upscaling standard dvd movies to 1080p using ffdshow and your htpc - Page 11 - AVS Forum | Home Theater Discussions And Reviews
post #301 of 355 Old 04-06-2011, 09:55 PM
greg1292's Avatar
Quoted: 83 Post(s)
Liked: 27
8:13 nice script for AMD. I deleted all the past scripts.Can't get
mflow to work without stuttering. Mblock looks fluid like the previous
mflow script. Cool indeed. Cpu at 44%.
greg1292 is offline
post #302 of 355 Old 04-07-2011, 07:33 AM
greg1292's Avatar
Quoted: 83 Post(s)
Liked: 27
Looks like the new script has greater clarity to it! Like going from
60hz to 240hz if that makes sense.
Also the script almost plays 1080p files. What would be a good script for
1080p files?
greg1292 is offline
post #303 of 355 Old 04-10-2011, 09:05 AM
pacemaker's Avatar
Quoted: 30 Post(s)
can someone answer this question
can ffdshow identify avi's from DVD's and use different post processing like sharpening for dvd's but not for avi's. then say denoise for avi's and not dvd's as examples?
thanks
pacemaker is offline
post #304 of 355 Old 04-11-2011, 07:22 PM
hanly2's Avatar
How is this possible? If you only have data on the disk to make it 480 how can you get more data out of the disk to make it 1080? Is there an app to turn my chevy into a benz?
hanly2 is offline
post #305 of 355 Old 04-25-2011, 07:05 PM
greg1292's Avatar
Quoted: 83 Post(s)
Liked: 27
Any news on a new script?
greg1292 is offline
post #306 of 355 Old 04-27-2011, 07:28 AM
greg1292's Avatar
Quoted: 83 Post(s)
Liked: 27
Originally Posted by 8:13 View Post
Nope. I'm watching Subjunk and Widezu and those people doing their thing.
If I had a videocard that could use SVP I might try it.
I have been using the SVP and nice project. Enjoy the on the fly adjustments.
The I2600K processor sure makes things easier.
Been playing around with the new Linux Natty picture looks good.
For some reason the picture looks better? Maybe it is a driver thing but Mplayer
has acceleration and other features seems like video drivers are broke in
Windows even though they work!
Looks like while we sit on the side lines there may be another option for
PQ playback. These threads sure give us a great picture for that I am greatful.
greg1292 is offline
post #307 of 355 Old 05-08-2011, 08:51 AM
lilwheezy75's Avatar
so im someone who does some heavy duty Dvd watching via ripped dvd in folder structure... Vob files probably. AVI files and mpg files for ripped standard definition tv series DVDs.
Am i someone who could benefit from this and how do i take advantage of the setup? Im using the Shark007 codec which includes ffdshow if im not mistaken. do all i need to do is download avisynth and follow the directions?
lilwheezy75 is offline
post #308 of 355 Old 05-08-2011, 09:11 PM - Thread Starter
8:13's Avatar
Here is my frame doubler. It uses the SVP Project's dll's: libflowsse, and libflowgpu.
This particular frame doubler needs the mvtools2.dll the SVP Project team made, so all three dll's are in both the plugins and software links in the first post.
Nothing special really, just put the fftw3,dll in the system32 folder in a windows 32 bit operating system, or if you have windows 64 bit operating system put fftw3.dll in the syswow64 folder. Read the first post for more detailed instructions.
So, what is different about libflowgpu vs libflowsse? One; libflowsse, only use the cpu and the other; libflowgpu, uses the gpu or videocard too.
And to use libflowgpu you need a newer videocard that has OpenCL API ability, use any of the videocards below to get the required OpenCl API:
AMD HD5xxx
AMD HD6xxx
NVIDIA 8xxx, 9xxx, 2xx, 4xx, 5xx
here is my frame doubler code, it's for Intel CPU:
Code:
svp_scheduler=true
svp_cache_reduce=true
svp_flow_lib="C:\\Program Files\\Avisynth 2.5\\plugins\\libflowsse.dll"
setmtmode(5,0)
SetMemoryMax(512)
video=ffdshow_source().changefps(ffdshow_source(), linear=true)
A = video.autolevels()
B = video
setmtmode(2)
SetMemoryMax(512)
super_1 = A.MSuper(pel=2, hpad=12, vpad=12, rfilter=2, isse=true)
super_2 = B.MSuper(pel=2, hpad=12, vpad=12, rfilter=1, isse=true)
F = Video.MFinest(super_2)
backward_vec = MAnalyse(super_1, isb=true, search=3, searchparam=3, isse=true, lambda=50, dct=4)
forward_vec = MAnalyse(super_1, isb=false, search=3, searchparam=3, isse=true, lambda=50, dct=4)
backward_vec_1 = MRecalculate(super_1, backward_vec, blksize=8, search=2, searchparam=1, dct=10)
forward_vec_1 = MRecalculate(super_1, forward_vec, blksize=8, search=1, searchparam=1, dct=10)
video.MSmoothFps(super_2, backward_vec_1, forward_vec_1, num=0, den=1, thscd1=248, thscd2=50, finest=F, algo=23, sadgamma=2, sadml=450, ml=0, blend=false)
GetMTMode(false) > 0 ? distributor() : last
Here's what it looks like in ffdshow video decoder configuration:
Edit, the above code is very slow, meaning it takes a lot of cpu. The code I will post below takes a lot less cpu and performs similarly to the above code:
Code:
setmtmode(5,0)
SetMemoryMax(512)
B = video
setmtmode(2)
SetMemoryMax(512)
super = B.MSuper(pel=2, hpad=12, vpad=12, rfilter=1, isse=true)
F = Video.MFinest(super)
backward_vec = MAnalyse(super, isb=true, search=2, searchparam=1, isse=true, lambda=90, dct=10)
forward_vec = MAnalyse(super, isb=false, search=1, searchparam=1, isse=true, lambda=90, dct=10)
backward_vec_1 = MRecalculate(super, backward_vec, blksize=8, search=2, searchparam=1, dct=10)
forward_vec_1 = MRecalculate(super, forward_vec, blksize=8, search=1, searchparam=1, dct=10)
video.MSmoothFps(super, backward_vec_1, forward_vec_1, num=0, den=1, thscd1=248, thscd2=50, finest=F, algo=23, sadgamma=2, sadml=450, ml=0, blend=false)
Super fast code would add block=true to the msmoothfps line, like this:
Code:
MSmoothFps(super, backward_vec_1, forward_vec_1, num=0, den=1, block=true, thscd1=248, thscd2=50, finest=F, algo=23, sadgamma=2, sadml=450, ml=0, blend=false)
You would use super fast version of msmoothfps if your cpu is too weak to play the video smoothly. But there may be blocks though if your source is being upscaled.
There is new, and then you are new.
This is a moral of the bears and their cereal.
8:13 is offline
post #309 of 355 Old 05-09-2011, 02:35 AM
travolter's Avatar
thank you
travolter is offline
post #310 of 355 Old 05-09-2011, 04:16 AM
pacemaker's Avatar
Quoted: 30 Post(s)
have you tried MPC-HC and MadVR?
it produces excellent colour and a small amount of upscaling
if you use win7 though there is a problem with navigation on menus but if you have all your discs ripped as movie only you wont have a problem
post #311 of 355 Old 05-09-2011, 05:51 AM
i think im going to try madvr tonight. how does it work with onboard hd4200 graphics?
post #312 of 355 Old 05-09-2011, 08:49 AM
pacemaker's Avatar
Quoted: 30 Post(s)
i would say yes it will work
if you use Win7 you will need to follow this hack:
http://forum.doom9.org/showthread.php?t=159492
post #313 of 355 Old 05-11-2011, 08:50 AM
greg1292's Avatar
Quoted: 83 Post(s)
Liked: 27
8:13
Sucking me back with the new script! Can't wait to try it.
Living in the world of linux right now playing with all the
11.04 distro's. Smplayer,11.04, Nvidia drivers hard to
beat PQ wise.
Thanks for the new script.
greg1292 is offline
post #314 of 355 Old 05-12-2011, 06:02 PM
usabrian's Avatar
Just getting back into HTPC's for first time in 5 years. Used to be a pro and now I don't know jack.
Can someone tell me why when I go into media player classic and try to add external filters i do not show an option to add ffdshow? i have installed it and everything else per the instructions.
My other issue is that avisynth.dll does not show in the plug in folder I download from the sw kit and I am told to drag it to here C:\\Program Files (x86)\\AviSynth 2.5\\plugins? It's not in the plug in folder wtf?
Zed's dead baby, Zed's dead.
Guide to Internet Forum Posting: Posting and You
usabrian is offline
post #315 of 355 Old 05-13-2011, 03:16 AM
joeydrunk's Avatar
Quoted: 14 Post(s)
It's probably because you have a 64 bit of either ffdshow or mpc and a 32 bit of either ffdshow or mpchc.
joeydrunk is offline
post #316 of 355 Old 05-15-2011, 11:38 PM
usabrian's Avatar
bingo, thanks
usabrian is offline
post #317 of 355 Old 05-15-2011, 11:55 PM
joeydrunk's Avatar
Quoted: 14 Post(s)
bingo, thanks
Yo
post #318 of 355 Old 05-16-2011, 07:34 AM
Hawkson's Avatar
If I have win 7 64 bit, is there any disadvantage or advantage to using 32 or 64 bit of the players and filters etc? I read there are a few that aren't 64 compatible.
Can you upscale movies to 1080p AND use something like the SVP?
Hawkson is offline
post #319 of 355 Old 05-16-2011, 04:54 PM - Thread Starter
8:13's Avatar
Hi Hawkson, if you use the sw kit in the first post the codes I list should work fine.
And you could upscale and use svp but since I have a E6600 cpu only I can't test it very well so I don't list that.
To do that just check the resize box and set it up as shown in the first post.
I updated the interpolation post with a faster code. And the scene change shouldn't show the previous frame now.
If blend=true the previous frame is shown as a dull overlay picture when the scene changes.
8:13 is offline
post #320 of 355 Old 05-24-2011, 12:56 AM
nicknacc's Avatar
sorry for the noobish question but
is there a way to upscale in congruence with xbmc?
nicknacc is offline
post #321 of 355 Old 05-24-2011, 02:58 PM - Thread Starter
8:13's Avatar
I don't know. Google it and post your answer here.
8:13 is offline
post #322 of 355 Old 05-24-2011, 11:44 PM
nicknacc's Avatar
didnt really find anything, xbmc wiki said it can upscale upconvert. but it is to the level of ffdshow and all the codec stuff?
nicknacc is offline
post #323 of 355 Old 05-25-2011, 04:10 PM - Thread Starter
8:13's Avatar
I have a link to some test disks in the first post. Burn one and test it on ffdshow on your computer and then on the xbox media centre.
You want to see the dots in the wavy lines clearly defined, and the picture to look crisp.
http://forum.doom9.org/showthread.php?t=140747
http://www.mediafire.com/?xfetd323l42dqcm
I don't own a xbox, but the ffdshow works better than the ps3 upscaler in the tests I did way back when.
I just did another test on my ps3 and will post the result picture.
Notice there are no defined dots in the wavy lines, hence much detail is lost, making the picture like jpeg blu ray instead of bmp blu ray.
8:13 is offline
post #324 of 355 Old 11-20-2011, 05:21 AM
thalaivar's Avatar
Can you post the links to your builds again. The links containing your builds on mediafire are broken or no longer exist.
Will try to do this on a Phenom II X4 830 8GB RAM Windows 7 64-Bit Home Premium system and report back the results.
Many thanks for your efforts.
thalaivar is offline
post #325 of 355 Old 12-08-2011, 09:05 PM
jenielsen's Avatar
Originally Posted by thalaivar View Post
8:13,
Any words of wisdom (aka were you able to get it working)?
jenielsen is offline
post #326 of 355 Old 12-29-2011, 03:57 PM
avsscientist's Avatar
Great post, just wondering how much of these settings are compatible with mkv 720p TV show files to be upscaled to 1080p?
avsscientist is offline
post #327 of 355 Old 12-31-2011, 08:16 AM
rinorho's Avatar
Good question!
How we can set-up the software/scripts to playback DVD and Blu-ray disc?
thanks
bye
rinorho is offline
post #328 of 355 Old 01-14-2012, 06:30 AM
ymc
ymc's Avatar
The link to sw kit is invalid now. What can I do??
ymc is offline
post #329 of 355 Old 02-02-2012, 10:25 PM
onatah's Avatar
I was wondering the same.
I tried downloading avisynth + some plugins (especially MT) from around the internet, but for a nebie all the different versions are quite confusing
//edit: Is it true that MT is integrated in avisynth 2.6ß (found some mention of it in some old doom9-thread)
Would be nice to have a package with wich to start or at least some links to avisynth and plugins that actualy work together.
onatah is offline
post #330 of 355 Old 03-01-2012, 10:38 PM
peter caesar's Avatar
Dear 8:13,
Used to be an FFDshow lover for years, I ditched DVD and went with Blu-Ray for the simplicity of playing back four years ago. Eventually I miss the passion once dominating my leisure hours with FFDshow + DVD. I'm planning to build a new HTPC, and thinking it's right time to give FFDshow another shot.
My question is, should I go with Intel i-3 dual-core 2100, or should I go with i-5 quad-core 2500k? IIRC FFDShow won't support Hardware acceleration if any filter kicks in, when we upscaling DVD CPU raw power used to be the only factor we should concern. On the other hand, will FFDShow benefit from the extre two-core of i-5 CPU, since very few codec acutally support multi-core.
And shoud I go with Z68 MB with onboard Graphic chip, or a H67 MB and a separate Graphic card?
Any suggestion are expected and appreciated.
peter caesar is offline
Reply Home Theater Computers
