dvd formats - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 06-07-2009, 09:38 PM - Thread Starter
kingcain's Avatar
OK I am new to the htpc and still learning. here is my question what is a good format to put dvds in. If I just put them in reg dvd format from like dvdfab the files are 4.3gb and would need huge amounts of storage. I want to put them in another format that doesn't us all that space but want to keep chapters and subtitles. any help and/or suggestions?
Sorry if this is a duplicate post I looked and couldn't find the answer.
King
kingcain is offline
post #2 of 10 Old 06-07-2009, 09:49 PM
umdivx's Avatar
probably mkv is your best bet, haven't really played with chapters though.
Me personally I just leave them in folder format (ie video_ts) as its the easiest to store, and easiest to play back.
- Josh
umdivx is offline
post #3 of 10 Old 06-08-2009, 02:59 AM
jong1's Avatar
Quoted: 131 Post(s)
Liked: 105
Yeah, given the size/cost of hard drives these days I think the majority are simply copying either the whole disc or the main movie in DVD format without any compression.
jong1 is online now
post #4 of 10 Old 06-08-2009, 05:50 AM
mike_311's Avatar
- Josh
i started ripping my dvd tv shows to mkv for simplicity, using makemkv. but the quality is terrible. Even though the file size is about the same.
I wont being doing that again, unless i find a better program for the conversion.
"If the world didn't suck, we'd all fly off."
mike_311 is offline
post #5 of 10 Old 06-08-2009, 09:10 AM
Beefcake's Avatar
wait.. your complaining about 4.3GB as "huge". What is this 1997 or something???
1TB drive will hold about 230 of those "huge" rips. all for about $90. $0.09/GB. That's $0.39 per rip. Quit your bitchin'...
Beefcake is offline
post #6 of 10 Old 06-08-2009, 10:00 AM - Thread Starter
kingcain's Avatar
Well i'm not really complaing about cost I have 1500 of those huge files and only have room for 2 hard drives. I guess i should have said that before and I want to add more files as time goes by. I just wanted the best bang for my buck.
kingcain is offline
post #7 of 10 Old 06-08-2009, 10:35 AM
Ben_Tech's Avatar
Some people use xvid to encode the main movie and get it down to about 700mb. However, the quality does suffer. It is still watchable though, if the encoder knows what they are doing.
If it were me, I would just rip the main feature to an .iso without any re-encode. You have to consider if your time is worth the $540 it would cost to store your collection without encoding or pairing down, vs. the $180 with maximum compression. That is a $360 dollar difference that would cost you endless hours to encode 1500 movies properly.
You could find a sale on external 1TB drives for about the same price as the internal ones. Or, buy a different case for your pc. Most cases will hold 4 hard drives or more.
The above are hard drive prices, but you could do it for less with two burners (one read, one write) and spools of dvd+r's.
That last method is only of benefit to a pirate, however, as there is no benefit versus just leaving the discs as purchased. (Edit, well OK, people that have kids or careless spouses might want beater copies.)
My Blog - Ask Toy Tech
Ben_Tech is offline
post #8 of 10 Old 06-08-2009, 11:03 AM
Zagor's Avatar
This makes no sense at all. Makemkv does NOT do any kind of re-encoding/conversion at all. The original encoded material is left as is (that is why it is just about the exact same size). All it does is take the untouched video and audio streams and re-packages them into an mkv container.
Zagor is offline
post #9 of 10 Old 06-08-2009, 11:49 AM
ilovejedd's Avatar
Quoted: 76 Post(s)
Liked: 67
At 1500 discs, it's seriously not worth the time to encode. You're better off building a file server that can scale to future requirements. Right now, I have a 12TB unRAID server (8x1.5TB data HDD). There are two ways I can increase storage - install new drives or replace existing drives with higher capacity ones.
ilovejedd is offline
post #10 of 10 Old 06-08-2009, 12:01 PM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
Zagor is right. There is no video/audio quality loss with MakeMKV. Maybe you use different MPEG-2 video decoders (or settings) for DVD and MKV?
renethx is offline
Reply Home Theater Computers
