ATI Radeon HD 5800, 5700 and 5600 Series Thread: Supporting HD Audio Bitstreaming! - Page 79 - AVS Forum | Home Theater Discussions And Reviews
Old 12-13-2009, 04:05 PM
vladd's Avatar
Liked: 39
Originally Posted by SamuriHL View Post
That counts me out as I have no intention of ever going back to Vista. When you need a W7 64 bit guy, let me know.
I'm going to retry some tests after dinner. Once I get this working, I'm going back to Win7 only. I liked Vista better than XP but that was before I saw Win 7.
vladd is offline
Old 12-13-2009, 04:07 PM
SamuriHL's Avatar
Exactly how I feel about Vista. It was fine and all, and better than XP, but, it was a pig. 7 is SO much more refined and better suited to HTPC duty.
SamuriHL is offline
Old 12-13-2009, 04:37 PM
ricabullah's Avatar
Thanks vladd for your efforts.
Guys don't forget i'm on seven as well but doing those tests for the other Vista users.
Chronical Tester
ricabullah is offline
Old 12-13-2009, 05:17 PM
drapp1952's Avatar
Quoted: 14 Post(s)
OK, I finally got the third option on PDVD9 to my Onkyo 805 with the help of this thread and, particularly, varkeast who sent me the Onkyo 906 .inf file that finally got the 805 to bitstream HD audio and the difference is clear and appreciated.
But, now, 24 Hz video is not an option under ATI CCC. It was before I installed the 906 .inf. 25i is as low as it goes, and it shows...my JVC RS1 projector confirms 50Hz is the frame rate - the projector doubles it, and occasional skipping is visible.
Any ideas? Reinstall the 9.11 driver?
drapp1952 is offline
Old 12-13-2009, 05:59 PM
Tulli's Avatar
Quoted: 117 Post(s)
Liked: 102
Well, maybe the EDID HD video descriptors of the Onkyo 906 are not in the order expected by the ATI driver? So far AFAIK no one using that EDID override has reported that 24hz issue. I get all refresh rates with my Denon override so I'd say yes, go ahead and reinstall the ATI driver.
A driver cleaning before installing would help. Use Driver Cleaner (not free) or Driver Sweeper (free).
EDID Overrides (capture, install/uninstall, troubleshooting)
Tulli is offline
Old 12-13-2009, 06:04 PM
ricabullah's Avatar
I would advise driver sweeper for Ati always
Chronical Tester
Old 12-13-2009, 11:04 PM
vladd's Avatar
Liked: 39
I didn't think you were going back to Vista. We're just "taking one for the team".
vladd is offline
Old 12-14-2009, 03:51 PM
ricabullah's Avatar
Fixed with MPC Audio Renderer, thanks guys.
ffdshow_bitstream beta 54 works with MPC Audio Renderer and i can see the blue light on my AVR's front panel for both HD audio formats
46 as well.
Both 46 and 54 is working on Seven too
http://forum.doom9.org/showthread.ph...13#post1352913
http://forum.doom9.org/showthread.ph...31#post1352931
http://forum.doom9.org/showthread.ph...63#post1352963
Chronical Tester
Old 12-14-2009, 04:30 PM
Davinleeds's Avatar
I don't have MPC Audio Renderer in my drop down.
"The purpose of diplomacy is to prolong a crisis." Spock, Mark of Gideon, TOS
Davinleeds is offline
Old 12-14-2009, 04:40 PM
ricabullah's Avatar
Old 12-14-2009, 04:41 PM
Andy o's Avatar
Last time I tried it you had to download and register it separately.
Andy o is offline
Old 12-14-2009, 04:47 PM
ricabullah's Avatar
Old 12-14-2009, 05:50 PM
Davinleeds's Avatar
Thanks Rica, exact setup and still no True HD.
Old 12-14-2009, 05:54 PM
SamuriHL's Avatar
Hey Rica, you can start using forum.doom9.org instead of the IP in links now. DNS has been fixed over there for quite a while now. Nice work on the Vista testing. I'm sure you'll be happy to get back to 7.
SamuriHL is offline
Old 12-14-2009, 05:57 PM
ricabullah's Avatar
Sorry if it is a repetition davin:
Make sure:
You are on SP2?
Updated DirectX End-User Runtime?
Have MS Net FrameWork 3 or later?
Registered proppage.dll coming with the latest Windows SDK?
Chronical Tester
Old 12-14-2009, 06:02 PM
ricabullah's Avatar
Thanks my friend but you know you have to wait some days for your approval to doom9; so nobody who's not a member may ask something there
Get back to 7 ? Yes
Chronical Tester
Old 12-14-2009, 06:17 PM
Davinleeds's Avatar
Make sure:
You are on SP2?
I'm losing it. I forgot you were testing Vista.
SamuriHL's Avatar
I was referring to this, actually:
Instead of the ip address, you can start using forum.doom9.org again as the DNS problem has been fixed.
Get back to 7 ? Yes
HEHEHE. That's a BIG sacrifice going back to Vista once you've touched 7.
SamuriHL is offline
Old 12-14-2009, 06:25 PM
ricabullah's Avatar
Yeah, you're right, sorry
revised.
Chronical Tester
Old 12-14-2009, 06:43 PM
ricabullah's Avatar
OK but if you are on 7, it must be more easier to get THD bitstreming?
Settings are the same for seven and lets make a little modification on these:
Code:
Make sure:
Registered proppage.dll coming with the latest 7 SDK?
Chronical Tester
Old 12-14-2009, 07:36 PM
Davinleeds's Avatar
No, no True HD, but I am getting bitstreamed lpcm >I'm thinking< Nothing but the AVR controls audio output. MPC nor window's audio controls work. In Xonar these could affect volume.
True HD 5.1 is outputing lpcm 7.1 The New World
Audio with Star Trek ISO is spastic.
Old 12-15-2009, 10:43 AM
blackEyEz's Avatar
@renethx, how is the walkthrough of HD bitstreaming going? If i check the ffdshow thread THD and DTSHD has been accomplished. Can't wait!
blackEyEz is offline
Old 12-15-2009, 01:10 PM
vladd's Avatar
Liked: 39
Good news on the EDID issue guys. Someone had an unrelated issue with the 4xxx series cards and got the following response from ATI support (excerpt):
Originally Posted by Arashjahn View Post
There should also be a hotfix released in the next few days labeled Catalyst 9.12 hot fix. One of the release notes statement revolves around:
DTS-HD and Dolby True-HD not working properly with certain receivers while using HDMI connection on ATI Radeon HD 5000 Series
This may be also related to the 4000 series, so you may want to try that when it comes out later on this week.
vladd is offline
Old 12-15-2009, 01:29 PM
tycoonheart's Avatar
Sweeeeeeet.
tycoonheart is offline
Old 12-15-2009, 01:35 PM
Tulli's Avatar
Quoted: 117 Post(s)
Liked: 102
hmm, 9.12 should be available tomorrow, and there's already a hotfix to inmediately come out after that? Interesting developments ...
Tulli is offline
Old 12-15-2009, 01:46 PM
vladd's Avatar
Liked: 39
Yeah, hopefully it will also enable DD+ support in the audio driver.
vladd is offline
Old 12-15-2009, 02:41 PM
ricabullah's Avatar
Hope today is the last day of his his vacation
He was on vacation while we were ..... for Ati, huh?
Merry Xmas to you Terry .
Don't worry you are the CatalystMaker and we are ourselves own brain ***r. (maker ,lover, whatever )
Chronical Tester
Old 12-15-2009, 02:56 PM
lagcal3's Avatar
Ok, quick question.
My HTPC running a ATI 5750 (HDMI) output to my reciever (Yamaha RX-V1700).
The RX-V1700 does not support bitstreaming so i want to make sure i'm getting the correct stream to get LPCM.
In TMT3 I selecting HDMI and origanal steam. But when i play a blue ray it says DTS on my reciever and not PCM.
Anyone know why this is?
lagcal3 is offline
Old 12-15-2009, 03:04 PM
vladd's Avatar
Liked: 39
Originally Posted by lagcal3 View Post
Ok, quick question.
Select 8 channel (or 7.1 channel) output.
vladd is offline
Old 12-15-2009, 03:12 PM
haggis663's Avatar
The new Realtek 2.39 drivers are now out. After installation, the supported formats include DTS-HD and Dolby TRUEHD. I have to use the Realtek drivers due to them being the only stable ones for Win 7 Media Centre TV when in Dolby digital mode.
Will someone try these out with PowerDvd and let us know if it is bitstreaming the DTS-HD or Dolby TrueHD correctly?
haggis663 is offline
