ATI Radeon 4850 - How to toggle between 2 and 7.1 speaker configuration - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 07-03-2009, 02:40 PM - Thread Starter
LSDave's Avatar
This is my first post, and I believe this is the right forum.
ISSUE: I want to toggle quickly from 2.0 to 7.1 speaker configuration, depending on whether I am listening to music or watching a movie. I can make that switch by clicking Control Panel -> Sound -> Realtek HDMI Output -> Configure -> plus four further mouse clicks to complete the switch. I created a "Sound" panel shortcut on my desktop to save the first step, but it still takes too many clicks. There must be a quicker way to toggle between 2.0 and 7.1. Please share your thoughts and insight.
HARDWARE: I have an HTPC for music and movies. It is built on a Intel 6600 Dual Core, and equipped with an ATI Radeon HD 4850. The ATI card connects to my Sony STR-DG720 Receiver via HDMI, and then from the Receiver to my speakers and HDTV. I have a 7.1 surround sound speaker configuration for movies, but prefer that music play in 2.0 channel stereo--the receiver filters low frequency from the 2 channels to the subwoofer (for 2.1 channels).
While the STR-DG720 Receiver is capable of upmixing a 2.0 HDMI signal to 7.1, it does not support downmixing a 7.1 HDMI signal to 2.0/2.1. Even if it did, I suspect the downmix would do a disservice to the intended stereo sound of the music—which I’d rather avoid. I think this means that toggling from 2.0 to 7.1 has to occur at the HTPC level.
OS & SOFTWARE: The HTPC runs Vista Ultimate 64bit. I use the Realtek driver for the ATI card. I use both MPC-HC and VLC for video play. I use Foobar for music.
QUESTIONS:
1. Is there a quick way to toggle between 2.1 and 7.1 speaker configuration, using the Realtek Driver?
2. If no, is there an add-on sound utility I could try? I installed SpeakerTray a while back, which purportedly allows a quick toggle between 5.1 and 2.0, but the ATI card just ignores it.
3. If no, do you have any other suggestions? It's ridiculous that every time I switch from music to movies I have to open three windows and make six mouse clicks to go from stereo to surround sound.
Thanks for your help.
LSDave is offline
post #2 of 3 Old 07-03-2009, 05:45 PM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
Use AutoHotkey or ReClock with WASAPI exclusive mode (bypass Windows Audio Engine that sends 7.1 whatever the channel number of the source is if you select 7.1 speakers).
renethx is offline
post #3 of 3 Old 07-03-2009, 09:04 PM - Thread Starter
LSDave's Avatar
AutoHotKey totally did the trick! Thanks so much.
LSDave is offline
Reply Home Theater Computers
