MPC Decoder not working Planet Earth - AVS Forum | Home Theater Discussions And Reviews
post #1 of 19 Old 06-28-2009, 11:39 AM - Thread Starter
tmavs's Avatar
In order to get the MPC decoder to work, I unregistered qasf.dll. The MPC Decoder works with every BD I've tried except one... Planet Earth Disk 5. When I try to play disc 5, I get a black screen.
If I register qasf.dll again, Planet Earth Disc 5 plays (no DXVA though and 100% CPU). Planet Earth is 1080i VC-1 encoded video.
HTPC Specs:
OS: WinXP SP2
CPU: AMD 3500+ (Socket 939)
GPU: HIS HD4670
Catalyst 9.5
Has anyone else experienced this problem? Any suggestions?
tmavs is offline
post #2 of 19 Old 06-28-2009, 07:41 PM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
MPC Video Decoder does not support interlaced VC-1.
renethx is offline
post #3 of 19 Old 06-29-2009, 12:46 AM - Thread Starter
tmavs's Avatar
Do you think Planet Earth Disk 1 to 4 is not VC-1 interlaced? MPC decoder works nicely for those disks.
Any suggestion for another decoder that supports DXVA for VC-1 interlaced video?
tmavs is offline
post #4 of 19 Old 06-29-2009, 01:13 AM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
Disk 1-4 are progressive.
WMVideo Decoder DMO.
renethx is offline
post #5 of 19 Old 06-29-2009, 01:21 AM - Thread Starter
tmavs's Avatar
It plays using this WMVideo Decoder DMO but the CPU usage is 100%.
I tried the WMV9 Power Toy by Alex Zambelli to enable DXVA, but that didn't seem to work
tmavs is offline
post #6 of 19 Old 06-29-2009, 01:56 AM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
PowerDVD/TMT are the best player/video decoder for interlaced VC-1 (supports DXVA fine).
renethx is offline
post #7 of 19 Old 06-29-2009, 02:02 AM - Thread Starter
tmavs's Avatar
Thanks I'll try that.
This thread also seems promising:
http://forum.doom9.org/showthread.php?t=144625
From that thread:
With this filter you can connect MPC Mpeg Splitter to Arcsoft Video Decoder which means you can get full dxva acceleration on ATI cards for both interlaced and progressive VC-1 video.
Works great on all the BDs I tested (using Zoom Player).
tmavs is offline
post #8 of 19 Old 06-29-2009, 02:07 AM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
Where is VC1Tweak.rar?
Never mind. Found it in a later post.
renethx is offline
post #9 of 19 Old 06-29-2009, 02:09 AM - Thread Starter
tmavs's Avatar
tmavs is offline
post #10 of 19 Old 06-29-2009, 09:23 AM
tlmaclennan's Avatar
I have my Planet Earth files setup as mkv with flac audio and decode it with the MPC decoder no problem. The only rip that gives me a problem is Sunshine, it gives a digital green screen over the video that flickers throughout the entire movie. I can decode it fine with ffdshow but then many of my other movies lag.
Any way of applying the ffdshow decoder just to my Sunshine mkv file and MPC to the rest of my movies?
tlmaclennan is offline
post #11 of 19 Old 06-29-2009, 05:25 PM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
The problem here is the lack of a decent free VC-1 decoder that supports DXVA (including deinterlacing), an equvalent of MPC - Video Decoder for H.264.
renethx is offline
post #12 of 19 Old 06-29-2009, 06:44 PM
CSMR's Avatar
Just download a properly encoded rip, none of this interlaced nonsense. You own the disk so no-one should complain.
CSMR is offline
post #13 of 19 Old 06-29-2009, 08:16 PM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
How is it a nonsense if the original video was shot at 50 fields per second?
renethx is offline
post #14 of 19 Old 07-01-2009, 03:16 AM - Thread Starter
tmavs's Avatar
renethx, have you had any success with the VC-1 tweaks?
I spent a lot of time trying to get them to playback a MKV containing VC-1 1080i video. The best I got was CPU usage around 30% and a stutter every 3 seconds ... using Arcsoft decoder.
With my other mkv's (Kung Fu Panda, Black Hawk Down) Arcsoft also gives poor performance (CPU 30%)... MPC decoder gives awesome performance (CPU 15%)
The last option will be to convert to H.264
tmavs is offline
post #15 of 19 Old 07-01-2009, 04:52 AM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
As for ArcSoft I am using TMT3 and this does not allow its decoders outside TMT3. So I tried CyberLink VC-1 Decoder (PDVD8) with 'CyberLink VC-1 Loader' (found in a thread linked in that thread). Unfortunately deinterlacing is very poor, but it works anyway.
TMT and PowerDVD are very good for interlaced/progressive VC-1 BD movies. What container is your Planet Earth 5 file? You can convert mkv/ts/m2ts to a BD folder/ISO by Clown_BD to play with PowerDVD/TMT. (Or TMT can play MKV directly, and PowerDVD too if you change the file extension to AVI or Divx.)
renethx is offline
post #16 of 19 Old 07-01-2009, 05:39 AM - Thread Starter
tmavs's Avatar
In the RAR archive, VC1Tweak_Haali allows you to connect to Arcsoft decoder.
I'm using a patched version of PowerDVD 7.3. I'll convert the MKV to ISO. I completely forgot about that option.
Should I upgrade to PowerDVD v8 or v9 for VC-1 deinterlacing?
tmavs is offline
post #17 of 19 Old 07-01-2009, 05:51 AM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
No. Radeon HD 4670 + PowerDVD 7.3 Ultra is good enough.
renethx is offline
post #18 of 19 Old 07-01-2009, 02:02 PM
CSMR's Avatar
Well nonsense compared with 1080p at 50fps. Interlacing is a relic from the days of CRTs that only serves to make things more complicated for LCDs. Admittedly a relic that got into the blu ray spec.
CSMR is offline
post #19 of 19 Old 07-01-2009, 04:34 PM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
1080p at 50/60Hz is just a future technology. Those videos shot interlaced have to be deinterlaced somewhere whether you like or not...
renethx is offline
Reply Home Theater Computers
