selecting artwork
- Better DVR-MS support, it will check DVR-MS for meta data prior to checking provider
- Optional embed metadata into artwork and\\or dvr-mr
- Option to add a layer on the top of artwork before saving
Note:
- Required .NET Fx 3.5 SP1
- Uses the same APIs as Windows Media Center to determine whether a file is a video file or not
- Rename and image overwrite is disabled by default.
- Requires admin rights to the movie folders and admin rights to run Yammm Config.
- Currently only detects movies (TV series is in testing
- Currently only supports a single rename format: "Title (Year) [Tags]
- Run the Yammm Config application to Add\\Remove Watched Folders
- Meta XML files will not be overwritten, I will update soon with an option to update missing information for existing meta files (i.e. dvdid.xml, mymovies.xml, ...
- I purposely did not include a way to manually edit the meta data. Please help the community and contribute to The Movie DB.
If you currently have all your movies in a single file you can use the below command to create a subfolder for each movie and move the file into it.
Code:
FOR %i IN (*.*) DO (IF NOT EXIST "%~ni" MD "%~ni") & (MOVE "%i" "%~ni")
mikinho is offline
post #2 of 4 Old 05-20-2009, 10:09 PM - Thread Starter
mikinho's Avatar
Updated to include file renames, improved threading (ReaderWriterLockSlim)
mikinho is offline
post #3 of 4 Old 05-21-2009, 06:14 AM
benjamin.r's Avatar
Good stuff! Is it compatible with Media Browser?
benjamin.r is offline
post #4 of 4 Old 05-21-2009, 07:32 AM - Thread Starter
mikinho's Avatar
Yes it is. When using Media Center I go back and fourth from Media Browser and the native MC7 Movie Library. I've found that it does a better job of matching movies and helps speed up the library load times.
I forgot to mention, for Media Browser support enable mymovies.xml metadata creation.
mikinho is offline
Reply Home Theater Computers
