Critique Build, about to order - AVS Forum | Home Theater Discussions And Reviews
Old 07-21-2009, 04:57 AM - Thread Starter
A_K_A's Avatar
This is larger based off renethx's recommendations thread.
I plan on using it mostly for online video, hulu, netflix, etc. divx files and then in the short future adding a tuner card to record OTA HD. No blu-ray since I have a nice blu-ray player already.
Ordering
ZOTAC GeForce 9300-ITX WiFi GF9300-D-E
Pentium Dual-Core E5200
SilverStone NT07-775
WD SATA 160GB
Samsung SH-S203N 20x DVD±RW DL SATA Drive
Apex MI-008
Already have 2GB of DDR2 667 memory for it laying around. I'm sure not ideal but would give it a shot before ordering memory.
If it matter it will be going into a Pioneer 1018 receiver for audio/video. Insignia 36" LCD and Mitsubishi HC1500 projector.
Size matters... 100" will do for now.
A_K_A is offline
Old 07-21-2009, 05:14 AM
steven975's Avatar
Good choices, but I hear the Zotac may have issues with USB devices waking the board up from standby. This may only apply to their ITX-sized board; not sure...read some Newegg reviews. I helped a friend build a PC based on the Asus version of the 9300 and he has been happy with it.
Also, I think DDR2-667 is just fine. Memory speed is a little more important with an IGP like the 9300, but I think you'll be fine. The CPU isn't going to suffer as a 1333FSB is basically saturated by DDR2-667.
steven975 is offline
Old 07-21-2009, 07:04 AM
ArtosDracon's Avatar
Looks Good.
ArtosDracon is offline
Old 08-03-2009, 10:02 AM - Thread Starter
A_K_A's Avatar
Last of the parts come in today, can't wait.
Right now I'm leaning towards WinXP and using Media Portal and Hulu Desktop.
What are peoples recomendations on a remote? Should I just get the usual MCE remote I keep seeing mentioned. Is 1 MCE remote the same as another? I have a Harmony 657 and would great if I could get most functionality to work with the Harmony.
I see something like this looks nice with the mouse controls also built in.
http://www.amazon.com/Windows-Contro...9315299&sr=8-2
A_K_A is offline
Old 08-03-2009, 10:40 AM
bimmerfreak0's Avatar
Quoted: 12 Post(s)
i would definately get a bigger hard drive 160gb is not going to be sufficient for recording...500 to 1tb at least
bimmerfreak0 is online now
Old 08-03-2009, 10:56 AM
stanglx's Avatar
Good Choice.. Ditch XP and get WIn 7 RC
HD is not large enough unless you have a Server
Ordering
WD SATA 160GB
Apex MI-008
stanglx is offline
Old 08-03-2009, 11:16 AM
mike_311's Avatar
subtract out the OS and program and you have about enough storage for 15 hr long hd shows, not counting your live recording buffer...
get teh most bang for your buck or add if you aren't storing any media definitely get at least 500 gb for tv, you can always add a second 1.5tb hdd if you plan to store any media...
"If the world didn't suck, we'd all fly off."
mike_311 is offline
Old 08-04-2009, 04:17 AM - Thread Starter
A_K_A's Avatar
Should have updated that post. When I was purchasing everything I got a deal on a 500g drive. So it's got a 500g drive and I also have a 1.5t NAS drive.
Any comments on the remote questions?
A_K_A is offline
Old 08-04-2009, 04:37 AM
I'm really spoiled for remote, I use a Snapstream firefly remote, it's got pretty much the same features as a media center remote but has mouse mode, four programmable favorites buttons and is RF. I love it.
