Movies with forced subtitles - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 15Likes
post #61 of 913 Old 01-03-2010, 09:16 PM - Thread Starter
Stryker412's Avatar
Liked: 24
The Bourne movies all have the subtitles burned into the video track already. There's no need to do anything.
Stryker412 is offline
post #62 of 913 Old 01-03-2010, 09:26 PM
MikeEby's Avatar
Originally Posted by Favelle View Post
So what do we have to do with those ones?
When you see an english sup file that is much smaller than other english sup that's a dead ringer...In my GUI I look for one that's 1/20 the size of the others. The newer version of eac3to may catch it in the logs...There was something in the release notes about that. I should try re-ripping Gran Torino and see.
Mike
MikeEby is offline
post #63 of 913 Old 01-03-2010, 09:42 PM
Klutzy's Avatar
I'm working on backing up the Bluray versions now and the "forced captions" did not automatically show up. What software did you use to rip/encode?
Klutzy is offline
post #64 of 913 Old 01-03-2010, 09:46 PM
kegobeer's Avatar
Mike
Yeah, the latest ea3to gives the total number of subtitles in the log, like this:
Subtitle track 10 contains 1160 captions.
Subtitle track 11 contains 53 forced captions.
Subtitle track 14 contains 1382 forced captions.
Subtitle track 15 contains 85 captions.
kegobeer is offline
post #65 of 913 Old 01-04-2010, 04:15 AM
Rigby Reardon's Avatar
Those are the tricky ones to catch...Gran Torino was the same way...I think it's a Warner Brothers thing...They still like VC-1 encoding too.
It has nothing to do with Warner. The studios do this mostly for multi-lingual discs, where you have several subtitle sets for the different languages. The use of "automatic" subtitles is very common on European discs. E.g., the European Bourne trilogy discs use subtitles (translated to the playback language) for the location captions, whereas on the US versions the captions are burned into the video.
Rigby Reardon is offline
post #66 of 913 Old 01-04-2010, 05:15 AM
JonnySak's Avatar
You can add this:
Snatch - Subtitles_8_English_FORCED
JonnySak is offline
post #67 of 913 Old 01-04-2010, 07:50 AM - Thread Starter
Stryker412's Avatar
Liked: 24
AnyDVD-HD to rip and Ripbot to encode.
Mike you releasing a new version of AEAC3? I still have that beta copy you sent me.
post #68 of 913 Old 01-05-2010, 07:10 AM
shanecole's Avatar
Night at the Museum 2 has some forced subtitles.
shanecole is offline
post #69 of 913 Old 01-05-2010, 08:19 PM
shanecole's Avatar
The Day the Earth Stood Still has a track which is very short and is subs for a few non english speaking parts.
Subtitles_12_English.sup
post #70 of 913 Old 01-06-2010, 01:00 AM
shanecole's Avatar
Seven Pounds has some forced english subtitles in the first sub track.
post #71 of 913 Old 01-06-2010, 06:55 AM - Thread Starter
Stryker412's Avatar
Liked: 24
I gave you access to the spreadsheet.
post #72 of 913 Old 01-06-2010, 04:35 PM
shanecole's Avatar
Thanks updated my finds as well as Snatch from JonnySak.
post #73 of 913 Old 01-07-2010, 11:33 PM
Favelle's Avatar
Does Eastern Promises really have forced subtitles because eac3to didn't catch them....
In terms of LFE, size does matter!
Favelle is offline
post #74 of 913 Old 01-08-2010, 02:31 AM
Dill206's Avatar
the latest Rambo has forced sub's. Burmese soilders dialog.
Dill206 is offline
post #75 of 913 Old 01-08-2010, 07:51 AM
aeroutaF35's Avatar
Babel as quite a bit
aeroutaF35 is offline
post #76 of 913 Old 01-08-2010, 08:06 AM
aeroutaF35's Avatar
Originally Posted by merzbow View Post
That's why I always rip all English subs then run them through BDSupToSub to preserve only the forced. Works like a charm.
how does one go about doing this??
post #77 of 913 Old 01-11-2010, 09:33 PM
aeroutaF35's Avatar
Stryker412, do you plan on keeping this updated??
post #78 of 913 Old 01-12-2010, 04:54 AM - Thread Starter
Stryker412's Avatar
Liked: 24
Yes, Shane and I have been adding movies.
post #79 of 913 Old 01-12-2010, 05:14 PM
aeroutaF35's Avatar
what subtile output file format is needed when using BDSup2Sub to process the .sup file and MKVmerge to merge the video, audio, and subtile file created from BDSup2Sub.
post #80 of 913 Old 01-12-2010, 05:15 PM
Killroy's Avatar
Quoted: 21 Post(s)
Liked: 64
idx/sub
Killroy is offline
post #81 of 913 Old 01-12-2010, 05:30 PM
aeroutaF35's Avatar
i get an error
post #82 of 913 Old 01-12-2010, 06:21 PM
kegobeer's Avatar
i get an error
Your screenshot is too tiny for me to read any of the text. Here's what you do: rip all of the english subtitle tracks, then run each one through bdsup2sub until you find the one that has forced subtitles. Then, export only forced subtitles. Next, run mkvmerge, add the main movie, audio, and forced subtitle file on the input tab, add your chapters in the global tab, then start muxing.
kegobeer is offline
post #83 of 913 Old 01-12-2010, 08:27 PM
aeroutaF35's Avatar
I have tried adding the subtitle file on the input tab. But when i start muxing it errors and says
"Error: The file 'F:\\MKV Movie\\Seven Pounds\\1_6_subtitle_exp.xml' cannot be attached because it does not exist or cannot be read."
post #84 of 913 Old 01-12-2010, 08:30 PM
aeroutaF35's Avatar
sheesh.. i figured it out..i was making a silly error.
thanks for your help!
post #85 of 913 Old 01-12-2010, 08:58 PM
aeroutaF35's Avatar
well, not quite there yet. I was able to get mkvmerge to mux all 3 files however, no subs during playback. any suggestions??
post #86 of 913 Old 01-12-2010, 09:10 PM
Killroy's Avatar
Quoted: 21 Post(s)
Liked: 64
What player?
Killroy is offline
post #87 of 913 Old 01-13-2010, 06:45 AM
aeroutaF35's Avatar
Wmc
post #88 of 913 Old 01-14-2010, 07:22 AM
aeroutaF35's Avatar
any ideas why they may not show?? or are there any other threads which cover using BDSUp2Sub and MKVmerge? This seems like it should be a straight forward process.
post #89 of 913 Old 01-14-2010, 08:04 AM
Killroy's Avatar
Quoted: 21 Post(s)
Liked: 64
I don't use WMC for playback but it is usually the sub renderer that is the problem. With MPC-HC you either use the internal filter or an external one. Also have to allow the application to pre-load or auto load the sub while other filters do it on their own.
Killroy is offline
post #90 of 913 Old 01-14-2010, 10:42 AM
MikeEby's Avatar
Agreed...Others have gotten forced subs in WMC working, I'll be damned how? If someone has a step by step I would like to know how too. I've installed vobsub...what's the step after that?
Mike
MikeEby is offline
Reply Home Theater Computers
