AMD Mobo + Two PCIE 1x? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 06-14-2009, 01:49 PM - Thread Starter
mi1stormilst's Avatar
I want to run two of these: Hauppauge WinTV-HVR 1800 MCE Kit 1128 on one Micro ATX AMD mobo. I prefer to stick to DDR2 since I already have a CPU and MEMORY for this type of a setup. Can any one make recommendations? I am currently running this mobo: GA-MA69GM-S2H
mi1stormilst is offline
post #2 of 4 Old 06-15-2009, 06:12 PM - Thread Starter
Help?
post #3 of 4 Old 06-15-2009, 07:12 PM
Java Jack's Avatar
I know the MSI 7411 board has 2 x PCIe x1 slots. However, it is 2x the cost because of the audio capabilities of the solution.
If you buy a 780 based board then you really only need 1x PCIe slot because you can use the PCIx x16 slot for 1 card and then the other PCIe x1 slot for the 2nd card.
Regards.
Java
There are 10 types of people in the world, those that understand binary, and those that don't.
AMD@Home Blog: http://links.amd.com/Home
Twitter: http://twitter.com/Java_Jack
Java Jack is offline
post #4 of 4 Old 06-16-2009, 09:56 AM
BigLan's Avatar
You could also run an 1800 (pcie) and a 1600 (pci) - they've both got very similar specs and can both tune qam channels.
BigLan is offline
Reply Home Theater Computers
