Help please with BDC-202 and Vista Driver problem - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 05-26-2009, 09:54 AM - Thread Starter
morgangd's Avatar
I have a BDC-202 player attached to an ACER PC (M3641). It was working.
Now the device has disappeared from 'my computer'.
When I look at the Device Manager it tells me the driver is corrupt (Code 39).
When I try to update the driver it says the driver is up to date.
If I uninstall and re-install the device I get the same error.
The Pioneer website tells me the drivers are generic MS drivers built into Vista. The Pioneer website only provides firmware updates.
Can anyone tell me where I can download a 'fresh' copy of the MS generic drivers? (Vista Home Premium - 32bit)
Thank you.
George.
morgangd is offline
post #2 of 7 Old 05-26-2009, 10:21 AM
rdunnill's Avatar
I had a problem with my BDC-202: iTunes had installed a filter driver that somehow got corrupted.
Uninstalling iTunes fixed the problem.
Blu-ray: 50+
HD-DVD: 23
DVD: 600+ and lost count
rdunnill is offline
post #3 of 7 Old 05-26-2009, 01:40 PM - Thread Starter
morgangd's Avatar
Thank you for the suggestion but unfortunately I don't have iTunes installed.
George
morgangd is offline
post #4 of 7 Old 05-26-2009, 06:55 PM
hammerdwn's Avatar
Quoted: 173 Post(s)
Liked: 57
Known vista bug. Registry hack fixed it for my brother's machine: http://www.randomfix.com/2007/04/12/...dvd-rom-drive/
Try google "vista optical drive fix"
XBR-65Z9D | AVR-X2200W | UBD-K8500 | JRMC HTPC w/9 cable tuners | Fluance SV 7.1 + eD A3-300
hammerdwn is offline
post #5 of 7 Old 05-27-2009, 02:01 PM - Thread Starter
morgangd's Avatar
Thank you for the suggestion.
I will need to get some expert help to go edit the Registry.
I will report back when it's done.
Much appreciated.
George.
morgangd is offline
post #6 of 7 Old 05-27-2009, 08:17 PM
rdunnill's Avatar
George
iTunes isn't the only source of filter driver problems.
Blu-ray: 50+
HD-DVD: 23
rdunnill is offline
post #7 of 7 Old 05-31-2009, 04:55 PM - Thread Starter
morgangd's Avatar
At last.
It worked!!!! Deleted the two 'filter' entries and now the drive is working again. Thank you to all the above.
BUT
Please, if you have a spare minute, can anyone give me a simple explanation of how deleting two lines in the registry can re-enable a DVD drive?
Just some hint as to the logic of what is going on? Nothing deep.
It really bugs me that I have NO IDEA of what is going on
George
morgangd is offline
Reply Home Theater Computers
