Dvr os - AVS Forum
post #1 of 14 Old 07-13-2009, 04:17 PM - Thread Starter
Luken8r's Avatar
Im in the earliest stages (starting today) of building my very own DVR and would like to know what sort of OSs are out there that are any good. Ive looked into MythTV a bit (Mythbuntu) but thats all. Are there any other good ones out there? What I really need it to do is
1) be easy to set up
2) be able to record more than one channel at a time (2 at the least)
3) play back on two separate TVs (one HD and one right now SD)
4) preferably *nix for the for the low low price of $0
Thats it. Everything else is gravy
Luken8r is offline
post #2 of 14 Old 07-13-2009, 04:24 PM
PGPFan's Avatar
I think a lot of people (myself included) find your #1 request, and *nix to be mutually exclusive of one another. FWIW, I use SageTV (works with any OS) to be robust, reliable, easier than *nix to setup, and will satisfy all your requirements, except the 'free' part.
-PGPfan
PGPFan is offline
post #3 of 14 Old 07-13-2009, 04:48 PM - Thread Starter
Luken8r's Avatar
thanks for the quick reply
I should have qualified #1 with saying that Im a computer guy and it took me all of 30 minutes to set up Ubuntu. I guess "easy" is a relative term. :P
Luken8r is offline
post #4 of 14 Old 07-13-2009, 06:21 PM
walford's Avatar
First it would help to know what dual tuner tuner card you have or plan to get so that you can record two programs conurrently
Second I am not aware of any way to play two different TV programs concurently on two differnt TVs/monitors concurently with a PC.
walford is offline
post #5 of 14 Old 07-14-2009, 06:04 AM - Thread Starter
Luken8r's Avatar
I havent even gotten to the point of selecting hardware. I am just looking into the possibility of some OS working as I need it to.
Luken8r is offline
post #6 of 14 Old 07-14-2009, 06:41 AM
mike_311's Avatar
do yourself a favor, spend the money on win7. Try the RC if you have dobts, but the dvr in media center is top notch.
also here is info on the others...
http://lifehacker.com/5128408/six-best-dvr-applications
"If the world didn't suck, we'd all fly off."
mike_311 is offline
post #7 of 14 Old 07-14-2009, 06:54 AM - Thread Starter
Luken8r's Avatar
Win7, eh? Interesting. I had Vista on my laptop and it was garbage so I did the Win7 upgrade and it was equally as bad. It could have been all of the bloatware that came with my laptop slowing it down though, I didnt wipe it between.
Luken8r is offline
post #8 of 14 Old 07-14-2009, 07:56 AM
mike_311's Avatar
try it.
i've had my vista machine running 24/7 non stop for months, never missed a recording. only rebooted after software install, never becuase of slow down.
i upgraded to win7 for qam support is its been equally as stable.
mike_311 is offline
post #9 of 14 Old 07-16-2009, 01:26 PM
Servicetech571's Avatar
I have to agree WMC7 is excellent. Only a couple of drawbacks concerning DRM and of course the cost. It records when it's supposed to, video quality is excellent, easy to setup, works "out of the box".
MythTV is MUCH more difficult to set up than ubuntu IMHO. Ubuntu is pretty much plug and play if you have Linux compatible hardware. I love ubuntu for my desktop, but my HTPC runs W7.
Servicetech571 is offline
post #10 of 14 Old 07-16-2009, 01:32 PM
candre23's Avatar
There's your problem
I have Vista 64bit on my fast, multi-core desktop and Win7 on my older, slower, single-core laptop and they both run (UI-wise) at about the same speed. Do a fresh install and I think you'll be pleasantly surprised.
candre23 is offline
post #11 of 14 Old 07-16-2009, 01:33 PM
B Leisle's Avatar
I hated Vista as well but have been very happy with the Win7 RC. 7's Media Center is definitely worth a look.
B Leisle is offline
post #12 of 14 Old 07-17-2009, 12:42 PM
BigT2's Avatar
Take a look at GBPVR it runs on windows it is pretty easy to setup. It should do almost everything you want and maybe more. There is a very good forum of very helpful people. I have been running it for about 2 years.
Tom
BigT2 is offline
post #13 of 14 Old 08-16-2009, 06:03 PM
PostPCMan's Avatar
I'm using SageTV on Ubuntu 9.04. Works great, and there's a good support forum for it at sagetv.com. If you're comfortable with linux, I'd go for it.
PostPCMan is offline
post #14 of 14 Old 08-16-2009, 07:54 PM
StinDaWg's Avatar
Quoted: 149 Post(s)
Liked: 134
Windows 7 is the easy answer here!
StinDaWg is offline
Reply Home Theater Computers
User Tag List
