Dell Zino HD - New mini HTPC - Page 4 - AVS Forum | Home Theater Discussions And Reviews
post #91 of 5041 Old 11-12-2009, 02:55 PM
Java Jack's Avatar
Originally Posted by klas View Post
I don't see Zino on EPP site. Did you order over the phone?
I did not see it there either when I looked.
A few people here at AMD all want to place orders ASAP as well.
Regards.
Java
There are 10 types of people in the world, those that understand binary, and those that don't.
AMD@Home Blog: http://links.amd.com/Home
Twitter: http://twitter.com/Java_Jack
Java Jack is offline
post #92 of 5041 Old 11-12-2009, 02:58 PM
hbomber202020's Avatar
I didn't order yet and now that you mention it, I don't see the Zino on the EPP site. I would try over the phone, at the least you should be able to get free shipping....*I would think*
Screw a discount on the thing, a least free shipping would be nice.
hbomber202020 is offline
post #93 of 5041 Old 11-12-2009, 02:59 PM
ralphkaz's Avatar
I know that Flash is soon supposed to be GPU accelerated on the Nvidia/Ion (Revo) platform - is this also true for ATI (Zino)?
ralphkaz is offline
post #94 of 5041 Old 11-12-2009, 03:05 PM
dbears's Avatar
Can you get DD or DTS 5.1 thru the HDMI output?
dbears is offline
post #95 of 5041 Old 11-12-2009, 03:19 PM - Thread Starter
candre23's Avatar
Originally Posted by Java Jack View Post
However, what I will do when I get my unit back is try disabling one of the cores and see what happens with flash content.
Could you specifically test this video? Legend of the Seeker 1x01 is often used as a benchmark for HD streaming video, as it is available in 720p and the first few minutes have a lot of high-motion, high-detail scenes. If the Zino is able to play this video without stuttering, it will play anything available online. If it can do it with a single core, then Dell and AMD really have a winner on their hands.
Sure, the C2D in the Mac Mini is still faster in the benchmarks, but if the AMD chips are fast enough to do HD streaming flash, then benchmarks don't matter.
candre23 is offline
post #96 of 5041 Old 11-12-2009, 03:24 PM
Java Jack's Avatar
Actaully, Adobe has not released any h/w accelerated flash player yet. Rumors are they are working on it but to my knowledge it is not yet available.
With that said, I fully expect that if such a h/w accelerated flash player were to be released that it would also work for this platform.
Regards.
Java
post #97 of 5041 Old 11-12-2009, 03:25 PM
Java Jack's Avatar
Sure. I just got the unit back 10 mins ago. I will start setting everything back up.
Regards.
Java
post #98 of 5041 Old 11-12-2009, 03:26 PM
beefjerky_7's Avatar
How does this compare to the ASRock 330?
beefjerky_7 is offline
post #99 of 5041 Old 11-12-2009, 04:02 PM
MikeSM's Avatar
One question about the GPU, is this a regular 4330 or a mobility 4330? According to some AMD specs, the mobility 4330 handles HD decode, but SD is done in software by the CPU. Aside from how this plays with the 780G, I can only imagine how this would screw with pixel format and video dynamic range adjustments - it reminds me of the bad old days in drivers when video would use one set of output levels and games would use a different set.
MikeSM is offline
post #100 of 5041 Old 11-12-2009, 04:42 PM
klas's Avatar
Called Dell EPP and they couldn't order one... but I canceled my Home order though, they tried to lure me back
Mac Mini HTPC (Win7)
klas is offline
post #101 of 5041 Old 11-12-2009, 05:07 PM
CDLehner's Avatar
Quoted: 767 Post(s)
Liked: 1146
OK...I'm sold, and chomping at the bit to pull the trigger tonight. Remember, it's my first foray into HTPC, so can someone help me find the "sweet spot" with this machine; which do you think are the worthwhile upgrades?
- 3250 dual-core processor for $60
- win7 for $30
- the BD drive for $100 (will it be easy enough to add a drive to this form?)
- 4330 graphics card for $75
CD
CDLehner is offline
post #102 of 5041 Old 11-12-2009, 05:11 PM
CDLehner's Avatar
Quoted: 767 Post(s)
Liked: 1146
Originally Posted by dan4081 View Post
Are you planning on going with XBMC with this?
If so, are you concerned that this doesnt have an nvidia sound card, so no GPU acceleration?
Well Dan...initially, I wasn't thinking along those lines; although everyone says XBMC's GUI can't be beat (I love mine for what I use it for), so maybe. But I thought XBMC couldn't do HD?
As for your other question, it's all greek to me.
CD
CDLehner is offline
post #103 of 5041 Old 11-12-2009, 05:11 PM
dbone1026's Avatar
Quoted: 216 Post(s)
Liked: 110
- win7 for $30
CD
Looks good. I would probably go with either 3 or 4 GB RAM. Also, probably worth getting a cheap IR Receiver separate so you can control with an MCE remote or universal (http://www.newegg.com/Product/Produc...-001-_-Product)
Cheers,
Damian
MSS.net blog (contributing editor) - http://www.mediasmartserver.net
Windows Entertainment and Connected Home MVP 2010-2012
dbone1026 is offline
post #104 of 5041 Old 11-12-2009, 05:13 PM
dbone1026's Avatar
Quoted: 216 Post(s)
Liked: 110
CD
They are working on HA for XBMC in Windows but it is not there yet. If you really want to use XBMC you can called up MPC HC for video playback so you get HA.
I would suggest going with 7MC + MediaBrowser
Cheers,
Damian
post #105 of 5041 Old 11-12-2009, 05:21 PM
klas's Avatar
forget MCE remotes, Gyration RF remote is much better, plus it can be programmed to control tv, speakers etc...
klas is offline
post #106 of 5041 Old 11-12-2009, 05:24 PM
CDLehner's Avatar
Quoted: 767 Post(s)
Liked: 1146
So you're suggesting ALL of these upgrades...plus more RAM? That turns our affordable $229 box into a $500 box. I know that's still not a lot of money for a well fleshed-out HTPC, but this is my first attempt; isn't there something to be said for easing in?
CD
CDLehner is offline
post #107 of 5041 Old 11-12-2009, 05:31 PM
dbone1026's Avatar
Quoted: 216 Post(s)
Liked: 110
CD
Do you plan on using the BR drive or are you just going to be streaming? You can always skip the BR Rom since that is a big cost and add later. To be honest you will be perfectly fine with 2GB RAM, I have just always been in the habit of upping the RAM.
Cheers,
Damian
post #108 of 5041 Old 11-12-2009, 05:36 PM
Jdecarol's Avatar
How much ram does Windows 7 use just sitting by itself, not including anti virus/spyware and whatever addons.
Jdecarol is offline
post #109 of 5041 Old 11-12-2009, 05:41 PM
ilovejedd's Avatar
Quoted: 76 Post(s)
Liked: 67
+1. The opening sequence of Legend of the Seeker Episode 1 HD is my standard test for a "fast enough" machine. I think it should be a staple for reviews. Most of the reviews I've seen, particularly for ION netbooks/nettops, only tested YouTube HD videos and complexity of those tend to vary, not to mention I've found them to be relatively easy on the processor. One reason I'm enamoured with dual-core CULV notebooks is because they were able to pass the fullscreen Hulu HD test.
Can you also monitor CPU usage while you're at it? I don't think you'll be able to do so in fullscreen mode but maximizing the pop-out window should do the trick.
- win7 for $30
CD
The CPU is a definite yes. Windows 7 Home Premium is a yes, too, assuming you plan on using Windows Media Center. The specs on the $229 model changed so it now comes with Vista Home Basic 32-bit. Earlier today, $229 gets you Windows 7 already. The Blu-ray drive depends on you. I don't need the machine to play Blu-ray discs as mine gets ripped to a file server and I just stream from there. However, if you want Blu-ray on yours, you won't currently be able to find a slim Blu-ray drive cheaper than $100. The 4330 is a maybe. I'm still waiting on how Jay's tests go. As for RAM, I'm using Windows 7 Ultimate 64-bit on an Intel D945GCLF2 (945GC+Atom330) with maximum 2GB RAM on both a nettop and an HTPC (old CRT TV w/S-Video). The nettop works just fine albeit it tends to slow down when Firefox is left running a couple of days in a row. The HTPC works like a champ, albeit, it can only do 720p H.264 and 720p/1080i MPEG-2. 2GB RAM is more than respectable especially if you're trying to cut costs.
ilovejedd is offline
post #110 of 5041 Old 11-12-2009, 05:42 PM
CDLehner's Avatar
Quoted: 767 Post(s)
Liked: 1146
Well...if I had my way, I'd skip the BD drive for now. I have a PS3 at the same spot, and that can handle the very rare BD disc playback. Mostly I stream. If down the road, I wanted to have the BD disc capability, I'm usually happier adding after the fact...although I wasn't sure this would be an easy option, with the form factor?
And I hardly ever max RAM out on the build...it's so easy, and usually cheaper, to add later...if you even need to at all. So, in asking about the upgrades, I was mostly questioning which would keep the Zino from being "useless"; is the "included" processor going to keep it from doing a lot of things, in which case the dual-core 3250 is $60 well spent? Ditto the upgraded graphics card, and I'm pretty sure I want to make the jump to 7 (I went this long skipping Vista, now's certainly not the time to go down that road...lol).
CD
CDLehner is offline
post #111 of 5041 Old 11-12-2009, 05:50 PM
Java Jack's Avatar
- win7 for $30
CD
Here are some things to consider...
Blu ray?
How big is your TV? Anything under 50" does not really need BD IMO. BD really starts to look a lot better on screens larger than 50". Don't misunderstand me, BD looks better on any screen but upscaled DVD looks pretty darn good and I don't know that BD is really worth it unless your TV is larger than 50". Once cost parity for DVD/BD is nearly the same, then sure, but at $100, you really need to think on that one.
GPU?
I am still waiting on the 4330 version of this system so I can test it out to see the real advantages. I would love to say spend more money here as that would certainly be good for me. However, until I test it, I can't really offer too much help. If you think you are going to game on the system then yes, upgrade the GPU. If this is going to be a streaming and DVD playback box, then you probably won't need the GPU upgrade.
CPU?
Given the options here, more would be better. However, my testing with the 3250e has been pretty good for most HTPC tasks. I always like a little more processing power available, provide a little headroom. Some of this depends on what all you plan on doing with it. higher freq. might be more important than core count, or core count might be more imporant that freq. all depends on what you are doing. You could solve both of these by going to 6850e, but it depends then on what your budget is going to be.
Memory?
2GB is pretty good for almost any HTPC task. I have systems with 2GB in them and others with 4GB, I can't see any real perforamce difference between the two.
HDD?
Again, depends on what you are doing. Do you have other PCs in the house that will store the majority of content or will you be storing it on the Dell box? If the Dell box, then more is always better. If you have a home server, etc. that will store the content, then more may not be needed.
Add Ons to consider...
TV Tuner. Part of the HTPC experience can involve the DVR functions available. I have 1 or more tuners on all my HTPCs. However, keep in mind the comments on storage. If you DVR a lot of stuff, more storage is better.
Remote
USB Ir receiver and remote combos for about $20.00. HTPC is just not an HTPC if you are stuck using keyboard/mouse to operate. One with mouse functionality like the Gyration even better.
Wireless Keyboard/Mouse
Dell box comes with wired keyboard/mouse. Not the best HTPC experience. a nice wireless solution is worth the investment. However, if you get your set up done right, you may rarely need a keyboard.
Maybe I should do a blog on building an HTPC experience around the Dell box and set a budget around it...hmm.
Regards.
Java
post #112 of 5041 Old 11-12-2009, 05:53 PM
dan4081's Avatar
Quoted: 74 Post(s)
Liked: 78
CD
XBMC on the $199 Acer Revo can do HD perfectly. XBMC for linux uses the graphics card to help handle the HD content, but it needs to use an nvidia video card.
Now on the dell Zino you can load XBMC for Windows and configure it to launch an external player for HD content and it should play it perfectly.
Read this thread for some more info on using XBMC with the $199 Revo to play HD content: http://www.avsforum.com/avs-vb/showthread.php?t=1185529
The Zino and the revo are both similar, but the Zino looks like it has a few more nice features.
Revo Ion...XBMC For Windows...Dharma RC2
dan4081 is offline
post #113 of 5041 Old 11-12-2009, 05:55 PM
Java Jack's Avatar
No problem. I should be able to full screen it and just set the task manager to always on top.
I will test it out tomorrow when I am back in the office.
Regards.
Java
post #114 of 5041 Old 11-12-2009, 05:56 PM
CDLehner's Avatar
Quoted: 767 Post(s)
Liked: 1146
Thanks Dan. I'll cross the XBMC bridge when I get to it; first things first.
CD
CDLehner is offline
post #115 of 5041 Old 11-12-2009, 06:00 PM
fcorona76's Avatar
CD
I'm pulling the trigger now. I am going with the dual core 1.8ghz Athlon, 2GB RAM, smallest hard drive, Win 7, and standard DVD.
Unless you plan on doing heavy computing why on earth would you need 4 GB of ram for movie playback? You really dont.
And the mobility 3200 does Avivo so I dont see a reason for the 4300 at all...again, unless you plan on doing more than media playback.
fcorona76 is offline
post #116 of 5041 Old 11-12-2009, 06:02 PM
dan4081's Avatar
Quoted: 74 Post(s)
Liked: 78
CD
No problem.
I just assumed you were looking to get the Zino to use as an HTPC, and if so I figured you would probably first decide what front end you are going to use so you know what upgrades are important.
The Revo thread I posted really lays out whats important for HD streaming in one of these mini-pc's. (Zino or Revo)
dan4081 is offline
post #117 of 5041 Old 11-12-2009, 06:03 PM
dan4081's Avatar
Quoted: 74 Post(s)
Liked: 78
Whats the total on that come to?
And any deals on shipping found yet?
dan4081 is offline
post #118 of 5041 Old 11-12-2009, 06:04 PM
CDLehner's Avatar
Quoted: 767 Post(s)
Liked: 1146
Blu ray?
GPU?
CPU?
Memory?
HDD?
Remote
JJ, thanks for the info. I'm new to HTPC, but not BD/HT/NMT...I already have 2 BD players, and 2 NMTs that stream BD...lol. So it's not a matter of whether I'm on-board for BD (one location is my 96" HT screen, btw; the other, the 50" Kuro), but whether I need it in this, my first HTPC. I know, I know...only I can answer if I need it; my question was more is it likely to be hard to add later, given the Zino's form factor?
I don't plan on gaming on this PC, just VOD and streaming. I want best resolution available from the source. I don't know what Fancast, Hulu, Netflix, etc. will do, but if they'll do 720p for example...I don't want to settle for 480p because my GPU won't handle it. But are you saying the 3200 should handle anything video, and only upgrade to the 4330 for hardcore gaming? Ditto for the CPU.
Memory, bigger HDD (never, as I have an MSS with 6T and growing), remotes, etc will all come later. I'm defintely a walk before you run kinda guy when I'm getting into something new.
Thoughts?
CD
CDLehner is offline
post #119 of 5041 Old 11-12-2009, 06:08 PM
fcorona76's Avatar
$369 + $39 shipping.
That shipping sucks...second thoughts...
post #120 of 5041 Old 11-12-2009, 06:08 PM
klas's Avatar
they are including Windows Vista now with base system.
klas is offline
Reply Home Theater Computers
