Movies with forced subtitles - Page 28 - AVS Forum
 6Likes
post #811 of 830 Old 10-28-2014, 02:41 PM
ScottJ's Avatar
Quoted: 127 Post(s)
Liked: 77
Originally Posted by G1Nger View Post
May I ask what TLC you use with ClownBD? Does Clown support 3D BDs? I haven't used it very long and maybe am missing something in the setup. Also, I didn't think it would "shrink" the output size as does BDREBUILDER to fit on a 25GB disc but again I'm not that familiar with the software. Yes to your questions above. My issue lies strictly with a standard Bluray player and burned Movie Only ISO - the separate sub track does not turn on automatically. Thanks for your help.
I'm not sure about 3D support in Clown. It doesn't recompress, though you might be able to use only pieces of it to get what you need.
If you run the Clown gui in batch mode, it generates a *.bat file which you can peruse and edit, and a meta file for tsmuxer. In the no-recompression case, you would need to rename the proper sub file to add _FORCED to the name, like: Subtitles_5_English_FORCED.sup
Then edit the meta file to match. Clown will see that special filename and (in a step following remux and before imgburn) modify the BDMV code to force on that subtitle track.
I'm not sure how BDREBUILDER creates an iso file. If there's an intermediate step just before the iso is created, you could run this Clown step to modify the BDMV code. But if the iso is created all in one step, it might be too late. Somehow you would need to modify the files within the iso. I'm sure that's possible I just don't know how.
More disorganized thoughts on forced subs on my wiki.
ScottJ is online now
post #812 of 830 Old 10-30-2014, 01:41 PM
G1Nger's Avatar
Deliver us from Evil has 4 forced subs embedded into the 2nd English PGS stream (CDN BD) I demuxed using tsmuxergui then used bdsup2sub to check the streams and then extracted the forced subs. I then remuxed the files including the exported forced sub stream to BD ISO format but the subs didn't show up when I played the ISO on my media player. I find this strange because I used the same process on Transformers Age of Extinction where the subs are also embedded as forced in one of the English streams and they played just fine. Why do some play and others don't? Anyone else have these issues with subtitles or is it just me??
G1Nger is offline
post #813 of 830 Old 10-30-2014, 02:32 PM
ScottJ's Avatar
Quoted: 127 Post(s)
Liked: 77
I don't know what the difference might be, but extracting the forced subs to their own track is insufficient for a BD-ISO. There is also some BDMV code required to turn on that track. ClownBD calls this step "Force_Subtitles" in its generated batch file.
This assumes your media player supports full BD-ISO and will follow the instructions in the BDMV. If it supports only "BD-Lite" then I'm not sure how it would support forced subs.
post #814 of 830 Old 10-30-2014, 02:52 PM
hifiaudio2's Avatar
Quoted: 157 Post(s)
Liked: 76
Originally Posted by steelman1991 View Post
MakeMKV is unable to rip the correct audio for the new Transformers movie, due to the addition of the Dolby Atmos track - you will only get core Dolby Digital, until the author updates the code.
You guys probably know this by now, but MakeMKV now supports Atmos and the Transformers disc. It also extracts the forced sub track properly.
hifiaudio2 is online now
post #815 of 830 Old 10-30-2014, 03:00 PM
G1Nger's Avatar
I'm going to try the ClownBD option mentioned above. I'll try MakeMKV as well. I found my media player seems to skip the first forced sub for some reason with MakeMkV that's why I moved to the ISO format but it's clear there must be some code that controls turning on the forced subs. I guess I got lucky with my Transformers Age of Extinction BD Disc.
G1Nger is offline
post #816 of 830 Old 10-30-2014, 03:16 PM
hifiaudio2's Avatar
Quoted: 157 Post(s)
Liked: 76
Do you have the Mede8er x series? I had that as well and the first sub skipping was too annoying so I quit using it. I use a Dune Smart D1.
post #817 of 830 Old 10-31-2014, 04:25 AM
G1Nger's Avatar
I have a KDLinks 720HD. It's good but like all media players it has its quirks.
G1Nger is offline
post #818 of 830 Old 11-21-2014, 07:39 AM
djc11369's Avatar
I extract the subtitles using ClownBD and then use BDsup2sub to detect and extract the forced subs while exporting to SUB/IDX from PGS. I then remux using MKVmerge and check the forced flag at the same time (whether it will have any benefit by checking in the future or not I'm not sure). Solved the Mede8er MKV problem with PGS subtitles for me although a few more steps.
djc11369 is offline
post #819 of 830 Old 11-21-2014, 02:04 PM
STxFarmer's Avatar
Inseparable (2012) has forced subs and didn't see it on the list or in this thread. MakeMKV pulled them but I had to edit the header with MKVmerge to turn the forced flag on. Played perfect after that.
Harsh Times (2005) was another find
Rain Fall (2009) scattered all throughout movie
Seal Team Six The Raid on Osama Bin Laden (2012) scattered all throughout movie
Shanghai (2010) scattered all throughout movie
The Double (2011)
The Ramen Girl (2008) scattered all throughout movie
Thanks for the list Great tool
STxFarmer is offline
post #820 of 830 Old 11-21-2014, 06:47 PM
Larry M's Avatar
Quoted: 23 Post(s)
Liked: 44
Does anyone know if the new Godzilla has subtitles?
Larry M is offline
post #821 of 830 Old 11-21-2014, 06:55 PM
ScottJ's Avatar
Quoted: 127 Post(s)
Liked: 77
The US BD has none.
Larry M likes this.
post #822 of 830 Old 11-21-2014, 09:04 PM
Larry M's Avatar
Quoted: 23 Post(s)
Liked: 44
Originally Posted by ScottJ View Post
The US BD has none.
Larry M is offline
post #823 of 830 Old 12-08-2014, 01:09 AM
Liked: 0
Hi
I've been using your wonderful sheet, on and off, for a lonfg time. After a HD crash I'm having to re-do lots of films. I've got the the original Star Wars trilogy, and I am sure that there was a reference in your sheet about (what is know known as) A New Hope. Yet that record seems to be missing now.
Have they been removed?
Eserim
eserim is offline
post #824 of 830 Old 12-09-2014, 09:39 AM
STxFarmer's Avatar
Here is another list
https://docs.google.com/spreadsheet/...UE&hl=en#gid=0
post #825 of 830 Old 12-09-2014, 10:47 AM
Liked: 0
Ah, that's better - many thanks - did I miss where it was changed? No matter.
eserim is offline
post #826 of 830 Old 12-09-2014, 07:36 PM
dfkimbro's Avatar
Quoted: 55 Post(s)
Liked: 47
Did you look on page 2 of the spreadsheet? I see Star Wars: Episode IV - A New Hope listed there.
dfkimbro is offline
post #827 of 830 Old 12-10-2014, 01:08 AM
Liked: 0
All OK on the recent link - can't see on the original sheet from post 1 - that one appears quite vandalized.
eserim is offline
post #828 of 830 Old 01-06-2015, 03:27 AM
Liked: 0
Hi,
BDtoAVCHD also does a good job identifying forced subtitles (see attached screenshot).
jogal is offline
post #829 of 830 Old 01-06-2015, 06:14 AM
Larry M's Avatar
Quoted: 23 Post(s)
Liked: 44
Originally Posted by jogal View Post
Hi,
Welcome to the forum
Larry M is offline
post #830 of 830 Old 01-07-2015, 09:44 AM
MyMojo's Avatar
Liked: 0
Been using the spreadsheets, as I have over 1600 DVDs and BDs that I'm converting for my home media server. I just wanted to give a HUGE Thank You to Stryker and the rest of you for doing this. What a great project this is!
MyMojo is offline
Reply Home Theater Computers
