ATI Radeon HD 5800, 5700 and 5600 Series Thread: Supporting HD Audio Bitstreaming! - Page 10 - AVS Forum | Home Theater Discussions And Reviews
Old 10-02-2009, 08:23 AM
SamuriHL's Avatar
I'm not sure if the results I'm getting with it are what's expected. I'm not getting bitstreamed audio, that's for sure. But I'm not sure what he's looking for in this test.
SamuriHL is offline
Old 10-02-2009, 08:26 AM
Tulli's Avatar
Quoted: 117 Post(s)
Liked: 102
Originally Posted by sanderdvd View Post
I think Albain (ffdshow dev.) and James (ReClock dev.) will beat TMT and will be able to present a ffdshow/reclock combination with both new versions that will make bitstreaming possible, maybe even for the 4XXX-series!
I would not be so sure as PAP, by definition, implies no standards, meaning a proprietary feature in the drivers only disclosed to the PAP SW partner.
I'd be very - HAPPILY! - surprised if ATI let a "PAP hole" be opened in their drivers.
EDID Overrides (capture, install/uninstall, troubleshooting)
Tulli is offline
Old 10-02-2009, 08:28 AM
SamuriHL's Avatar
What if you bitstream and ignore PAP?
SamuriHL is offline
sanderdvd's Avatar
Quoted: 164 Post(s)
Liked: 30
hmmm, too bad. well let s wait for beta9 then
Ill do some testing tonight btw.
sanderdvd is offline
Old 10-02-2009, 08:30 AM
SamuriHL's Avatar
Not sure if I'm doing something wrong on my end but I set it up like he said and I'm getting some screwy results.
SamuriHL is offline
Old 10-02-2009, 08:34 AM
sanderdvd's Avatar
Quoted: 164 Post(s)
Liked: 30
how did you config everything exactly and what card do you use?
Old 10-02-2009, 08:37 AM
SamuriHL's Avatar
I used the configuration he told us in that thread, and I have a 5870. I can't get it to work at all with ReClock in step 1. In step 2 I'm seeing the TrueHD track info just fine, but, output is set to S/PDIF and I get no audio at all. DTS-HD MA is seen as a 1536 Dolby Digital track and outputs core DTS to my receiver. LOL
SamuriHL is offline
Old 10-02-2009, 10:07 AM
Tulli's Avatar
Quoted: 117 Post(s)
Liked: 102
PAP -> bitstreaming (or PAP is the only way to bitstream).
If ATI has really implemented a PAP the only way to break it would be by gaining access to the particular proprietary functionality in the drivers/HW. This would include of course breaking in an encryption through a - also proprietary - "data bus" between the SW application and the drivers/HW. In two words, a "black box".
I'm really skeptical that it can be broken ... .
Tulli is offline
Old 10-02-2009, 10:10 AM
SamuriHL's Avatar
You of course are making an assumption that it can't be bypassed. LPCM, for example, can be sent without the need for PAP. It has been shown in the past that DTS, embedded in a wav file, for example, can be passed to a receiver and have it decode the DTS stream. The same type of approach is being taken here. They're trying multiple ways of embedding the raw TrueHD or DTS-HD MA track (AC3, PCM, etc) and passing it through to the receiver. So far it's not quite working, but, it's at least theoretically possible to do this.
SamuriHL is offline
Old 10-02-2009, 10:22 AM
Tulli's Avatar
Quoted: 117 Post(s)
Liked: 102
Yes, but that's all through directshow, i.e. standard interfaces, nothing to do with a proprietary PAP implementation.
Tulli is offline
Old 10-02-2009, 10:26 AM
SamuriHL's Avatar
Right. But, what I'm saying is that bitstreaming and PAP are NOT tied to each other from a technical stand point. To do it "properly" you do need PAP support which is never going to happen in an open interface. (Kind of defeats the purpose, no?) So for TMT3 or PDVD9 to support bitstreaming, they need official support in order to use the PAP. What they're trying to do with ffdshow, not so much, but, in the end if you can get the stream to the receiver so that it can decode it then you've sent unmolested audio which is bitstreaming in my book.
SamuriHL is offline
Old 10-02-2009, 10:39 AM
Tulli's Avatar
Quoted: 117 Post(s)
Liked: 102
Ok, but what I fail to see is "where" in that PAP black box you sneak in to get access to the native audio stream. You certainly won't have access to it through directshow (ffdshow). Or how?
Tulli is offline
Old 10-02-2009, 10:48 AM
SamuriHL's Avatar
To use PAP, you have to actively code for it. Again, LPCM can be sent without engaging PAP. I think you're under the mistaken belief that it's just "active" and watching what comes through. That'd be an incorrect assumption I think. It's simply a "requirement" that in order to be allowed to bitstream, *LICENSED* players are forced to use PAP. On a technical level, I don't think it's required to send data down the HDMI path. But again, if you couldn't send any data without PAP, NOTHING would play right now except for the non-released PDVD9. But we are able to use LPCM for many different things. Games, TMT3, etc. So, if he encodes a raw TrueHD or DTS-HD MA track inside PCM and sends that through, it should work assuming the receiver then recognizes it. Remember that PAP is only on the PC side of things. The receiver knows nothing about it at all nor does it care. Stand alone players bitstream without it just fine.
SamuriHL is offline
Old 10-02-2009, 10:49 AM
SamuriHL's Avatar
Oh, just so we're clear here, this will not work on encrypted streams. You'll need AnyDVD or whatever to decrypt it first before being able to bitstream. This is only to allow bitstreaming of unprotected sources. Maybe that's the confusion?
SamuriHL is offline
Old 10-02-2009, 11:05 AM - Thread Starter
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
renethx is offline
Old 10-02-2009, 11:10 AM
Tulli's Avatar
Quoted: 117 Post(s)
Liked: 102
Got it, thanks!
Tulli is offline
Old 10-02-2009, 12:33 PM
blackEyEz's Avatar
This article helped me some to understand PAP: http://www.anandtech.com/video/showdoc.aspx?i=3411&p=2
So PAP is a AES 128bits encryption. Does this mean that each Blu Ray has its own key which PAP uses and is verified by the HDCP to come full circle?
blackEyEz is offline
Old 10-02-2009, 12:38 PM
SamuriHL's Avatar
No. What's happening is the software (TMT3, PDVD9, whatever) has to be written to be able to encrypt the content as soon as AACS decryption is done using a key that the GPU inherently knows. Think of it something like PGP where you encrypt a message with a person's public key and the receiver then decrypts it with their private key. So the player encrypts the content, and as soon as it hits the GPU it's decrypted and sent over HDMI to your receiver. At least, that's the theory. Why this is really needed is beyond me. It's a freaking sick joke if you ask me.
SamuriHL is offline
Old 10-02-2009, 12:43 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 330
You don't, what if someone sniff's the PCIe bus and before we know it there will be uncompressed hi-res version of the audio to the movie Free Willie floating around.
Can you imagine what torrent sites would do with 24b/96khz audio soundtracks. I'm not sure the movie industry could survive it.
Joel Barsotti
SpectraCal
CalMAN Lead Developer
sotti is offline
Old 10-02-2009, 12:48 PM
SamuriHL's Avatar
I'm really hoping I'm catching the sarcasm here. Otherwise,
Yea, it just amazes me. It's ok to output 48/16 seemingly unprotected. But, 48/24 or heaven forbid 96/24, WOA there! Cause, you know, it's WAY too hard for someone to decrypt the disc and rip the unmolested content. Besides, if this was really such a huge issue, why not just keep the AACS protection as it's pass through the player and decrypt that on the GPU instead of creating yet another new standard? The industry just amazes me at times.
SamuriHL is offline
Old 10-02-2009, 01:07 PM
Andy o's Avatar
I'm not so sure that you need PAP to bitstream TrueHD and DTS MA in principle. Just for AACS content probably. That's what the IEC61937 option in ffdshow should do, no need to pack to PCM.
Andy o is offline
Old 10-02-2009, 01:09 PM
SamuriHL's Avatar
He's got a version that's trying to do that. I sent some debug info and he found an issue. So hopefully that gets fixed and maybe the next version we get a little further. The IEC header is being filled in correctly now, though, so, it's getting there. That was without ReClock in the picture.
SamuriHL is offline
Old 10-02-2009, 01:20 PM
Andy o's Avatar
Unfortunately that way, the "correct" way, I don't think is likely to work since it should require driver and maybe hardware support. Fake PCM has a better chance, IMO. Oh well, worth trying, maybe ATI will wise up and release a compatible driver. I also wonder what James has been machinating there in the Slysoft dungeon.
Andy o is offline
Old 10-02-2009, 01:25 PM
SamuriHL's Avatar
It seems plausible that it'll work this way. At least for anything that supports IEC. I'm sure he's going to continue working on it.
SamuriHL is offline
Old 10-02-2009, 01:37 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 330
Yeah just like with PVP.
You need PVP to playback an AACS encrypted disc, but turn around and playback the m2ts stream from a decrypted disc and viola, no PVP. Both end up in the DXVA engine, just one also gets encrypted to the frame buffer, and the only other difference is that PVP will require HDCP on a digital output, but on output w/ HDCP they'd be identical.
Joel Barsotti
SpectraCal
sotti is offline
Old 10-02-2009, 01:40 PM
SamuriHL's Avatar
Yea, that was my thought, too. There shouldn't NEED to be any PAP from a technical stand point in order to bitstream. It's just required by the players to do so to play protected content. That's a licensing, not technical issue.
SamuriHL is offline
Old 10-02-2009, 03:04 PM
ricabullah's Avatar
Originally Posted by griffy_nz View Post
Sony make great products...its just that its always on their terms
Go mini-disc
Gone SACD
the list goes on...
you get stung every now and then
You forgot Betamax
Chronical Tester
ricabullah is offline
Old 10-02-2009, 03:13 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 330
possibly.
It would also be possible for the driver engineer to keep the bitstreaming hook behind the PAP hook.
Joel Barsotti
SpectraCal
sotti is offline
Old 10-02-2009, 03:14 PM
SamuriHL's Avatar
possibly.
We'll see. I don't think it works like that. People are treating PAP as some all powerful magic box. AFAIK, it's inactive unless it's specifically enabled by an application.
SamuriHL is offline
Old 10-02-2009, 03:22 PM
Tulli's Avatar
Quoted: 117 Post(s)
Liked: 102
That's a tricky analogy! DXVA is pretty much "open" functionality right now, that had been available for years before HD, whereas HD audio bitstreaming is being implemented proprietarily only recently by HW providers. And, additionally, DXVA is mostly irrelevant for BD playback with today CPUs, and even most of BDs are 24p.
Actually, if the HW provider keeps its solution proprietary, so that the HD audio bitstreaming functionality remains exclusive for its SW partners, PAP will be required to bitstream.
Tulli is offline
