Movies with forced subtitles - Page 19 - AVS Forum | Home Theater Discussions And Reviews
 17Likes
post #541 of 914 Old 04-20-2013, 09:46 AM
Mike Duffy's Avatar
Ditto - Thanks Scott.
I love this thread guys, great work.
Nethawk likes this.
Mike Duffy is offline
post #542 of 914 Old 04-20-2013, 10:31 AM
shortcut3d's Avatar
Quoted: 21 Post(s)
Liked: 29
Originally Posted by Stryker412 View Post
Anyone know if Red Dawn or Django have any forced subs?
Red Dawn 2012 has a few hardcoded subtitles for Chinese language. Thus, there is not an english subtitle file for foreign language parts.
shortcut3d is offline
post #543 of 914 Old 04-24-2013, 08:37 AM
itznfb's Avatar
Liked: 58
Anyone have more info on Black Hawk Down? The spreadsheet says they are burned in but I don't have any in my rip.
Running Windows Home Server 2011 Evil Abandoned Edition
itznfb is offline
post #544 of 914 Old 04-24-2013, 09:17 AM
Killroy's Avatar
Quoted: 21 Post(s)
Liked: 64
Mine is burned in but there are several different versions out there. I think mine is the Nordic version...but don't remember.
Killroy is offline
post #545 of 914 Old 04-27-2013, 05:12 PM
space2001's Avatar
Quoted: 65 Post(s)
Liked: 37
Anyone know anywhere I can grab the Alien speaking part for the orginal stargate blu-ray. They didn't seperate the english track from the alien and there is no forced.
space2001 is offline
post #546 of 914 Old 04-27-2013, 08:54 PM
space2001's Avatar
Quoted: 65 Post(s)
Liked: 37
another thing anyone know how to find the sub track number in makemkv. in the googledocs it tells me the track but in MakeMkv it doesn't show the track #
post #547 of 914 Old 04-27-2013, 10:36 PM
Killroy's Avatar
Quoted: 21 Post(s)
Liked: 64
Did you try here: http://subscene.com/subtitles/stargate
As far as I remember, there were no forced subs on that disk. It was all or none. Some of us created custom subs from the full subs.
Killroy is offline
post #548 of 914 Old 04-28-2013, 12:30 AM
nabsltd's Avatar
The 15th Anniverary Blu-Ray has hardcoded subtitles. Not every piece of alien speech has a corresponding hardcoded subtitle, though.
It's really cheap (less than $9), and is worth it as an upgrade to the older "Extended Cut" Blu-Ray (which is what I assume you have). The video and audio quality are much better, and there are all the extras ever issued on any previous release.
nabsltd is offline
post #549 of 914 Old 04-28-2013, 12:59 PM
space2001's Avatar
Quoted: 65 Post(s)
Liked: 37
How did you go about doing this.
post #550 of 914 Old 04-28-2013, 01:07 PM
Killroy's Avatar
Quoted: 21 Post(s)
Liked: 64
Creating customs subs is not that hard. Find the actual subs you need (from either the PGS subs already on the disk or the ones on that link) and their timecodes, create an .srt text file, if you want to keep it as SRT then you are done. If you want them as PGS then you will need to convert them to PGS using EasySUP. You can also reposition the subs using BDSup2Sub.
If I remember correctly, there are not that many alien subs in the original...should take you about an hour or two.
Killroy is offline
post #551 of 914 Old 04-28-2013, 01:53 PM
ScottJ's Avatar
Quoted: 296 Post(s)
Liked: 152
I have that disc and the alien subs are in a separate track which needs to be forced on.
ScottJ is offline
post #552 of 914 Old 04-28-2013, 02:16 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
You can use mkvMerge to mux the subs into the mkv.
Sammy2 is offline
post #553 of 914 Old 04-28-2013, 06:26 PM
Killroy's Avatar
Quoted: 21 Post(s)
Liked: 64
I think the very first edition Blu-ray was authored incorrectly and they put the alien/foreign subs only in the full subs...or none at all. Either way, it was a bad disk.
Killroy is offline
post #554 of 914 Old 04-29-2013, 11:27 AM
ScottJ's Avatar
Quoted: 296 Post(s)
Liked: 152
So even playing the original disc in a BR player, the forced subs weren't right?
ScottJ is offline
post #555 of 914 Old 04-29-2013, 11:31 AM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Yes. So head on over to subscene and grab the one you need then mux it back into your mkv.
Sammy2 is offline
post #556 of 914 Old 04-29-2013, 01:36 PM
Killroy's Avatar
Quoted: 21 Post(s)
Liked: 64
I had to go research this again but it seems that the first edition from Lionsgate (circa mid-2006) had missing subs for the aliens and the natives. Lionsgate re-issued the disk and corrected the subs but from I was reading, they were very low quality. Basically, there were no subs to begin with so there was nothing you could do with the original disk other than finding external ones and synching them.
Killroy is offline
post #557 of 914 Old 05-29-2013, 05:56 PM
space2001's Avatar
Quoted: 65 Post(s)
Liked: 37
Thanks guys was able to get them.
One question I am ripping my season 2 of 24 (DVD)and see that in VLC it is playing subtitle Track # 9.
Is there a way to See the track # in MAKEMKV?
or is there another way to find out.
post #558 of 914 Old 05-30-2013, 02:13 PM
Polemides's Avatar
+1.
Thanks especially for the ClownBD wiki entry, Scott. I've been struggling to get The Avengers rip just how I wanted it, but thanks to you I've got it.
Polemides is offline
post #559 of 914 Old 05-30-2013, 03:12 PM
ScottJ's Avatar
Quoted: 296 Post(s)
Liked: 152
Originally Posted by Polemides View Post
+1.
Curious how you wanted it? Avengers was one of the tricker ones for me to get how I wanted it. It's mentioned in the "Extremely anal" section but I didn't go into details there.
ScottJ is offline
post #560 of 914 Old 05-30-2013, 10:22 PM
Polemides's Avatar
Nothing fancy. I just wanted it to play the Russian part when I started the movie in J. River without having to manually activate the "separate" sub track. Perhaps I should have said, "Gotten it to work" instead of "how I wanted it."
One of the good things about J. River playback is that it will remember your playback selections so it would always play back the correct subtitle track (12, in this case) once you've selected it. The problem with this is I have a 3 client setup, so you'd have to do that on every machine. And in the event of a windows re-install, complete wipe of the program, library re-load, etc. you'd be back with no subs. And then if my wife wanted to watch it from her office/kids playroom I get the dreaded, "Honey, how do I turn on subtitles in J. River again???"
So you see you've saved me some grief.
post #561 of 914 Old 06-03-2013, 06:45 PM
LouV68's Avatar
Very useful thread. Thank you.
LouV68 is offline
post #562 of 914 Old 06-23-2013, 07:45 PM
288enzo's Avatar
Hi all,
Has anyone had luck with the Spanish speaking parts that start at 1:06:08 in Broken City? Using eac3to I only see one english subtitle track, and using both SupRip and BDSup2Sub511 I don't get any forced subtitles. I know they exist, in the complete subtitles you can see [Billy Speaks in Spanish] then the subtitle, but it's as if I either get the entire subtitles or nothing.
288enzo is offline
post #563 of 914 Old 06-28-2013, 09:24 PM
melinda's Avatar
Hi there , I'm not really that great with technology but I downloaded a movie . Finally got a copy with subtitles on to my USB . The subtitles work fine on my laptop but they don't show up on my Panasonic tv ? Any advice ? Is there something I need to change on my tv ? I know you can link your laptop to the tv but I would prefer just to use the USB ?? Thanks for any advice
melinda is offline
post #564 of 914 Old 06-28-2013, 09:54 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
You "ripped" a movie right?
Now that that is out of the way, what is the container of the movie (mkv, mp4)? How is the laptop connected to the TV?
Sammy2 is offline
post #565 of 914 Old 07-11-2013, 04:09 PM
BryanCPA's Avatar
The US blu-rays of Live Free or Die Hard and Dead Man Down have forced subtitles. I don't remember the track numbers.
BryanCPA is offline
post #566 of 914 Old 07-14-2013, 10:33 AM
Mike Duffy's Avatar
I can't tell from the spreadsheet if the "new" Star Trek movie has forced subs. It's been a while since I've watched it and I'm pretty sure it doesn't have them, but there is no date on the spreadsheet to verify. Anyone know off hand if the Star Trek made in 2009 has subs?
post #567 of 914 Old 07-14-2013, 11:22 AM
dbone1026's Avatar
Quoted: 216 Post(s)
Liked: 110
No forced subs for that movie
Cheers,
Damian
MSS.net blog (contributing editor) - http://www.mediasmartserver.net
Windows Entertainment and Connected Home MVP 2010-2012
dbone1026 is offline
post #568 of 914 Old 07-14-2013, 04:00 PM
Mike Duffy's Avatar
ty
post #569 of 914 Old 07-22-2013, 04:08 PM
Wireless member
pepar's Avatar
Quoted: 911 Post(s)
Liked: 502
I am researching subtitles and ripping, and that has lead me here. Post #19 of this thread, a member posted "That's why I always rip all English subs then run them through BDSupToSub to preserve only the forced. Works like a charm." Is that still good advice? Or do I need to research each title I rip (spreadsheet, Subscene, etc) and select accordingly? Tools are AnyDVD HD and Clown BD (the whole enchilada).
Also, I just discovered Scott's "Forced subtitles with ClownBD" wiki and have that yet to wade through ...
Jeff
"The future is already here, it's just not evenly distributed." W. Gibson
"I like the future, I'm in it." F. Theater
pepar is offline
post #570 of 914 Old 07-22-2013, 04:31 PM
ScottJ's Avatar
Quoted: 296 Post(s)
Liked: 152
The only 100% reliable way I've found is to rip all English subs and look at each of them with BDSup2Sub. I now do this for every rip. It's a minor PITA but it's the only way to be sure about what needs to be ripped.
I look for three things:
1. Are there any subs flagged as forced? Those will almost surely need to be forced on. (Exception: some Star Wars discs with forced subs on the commentary tracks.)
2. Are there any whole sub tracks that might need to be forced? Applies to foreign language movies, mostly.
3. Are all subs within the picture area? Important for CIH setups.
ScottJ is offline
Reply Home Theater Computers
