New heatpipe and fanless HTPC case designs - Page 5 - AVS Forum | Home Theater Discussions And Reviews
post #121 of 132 Old 01-06-2011, 12:34 AM
lymzy's Avatar
Originally Posted by BizarroTerl View Post
I've been considering one, but not having a list of currently available MBs is a stumbling block. Most MB mfgrs don't give detailed dimensions so getting a MB that fits is a bit of a crap shoot.
I only list the board I have personally tested so far as compatible.
You could check http://www.hd-plex.com/compatibility.html
Rule of thumb is that if nothing is blocking the heatpipe path, most mini-ITX and microATX should work with the heatsink sytem.
I will expand that list soon.
HDPLEX
lymzy is offline
post #122 of 132 Old 01-11-2011, 08:19 PM
BizarroTerl's Avatar
Quoted: 38 Post(s)
Liked: 46
I tried to register at the hdplex site. It gives me an error:
Please make sure you properly filled in all the required fields!
even if I enter info in all the fields.
BizarroTerl is offline
post #123 of 132 Old 01-12-2011, 09:46 AM
sriramc's Avatar
Im interested in the H5 case. Is it possible to fit a 3.5" and a 2.5" HDD along with an 5.25" optical drive? Maybe some velcro on top of the 3.5" to stick the 2.5" HDD?
My windows 7 media center http://www.hellosri.com
sriramc is offline
post #124 of 132 Old 01-13-2011, 11:50 AM
lymzy's Avatar
The H5.SODD will support 1xSSD,1x3.5HDD, and slim 12.7mm slot loading optical drive. It could also support 3xSSD(no 3.5HDD).
The H5.ODD won't be released since it would have to sacrifice internal PSU placement, SSD position, expansion card for a 5.25" ODD.
HDPLEX
lymzy is offline
post #125 of 132 Old 01-13-2011, 11:55 AM
Quoted: 38 Post(s)
Liked: 46
I'm very interested in the H3.S. I use XBMC/Linux and pretty much need Nvidia for the GPU. Does anyone know of a MB that'll fit that has a NVidia GPU?
post #126 of 132 Old 01-26-2011, 10:55 AM
gene1138's Avatar
Quoted: 13 Post(s)
Any idea when the H10 or H5 cases will be available? I'm very interested in redoing my HTPC to make it virtually silent. These cases look to be the perfect solution.
gene1138 is offline
post #127 of 132 Old 02-25-2011, 03:57 PM
Ayreon's Avatar
Silent PC Review has a review up now, but honestly I'm starting to lose patience. Is there ANY time frame at all when we can expect these cases to finally be available for purchase?
Ayreon is offline
post #128 of 132 Old 02-25-2011, 10:32 PM
lymzy's Avatar
H5.S is in stock now.
HDPLEX
lymzy is offline
post #129 of 132 Old 02-25-2011, 10:51 PM
mikinho's Avatar
That is great news Larry.
I also agree w/ your responses to the SPCR quibbles on the H10. The review was great, as expected from SPCR, but I felt each would take away from my own personal appeal on the H10.
As evident by my review of the H10, I'm a big fan of the minimalist front-plate and the symmetry in the heat-sink fins. I also like having the PSU secured within the chassis to reduce cable clutter. To each their own though.
mikinho is offline
post #130 of 132 Old 02-26-2011, 10:47 AM
cburbs's Avatar
Quoted: 94 Post(s)
I inquired about the H5.ODD Fanless Chassis last night. Is it available?
Anyone know of any other case ideas that fit in the audio rack that look similiar?
This isn't for an HTPC but Vortexbox.
"You’re KILLIN’ ME Smalls! "
Sony 55EX500 Settings
cburbs is offline
post #131 of 132 Old 05-20-2011, 12:58 AM
hungarianhc's Avatar
Any word on the H5.SODD? I don't see it on the website, but this is exactly the configuration I need. It looks like there is room for one card there, and I'm going to need the Ceton InfiniTV 4 to fit... It will fit right? THANKS!
hungarianhc is offline
post #132 of 132 Old 12-23-2011, 07:25 AM
fphredd's Avatar
Just a quick shout out to Larry at HD-Plex. Without going into the details (though there was never a real 'problem') Larry is a rare business person these days as he has provided a level of customer service to me that can only come when you truly care about the people buying and using the product.
Thanks!!!
"When the going gets weird, the weird turn pro." - HS Thompson
fphredd is offline
Reply Home Theater Computers
