ATI Radeon HD 5800, 5700 and 5600 Series Thread: Supporting HD Audio Bitstreaming! - Page 168 - AVS Forum | Home Theater Discussions And Reviews
Old 02-17-2010, 02:24 PM
cybrsage's Avatar
Liked: 154
I am still using the 10.2 betas...they are actually newer than the 10.2 officials...go figure.
cybrsage is offline
Old 02-17-2010, 02:26 PM
cybrsage's Avatar
Liked: 154
Originally Posted by klillevo View Post
Cool. I am likely to try... but have to figure out how to edit yours back to the default fan speed first (33% I think). Yeah, I know you say 50% is silent as well...
Here you go, 33% fan speed and the stock fan curve put back in but with the (default for all other cards) 157 / 300 speeds.
HIS Edited stock fan speed.zip 44.646484375k . file
cybrsage is offline
Old 02-17-2010, 02:34 PM
acejhtwo's Avatar
Originally Posted by acejhtwo View Post
Which 5450 would you recommend?
Would this one be suitable?
Just a quick update, I brought this card and received it today.
Set up
Win 7 64 bit
TMT3 170
10.2 Catalyst Driver
ATI HDMI Driver
Lite On BD Drive
Pioneer Elite VSX-23
Tested 5 Blu-rays so far, Bitstreaming is working perfectly.
Great video & audio quality. $45 well spent!
acejhtwo is offline
Old 02-17-2010, 03:50 PM
Andy o's Avatar
Thanks cybrsage, added a link to your post above in the problems thread.
Andy o is offline
Old 02-17-2010, 04:02 PM
Astralmind's Avatar
Originally Posted by Andy o View Post
Two things.
1. Do you have both "allow apps to take exclusive control of this device" and "give exclusive mode applications priority" checked, they should be.
2. This is likely your problem. Do you have checked "disable all enhancements" in the enhancements tab? If so, uncheck it.
Ok problem solved ! Catalyst 10.2 did nothing for me, status quo. Installing the Realtek 2.42 solved my 7MC issue however. That being said I can't seem to get TMT3 to bitstream... is there a special update needed ? I picked HDMI out and it still goes LPCM
Astralmind is offline
Old 02-17-2010, 04:04 PM
SamuriHL's Avatar
It's been said many times. TMT3 does NOT currently work with the Realtek driver.
SamuriHL is offline
Old 02-17-2010, 04:07 PM
trapo's Avatar
Originally Posted by trapo View Post
I tested many drivers (Realtek an ATI) using Driver Sweeper. I'm thinking about a new Win7 64 install...
I installed Win7 again and the new 10.2 official drivers.
It works perfectly now! Blue led and DTS-HD MA led ok in Denon. No issues. Yeah!
Setup:
Dell U2410 (HDMI in - native 1920x1200 60Hz)
Denon AVR-590 (AMP)
Radeon 5850 (2x crossfire)
Windows 7 x64 Ultimate
ATI Catalyst 10.2 official
PowerDVD 9 build 2528 (3rd option enable)
ATI HDMI Audio driver
EDID override for U2410/Denon by Tulli
Thank you very much, Tulli.
trapo is offline
Old 02-17-2010, 04:08 PM
SamuriHL's Avatar
Setup:
Denon AVR-590 (AMP)
Try a TrueHD track just to make sure.
SamuriHL is offline
Old 02-17-2010, 04:17 PM
jbizzlefosho's Avatar
Should I take that the new 10.2 drivers STILL need the EDID override? Just catching up on things before I head home and update.
jbizzlefosho is offline
Old 02-17-2010, 04:19 PM
Andy o's Avatar
Tulli said he still needed his.
Andy o is offline
Old 02-17-2010, 04:28 PM
kjoy064's Avatar
How the hell can ATI keep releasing driver and not fix the EDID that was first found to be the problem when PDVD release bitstreaming.
come on guys get your **** together, it's not like you aren't aware of it. Go upgrade your AVR to Denon and then you'll realise.
kjoy064 is offline
Old 02-17-2010, 04:30 PM
Andy o's Avatar
Originally Posted by ATWindsor View Post
Does anybody have any luck with the 10.2 driver? Audio-dropouts still seem to occur for me (uninstalled all previous HDMI-audio-drivers, and installed 10.2)
AtW
Are you having dropouts only with DXVA disabled, or with DXVA enabled as well? See here if only with DXVA disabled.
Another thing, did Tulli's override fix anything for you? You said you were having volume suddenly turn very low. I've heard of a similar issue from at least one other person. What settings do you have for your output in Windows (16/24 bit, 44.1/48/96/192, stereo/5.1/7.1)?
Andy o is offline
Old 02-17-2010, 06:51 PM
trapo's Avatar
Where can I get a TrueHD 5.1 sample? It's hard to find one.
trapo is offline
Old 02-17-2010, 07:07 PM
SamuriHL's Avatar
You could check the doom9 forum and the ffdshow HD audio thread. Several were posted in there at one point or another.
SamuriHL is offline
Old 02-17-2010, 07:30 PM
braddles69's Avatar
I just found that my HIS 5670 512mb is doing the same thing, small crackles and pops, only when playing LPCM or PCM tracks, TrueHD and DTS HD-MA all good.
When I set the card to o/drive 840 and 1040 respectively, it took care of it, but don't really want to keep it there.
Has anybody tried the HIS drivers? (Says Vista 8.673-091110a)
Will give them a go and see what happens, I assume I will have to use their HDMI driver, but will try with Realtek as well.
Let you know how it goes.
Less is More and sometimes More is Less
braddles69 is offline
Old 02-17-2010, 09:03 PM
blackcell's Avatar
Quoted: 13 Post(s)
http://samples.mplayerhq.hu/A-codecs/TrueHD/
Sample 1 is 5.1 and sample 2 is 6.1.
blackcell is offline
Old 02-17-2010, 09:07 PM
braddles69's Avatar
Okay, tried the HIS drivers...but obviuosly, they are an earlier version of what I have (8.69RC3)...dumbass...)
So just installed the 10.2, and the realtek2.42, no change
as this only happens with one movie, Deja Vu (excellent, but only has LPCM in audio), was wondering is there a way to make MPC use DXVA decoding with a ts file?
Anybody thought of that?
Old 02-17-2010, 09:12 PM
blushrts's Avatar
Astralmind, have you disabled windows media center sounds? I had the same problem as you where video would play for a short while, then got the error about missing audio files. With the windows media center sounds disabled, I can use the ATI sound driver and get bitsteaming with TMT3 and live TV works in media center.
blushrts is offline
Old 02-17-2010, 09:13 PM
Andy o's Avatar
If you have enabled the H.264 and VC-1 DXVA decoders, and you ripped that movie from a bluray without transcoding, you should be able to use DXVA with MPC-HC. Just make sure you're using EVR-CP.
Andy o is offline
Old 02-17-2010, 09:25 PM
AmiraTech's Avatar
Quoted: 78 Post(s)
Liked: 60
Everything I have read so far says there should be no issues with a Yamaha Receiver and a Panasonic Plasma, however i can't get HD bitstreaming to work. PDVD9 does not show me a "3rd" option which I'm guessing allows HD audio. Dolby Digital and DTS both bitstream fine, but no HD.
Any thoughts? Anything I am missing?
Win 7 32bit
HIS 5670 1GB IceQ
ATI 10.2 Drivers
RealTek Audio Driver
All defaults in HDMI audio configuration.
Yamaha RX-V765
Panasonic TC-P65V10
AmiraTech is offline
Old 02-17-2010, 09:40 PM
trapo's Avatar
I tested http://sebinternet.free.fr/TEST_7.1_TRUEHD.m2ts. TrueHD didn't work.
I can't test .mkv files in PDVD9.
I tested ac3_truehd-50mb.ts and vc1-with-truehd.m2ts (both 5.1). TrueHD didn't work.
What's the trick now?
I'll try the Realtek driver.
Update: Realtek didn't work too.
trapo is offline
Old 02-17-2010, 09:47 PM
trapo's Avatar
Win 7 32bit
HIS 5670 1GB IceQ
ATI 10.2 Drivers
Yamaha RX-V765
Panasonic TC-P65V10
If you're using the PDVD9 build 2320 or later, try to install the EDID override by Tulli.
trapo is offline
Old 02-17-2010, 09:56 PM
AmiraTech's Avatar
Quoted: 78 Post(s)
Liked: 60
According to Tulli's thread, there is no EDID override required (or made) for Yamaha receivers, hence my quandary.
Old 02-17-2010, 10:00 PM
alpha0ne's Avatar
^ Have you checked your HDMI cable, yes I know its a big maybe but it is worth a try
alpha0ne is offline
Old 02-17-2010, 10:02 PM
KenIAm's Avatar
I just got a Powercooler 5450 today, and installed it using CCC 10.2, and I have a question:
The PC desktop doesn't expand all the way to the edges of the TV screen (Tosh 55SV670U). There's a blank area of about 2" on the sides and 1" on the top and bottom. I verified it is set to 1980x1020 (59Hz).
The PC is connected to the AVR (Denon 2310Ci) via HDMI (and the AVR is of course connected to the TV via HDMI).
I can change the TV setting from "native" to "fill", which comes closer to filling the screen by stretching in both directions (but still leaves a small border along all edges of 1/4" - 3/4"). But it does seem slightly degrade the PQ, so I'd rather fill it up without having to stretch it.
Any ideas?
KenIAm is offline
Old 02-17-2010, 10:15 PM
trapo's Avatar
Any ideas?
Try set the Image/GPU Scaling in CCC/Desktop & Displays/Configure... (arrow in select display bar)/Attributes
trapo is offline
Old 02-17-2010, 10:24 PM
Vic Y's Avatar
Any ideas?
I just installed 5570 2 days ago and have the same problem. Found out you have to goto ccc, desktop and display, configure your display, click the scanning tab and move the overscan option to 0%. Hope this help,
Vic Y is online now
Old 02-17-2010, 10:35 PM
gorges's Avatar
Is there a changelog for Realtek HDMI 2.42?
gorges is offline
KenIAm's Avatar
Thanks, I really appreciate the help and super fast replies.
But I don't have a "Scanning" tab in the configure display (Desktop properties) dialog (only "mode" and "color" tabs, neither of which have anything on them related to scanning or GPU scaling). Nor do I have an "Attributes" tab or menu selection. When I press the arrow in the display bar, I get 3 menu choices: Rotate, Identify, and Properties. Properties brings up the very same dialog as selecting "Desktop Properties" from the main menu.
How come I don't have this stuff? (This is advanced mode, not basic.)
KenIAm is offline
Old 02-17-2010, 10:41 PM
Nimo's Avatar
I had to make a tough call on that one too, but I opted for the officials hoping they worked out the bugs. But I'm pretty impressed with this set I just played Corpse Bride and the UV colors really pop on the skeletons dancing. This set up is working so well for me I won't be changing anything for a while.
Nimo is offline
