Totally reset Windows 7 Media Center? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-29-2009, 08:40 AM - Thread Starter
curiousmurf's Avatar
Just wondering if its possible to totally reset Windows 7 Media Center? or just reinstall Windows 7 Media Center without reinstalling windows 7 ?
I've tried the 'Run Setup Again' in the General/WMC Setup menu and also tried Control Panel/Programs and Features/Turn windows features on or off....but with both of these methods when I start W7MC again I can still see my previous settings eg...media library from previous set up.
curiousmurf is offline
post #2 of 4 Old 08-29-2009, 08:42 AM
<><'s Avatar
what exactly do you need to adjust?
Media Center is just a fancy gui for Windows Media Player 12, so if you need to make any changes to the actual library just make the changes in Media Player and they will reflect in Media Center...
<>< is offline
post #3 of 4 Old 08-29-2009, 09:20 AM - Thread Starter
I was having problem playing media files with audio encoded in ac3. I tried installing AC3Filter then later on tried Shark007's codec packs...in the end it still not working. I'd like to find a way to 'reset' W7MC so that it is easier to troubleshoot problems.
Also, my media library span multiple local pc and sometimes W7MC seem very sluggish updating the various sources. It would be faster for me to reset W7MC and set up new library then to wait for it to update...
post #4 of 4 Old 09-06-2009, 06:24 AM - Thread Starter
Reply Home Theater Computers
