Movies with forced subtitles - Page 29 - AVS Forum | Home Theater Discussions And Reviews
 7Likes
post #841 of 863 Old 02-22-2015, 12:12 PM
Killroy's Avatar
Quoted: 13 Post(s)
Liked: 64
If you want to see really fancy use of PGS subs as part of the video check out "You Don't Mess with the Zohan" (2008). They use PGS subs to show the HUD on a pair of night vision glasses. They load from the top of the screen about middle of the HUD. Only time I have seen PGS subs to do this.
Killroy is offline
post #842 of 863 Old 02-22-2015, 01:46 PM
G1Nger's Avatar
Theory of Everything has subs for the French speaking doctor - hospital scene.
G1Nger is offline
post #843 of 863 Old 02-23-2015, 06:38 PM
robnix's Avatar
Quoted: 315 Post(s)
Liked: 363
Hardcoded, not forced.
Looky here!
robnix is online now
post #844 of 863 Old 02-25-2015, 11:45 PM
Liked: 0
Originally Posted by Killroy View Post
Here are some others that I found:
  • The Mummy
  • The Mummy Returns
  • The Rundown
  • Dragon Wars
  • Paprika
  • The Professionals
  • Che Part 1 & 2
  • The International
  • Grand Torino
  • Defiance
  • Immortel
  • Hannibal Rising (only one caption)
  • Star Trek VI
  • Star Trek V
  • Star Trek III
  • Star Trek
  • Persepolis
  • Da Vinci Code
  • Mean Girls
  • Babylon A.D.
  • The Eye
  • Blindness
  • Dance With Wolves
  • Bangkok Dangerous
  • Pathfinder
  • The Legend of Zorro
  • The Mutant Chronicles
  • The Mummy Dragon Emperor
micagordon is offline
post #845 of 863 Old 04-20-2015, 07:15 PM
BDestroyer8418's Avatar
When you need to update the header info for a subtitle not playing which one do I edit.
Default track - no
Track enabled - blanked out unless I select add element
forced display - same as above
Do I just changed Default track -Yes ?
* I changed to Yes seems to work. What would the other 2 be used for.
BDestroyer8418 is offline
post #846 of 863 Old 04-21-2015, 04:24 AM
robnix's Avatar
Quoted: 315 Post(s)
Liked: 363
Default track - no
I change mine to Forced = yes, Default = yes. Seems to do the trick.
Looky here!
post #847 of 863 Old 04-22-2015, 12:26 AM
ScottJ's Avatar
Quoted: 167 Post(s)
Liked: 89
The US BD of Everly has forced subs for Japanese spoken parts. It's a separate track and ClownBD doesn't pick it up at all.
ScottJ is offline
post #848 of 863 Old 04-29-2015, 04:53 AM
robnix's Avatar
Quoted: 315 Post(s)
Liked: 363
Are you sure? They may be hardcoded. I'll find out for sure today.
Looky here!
post #849 of 863 Old 04-29-2015, 07:55 PM
speedoflight's Avatar
They're not hard coded and they are not really forced subs. The first sub track is only the Spanish and Japanese subs.
speedoflight is offline
post #850 of 863 Old 04-30-2015, 04:43 PM
robnix's Avatar
Quoted: 315 Post(s)
Liked: 363
MakeMKV 1.9.2 misses them as well, but Sub Track 5 is the correct track, and you're correct, it's not marked as a forced track.
Looky here!
post #851 of 863 Old 05-19-2015, 01:33 PM
Brajesh's Avatar
Quoted: 206 Post(s)
Liked: 80
Any forced subs in 'American Sniper'?
HD Media Keen Videosaurus
Brajesh is offline
post #852 of 863 Old 05-19-2015, 09:16 PM
robnix's Avatar
Quoted: 315 Post(s)
Liked: 363
None ripped by MakeMKV.
Looky here!
post #853 of 863 Old 05-20-2015, 04:11 AM
Brajesh's Avatar
Quoted: 206 Post(s)
Liked: 80
It appears no forced subs, though MakeMKV isn't reliable in this regard.
Brajesh is offline
post #854 of 863 Old 05-21-2015, 05:11 PM
alex014's Avatar
I am hoping somebody can help me with the Iron Man and Avengers bluray. I am having 2 different problems. With Avengers I can not get the forced subtitles to work. I manually set the flag to forced using MKV merge. However the subtitles will not play using MPC-HC or Kodi. Am I missing something? Other MKVs play properly so I do not think its the players. With Iron Man the subtitles play for the scene in the caves but not later when the terrorists are in the village around the 1:16 mark. I am completely at a loss for that one. Any help would be appreciated.
alex014 is offline
post #855 of 863 Old 05-22-2015, 01:07 AM
steelman1991's Avatar
Quoted: 61 Post(s)
Liked: 87
Like you I doubt its the players - particularly as other files are rendering correctly. My guess would be that the rip hasn't pulled the subs correctly, perhaps something corrupt the process. I would try a re-rip of those particular titles.
steelman1991 is online now
post #856 of 863 Old 05-23-2015, 05:03 AM
alex014's Avatar
I tried reripping iron man and still no luc. the track is there and it is tagged forced. MPC also identifies it as forced it just doesn't play properly. Are thrre any settings I am missing? I also set the track as default. Should I change this?
alex014 is offline
post #857 of 863 Old 05-23-2015, 11:10 AM
Quoted: 61 Post(s)
Liked: 87
What programme are you using to rip?
post #858 of 863 Old 05-23-2015, 11:44 AM
alex014's Avatar
I usually use makemkv but this time I demuxed it with clown bd and put it back together with mkvmerge
alex014 is offline
post #859 of 863 Old 05-23-2015, 12:00 PM
Quoted: 61 Post(s)
Liked: 87
Do you still have the demuxed sub file - if so you could check it in BDSub2Sub and see whether the sub is being ripped correctly.
post #860 of 863 Old 05-23-2015, 12:21 PM
alex014's Avatar
I did that and everything seems correct. Also when I play the movie in both mpc and kodi the subtitles will appear if I enable that subtitle track so I think the track ripped correctly. However it seems the forced option is somehow not being applied properly.
alex014 is offline
post #861 of 863 Old 05-23-2015, 12:35 PM
Quoted: 61 Post(s)
Liked: 87
If you want to upload a small sample (somewhere) I'll be happy to test using both kodi and MPC - see if the results are the same, otherwise I'm out of ideas (I use Kodi and certainly don't have any playback/sub rendering issues).
post #862 of 863 Old 05-23-2015, 01:02 PM
alex014's Avatar
Thanks for your help. I may take you up on your offer. I am going to try re ripping the avengers again and see if I have better luck. Honestly part of me is over the htpc thing.I spend more time tinkering than watching the movies lol.
alex014 is offline
post #863 of 863 Old 05-24-2015, 11:56 AM
Pain Infliction's Avatar
Quoted: 773 Post(s)
Liked: 374
Is the list on the first page up to date or updated every once in a while? I assume it is since Taken 3 is on it, but just wanted to know if I should go by that list or try and find another list elsewhere. Thanks!
Pain Infliction is online now
Reply Home Theater Computers
