Low profile PCI slot cooling for HTPC? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 07-31-2009, 09:10 PM - Thread Starter
patdman08's Avatar
Hi all,
I recently built a HTPC using the HEC 7K09 case.
I love my setup sooo much, but the case is a little cramped and runs kinda hot.
Here's my setup
LG GGC-H20L BD/HD/DVD drive
Western Digital 320gb HDD
4gb G.Skill DDR2 1066 RAM
GIGABYTE GA-MA78GM-US2H
AMD Athlon 64 X2 5050e
HEC 7K09 HTPC Case
What I would like to do is find a PCI slot fan that will fit in this case...so something low profile.
I tried looking but haven't found much. Has anyone found anything similar, or just a way to enhance airflow in a case of this size?
Cheers,
Pat.
patdman08 is offline
post #2 of 11 Old 07-31-2009, 09:31 PM
steven975's Avatar
how hot is hot?
I don't think any of those components use all that much power.
steven975 is offline
post #3 of 11 Old 07-31-2009, 09:34 PM
candre23's Avatar
I don't think anybody makes a half-height PCI cooler. Your options with a case that small are pretty limited for off-the-shelf solutions, but you might be able to rig something up.
If you're not using any of the PCI slots, you could fit a 60mm or 80mm fan inside of the case, exhausting out through the slot openings. Alternately, you could cut a hole in the top of the case and mount a fan above the slots. A slim fan like this might even fit above a half-height card if you're using one.
candre23 is offline
post #4 of 11 Old 07-31-2009, 11:24 PM - Thread Starter
patdman08's Avatar
Thanks for the info, I didn't think anything half height existed.
Things aren't toooo hot, but it's the middle of summer, we live on the 3rd floor of a house with no air conditioning, the HTPC is not in that well a ventilated area, so even with fans in the house, it's constantly around 90 degrees F, and the CPU temp hovers around 120 F.
It's not the end of the world by any means, I just thought if there was something I could easily slot in to help ventilation, that I would do so.
I don't really want to take a dremel to the case...at least not yet, as I am waiting to see if I will end up putting a dedicated video card in there for better HD video processing.
Cheers,
Pat.
post #5 of 11 Old 07-31-2009, 11:34 PM
candre23's Avatar
Better video processing likely means more heat as well. If you're concerned now, it will only get worse with a dedicated video card.
You could always try replacing the existing 80mm fan with one that pushes more air, though that will jack up the fan noise considerably.
candre23 is offline
post #6 of 11 Old 08-01-2009, 01:23 AM
paratwa's Avatar
Rather than get a case fan, I would consider getting a window air conditioner for that room. Blowing air that is already hot into a computer will not make a system run cooler. Ambient air is a killer when it gets hotter than your components.
And how do you sleep at night with it that hot? I live in Arizona where the night temps get down to 90f. I could not sleep in that. There is NO way I could live here with out A/C!
paratwa is offline
post #7 of 11 Old 08-01-2009, 09:29 AM
H8nXTC's Avatar
Here's a possible solution, if you have an area of 40mm x 40mm x 40mm that you can attach internally to a vented area (like right above the rear sockets on your case, you can see if you can find a Thermaltake Extreme Spirit (the original, not the II) chipset cooler, take the fan off the heatsink and attach the fan to a vent, it comes with a 3 speed controller also. It'll suck the warm air out and exhaust it to the exterior.
http://3btech.net/thexspnosobr.html
H8nXTC is offline
post #8 of 11 Old 02-03-2011, 02:34 PM
branded888's Avatar
Hi all,
Here's my setup
HEC 7K09 HTPC Case
Cheers,
Pat.
I sell a Low Profile PCI Fan Card and a Low Profile PCI Exhaust fan card on Ebay.
branded888 is offline
post #9 of 11 Old 02-03-2011, 02:36 PM
ES_Revenge's Avatar
Quoted: 410 Post(s)
Liked: 133
You are two years late to this party it seems, LOL.
ES_Revenge is offline
post #10 of 11 Old 01-28-2013, 11:41 AM
NinjaUnmatched's Avatar
Hi all,
Here's my setup
HEC 7K09 HTPC Case
Cheers,
Pat.
I see the one you are talking about......seller bryanmoore? $30 is a bit expensive plus the thing looks like it won't even fit in most SFF systems. If that is you...
NinjaUnmatched is offline
post #11 of 11 Old 01-29-2013, 01:00 AM
weisstksing's Avatar
yeah,i agree with you, $30 is a bit expensive plus the thing looks like it won't even fit in most SFF systems. thanks for your sharing 1.gif
weisstksing is offline
Reply Home Theater Computers
