re-rip CDs or convert WMA to FLAC? - AVS Forum | Home Theater Discussions And Reviews
Old 07-22-2009, 03:51 PM - Thread Starter
lifespeed's Avatar
Quoted: 25 Post(s)
I have read about the virtues of Exact Audio Copy regarding making the Most Perfect extraction of digital audio from a Redbook CD. However, when I ripped my CD library to hard drive I just used WMP10 to rip to WMA-lossless format.
Now I am adding FLAC rips of DVD-Audio discs I own, and am wondering about converting my CD library to FLAC. It might make more sense to stick with one format. I could convert the WMA to FLAC. Lossless is lossless. This would certainly by easier than ripping from CD and adding missing album data.
Would audio quality really benefit by using Exact Audio Copy instead of converting the WMP rips? I have to admit this is a bit hard to imagine. Only talking about 250 CDs, wouldn't be the end of the world to re-rip.
Opinions? Actual experience?
Lifespeed
lifespeed is offline
Old 07-22-2009, 04:06 PM
MSmith83's Avatar
Quoted: 232 Post(s)
Liked: 191
I've converted a few albums encoded in WMA Lossless (through WMP) to FLAC through foobar2000. It is quick, easy and completely lossless. To verify, I tested to see if the resulting files that came from HDCD would be recognized by my AVR as having HDCD data. As expected, the resulting audio is still recognized as such.
By the way, there is now a DVD-Audio decoder available for foobar2000. I've converted DVD-Audio tracks directly to FLAC with no issues. There is a thread about it in the Surround Music Format section of AVS if you didn't already know.
MSmith83 is offline
Old 07-22-2009, 04:22 PM - Thread Starter
lifespeed's Avatar
Quoted: 25 Post(s)
Yes, the DVD-Audio decoder for foobar2000 is what prompted me to try this. And I did notice the thread you reference.
I guess I am mainly wondering about any real (vs theoretical) difference in accuracy of the bits extracted from CD by WMP, compared to using Exact Audio Copy.
Lifespeed
Old 07-22-2009, 04:24 PM
jszei's Avatar
Quoted: 17 Post(s)
If you have the time then re-rip it all.
You'll get the most accurate representation *guaranteed* of your CDs and you'll know if any errors occur in the extraction where you wouldn't otherwise.
It is nice to have it all in .flac as it's the best lossless compression format.
I use an iPod so I have my music double ripped in ALC for that as well as FLAC for home. Ripping CDs to Apple Lossless with iTunes sucks because errors occur and you don't find out until you listen to it.
Digital chain: Synology DS1815+ -> Custom PC (Windows 2012R2 AO, Fidelizer, Roon, HQPlayer, JRiver) -> microRendu -> Audio Alchemy DDP1 and PS-5 -> Emotiva XPA-5 -> B&W 803s
Analog chain: Project RPM 3 Carbon with Blue Point #2 -> Moon 110LP -> Audio Alchemy DDP1 and PS-5 -> Emotiva XPA-5 -> B&W 803s
Theater: Marantz AV7701, Sony VPL-HW50ES
jszei is offline
Old 07-22-2009, 04:34 PM
MSmith83's Avatar
Quoted: 232 Post(s)
Liked: 191
When compared to direct CD playback, my ears have not detected any added distortions or the like.
If you want complete assurance, then it may make sense to re-rip them. There may very well be some problematic discs that have caused errors undetected by WMP. You can then copy the metadata from your unused WMA lossless tracks to the newly created FLAC files if needed.
MSmith83 is offline
Old 07-22-2009, 04:42 PM
gameboy's Avatar
Lossless means they are exact copies. There is absolutely no difference in sound when you listen to either codec.
Only differences are how the achieve their compressions. Some are more effecient than the others, but if they are lossless, there are no differences in data stored.
gameboy is offline
Old 07-22-2009, 04:58 PM
jszei's Avatar
Quoted: 17 Post(s)
Lossless means there is no information lost due to compression, not that they are exact copies.
A rip may be exact unless an error occurs due to bad sector, skip whatever and is unreckognized by the ripper. EAC will let you know.
you are partially right though, if the rip is perfect then whether it's in shorten (.shn), flac or whatever lossless format, lossless is lossless.
jszei is offline
Old 07-22-2009, 10:45 PM
jimwhite's Avatar
Says who and why??
Jim White
St. Petersburg, FL
jimwhite is offline
Old 07-22-2009, 11:57 PM
jszei's Avatar
Quoted: 17 Post(s)
Originally Posted by jimwhite View Post
Says who and why??
"The technical strengths of FLAC compared to other lossless codecs lie in its ability to be streamed and in a fast decode time, which is independent of compression level."
This should explain things in much better detail
http://wiki.hydrogenaudio.org/index....ess_comparison
http://en.wikipedia.org/wiki/Free_Lossless_Audio_Codec
jszei is offline
Old 07-24-2009, 04:12 PM
roots4x's Avatar
I wouldn't waste time re-ripping if i were you. All FLACs I download I archive and convert to WMA-L just so they'll play nicely with WMC.
At worst, you might have a couple blips here and there because WMP doesn't confirm exact rips or not. However, 99.999% of the music will sound perfect.
roots4x is offline
Old 07-24-2009, 04:53 PM
jszei's Avatar
Quoted: 17 Post(s)
Media Portal will play FLAC
jszei is offline
Old 07-24-2009, 05:08 PM - Thread Starter
lifespeed's Avatar
Quoted: 25 Post(s)
can't you teach windows to play FLAC just by installing the right codec? I play MKV with FLAC audio on Vista x64 in WMP11, WMC, MPC-HC, and TMT2.
Lifespeed
