ATI Radeon HD 5800, 5700 and 5600 Series Thread: Supporting HD Audio Bitstreaming! - Page 82 - AVS Forum | Home Theater Discussions And Reviews
post #2431 of 7498 Old 12-17-2009, 12:08 PM
bokis's Avatar
bokis is offline
post #2432 of 7498 Old 12-17-2009, 12:48 PM
Tulli's Avatar
Quoted: 117 Post(s)
Liked: 102
hmm ... looks like I'll wait for the hotfix .
EDID Overrides (capture, install/uninstall, troubleshooting)
Tulli is offline
post #2433 of 7498 Old 12-17-2009, 12:52 PM
SamuriHL's Avatar
The HDMI driver in Cat 9.12 has not changed. I'm sticking with the realtek driver.
SamuriHL is offline
post #2434 of 7498 Old 12-17-2009, 01:57 PM
Tolstoi's Avatar
I am anxious to get that one I am still not capable to get DTS-MA bitstream to sync with my prepro even with an EDID override. At least the EDID override is giving me access to 23 and 59hz.
Tolstoi is offline
post #2435 of 7498 Old 12-17-2009, 02:03 PM
jong1's Avatar
Quoted: 131 Post(s)
Liked: 105
So no one else is having "crackling" problems with WMP12 (and smplayer).
I have managed to make it much better by disabling sounds in my HTPC app, which I think were interfering with playback. It seems it is the mixer that throws a fit in some apps (MF?) if other sounds need to be mixed in with it. MPC-HC and PDVD are fine. Even bringing up the start menu when WMP/smplayer are running is enough to send the sound into fits and once it has started it won't stop until playback is stopped and restarted. It gets worse as you up the output bitdepth/sampling rate. Once it starts it is unlistenable to @24/96, bad but survivable @16/48! The new Realtek drivers are the same.
jong1 is offline
post #2436 of 7498 Old 12-17-2009, 03:13 PM
Tolstoi's Avatar
Tolstoi is offline
post #2437 of 7498 Old 12-17-2009, 03:14 PM
SamuriHL's Avatar
"File not found."
Awesome.
SamuriHL is offline
post #2438 of 7498 Old 12-17-2009, 03:16 PM
SamuriHL's Avatar
FYI, the Realtek driver + 9.12 fixes WinDVD 2010 bitstreaming with the 5xxx cards.
SamuriHL is offline
post #2439 of 7498 Old 12-17-2009, 03:17 PM
Tolstoi's Avatar
Originally Posted by SamuriHL View Post
"File not found."
Awesome.
I know!
Tolstoi is offline
post #2440 of 7498 Old 12-17-2009, 03:21 PM
SamuriHL's Avatar
LOL! I'm sure they just haven't put it up yet. We'll keep checking. Thanks for the link to the page, though. That's awesome.
SamuriHL is offline
post #2441 of 7498 Old 12-17-2009, 03:22 PM
Tolstoi's Avatar
I finally got it here:
http://support.amd.com/us/kbarticles...AGPHotfix.aspx
Which bring you to the 9.11 hotfix pages. Than press this link:
■Catalyst 9.11 Hotfix for Windows 7 / Windows Vista 64-bit Edition
That will give you the 9.12 hotfix.
unbelivable!
Tolstoi is offline
post #2442 of 7498 Old 12-17-2009, 03:23 PM
Tolstoi's Avatar
unbelivable!
Disregard this is the AGP 9.12 hotfix we don't need that!
Tolstoi is offline
post #2443 of 7498 Old 12-17-2009, 03:23 PM
SamuriHL's Avatar
No no no! Don't install that. It's for AGP cards. Be careful.
EDIT: You're too fast.
SamuriHL is offline
post #2444 of 7498 Old 12-17-2009, 03:27 PM
Tolstoi's Avatar
I know!
I need DTS-MA bitstream to work...Yesterday!
Tolstoi is offline
post #2445 of 7498 Old 12-17-2009, 03:28 PM
sk11vengeance's Avatar
So let me get this straight. When im watching a movie that is 24hz or 23.976, should I set the frame rate in CCC or in Win7, screen res>advanced settings>monitor tab to 23 or 24hz? Im sending the hdmi from the 5750 to my receiver and from there to my samsung tv which has 240hz refresh which I have on a custom setting. Ive noticed when I leave it on 60hz I see skipping during bluray playback in PDVD9 but when I set it to 24hz its only a few times during the whole movie so I was wondering if the 23/24hz thing has something to do with that? Also my htpc with the 5750 has win7 64bit installed and I tried reclock but it doesnt seem to be working. The shortcut key to bring up the properties window doesnt work either.
sk11vengeance is offline
post #2446 of 7498 Old 12-17-2009, 03:51 PM
JaSharpy's Avatar
I am curious as well...
JaSharpy is offline
post #2447 of 7498 Old 12-17-2009, 04:08 PM
Davinleeds's Avatar
Originally Posted by Davinleeds View Post
I found it did make a difference. Tried with two 785(4200) MBs and two different 4670s to use the Xonar. Each attempt, black screen if windows showed "not supported". HDCP was listed as supported in the driver, Nvidia and ATI. Only when listed in windows (HDCP Supported) did the Xonar accept the Protected Audio Path.
That was my trial and error to get it working for my setup.
I update this with: Using the 2.39 Realtek driver (which indicates HDCP not supported) and WinDvd2010 does bitstream HD audio. Xonar seems to need HDCP and software players do not. renethx was correct.
"The purpose of diplomacy is to prolong a crisis." Spock, Mark of Gideon, TOS
Davinleeds is offline
post #2448 of 7498 Old 12-17-2009, 04:46 PM
Mevlock's Avatar
Mevlock is offline
post #2449 of 7498 Old 12-17-2009, 05:02 PM - Thread Starter
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
Every AACS-compliant software player checks HDCP-compliance of the HDMI devices (source/display) before sending premium contents. So somehow Windows reports wrong information (via Realtek driver) and somehow Xonar uses this wrong information, I guess.
renethx is offline
post #2450 of 7498 Old 12-17-2009, 05:13 PM
Davinleeds's Avatar
Should I uninstall Realtek before installing this hotfix?
post #2451 of 7498 Old 12-17-2009, 05:22 PM
SamuriHL's Avatar
No. It doesn't contain an HDMI driver from what I can see.
SamuriHL is offline
post #2452 of 7498 Old 12-17-2009, 05:24 PM
Andy o's Avatar
The hotfix came out before 9.12 official, but it's "9.12 hotfix". Damn they're confusing.
Andy o is offline
post #2453 of 7498 Old 12-17-2009, 05:39 PM
Davinleeds's Avatar
Thanks SamuriHL
post #2454 of 7498 Old 12-17-2009, 05:40 PM
Tolstoi's Avatar
9.12 is fixing video edid problem i could now 23 and 59 without edid override.
Tolstoi is offline
post #2455 of 7498 Old 12-17-2009, 05:45 PM
rickcfer's Avatar
Quoted: 46 Post(s)
Liked: 24
Thanks SamuriHL
The hotfix does contain a HDMI driver. Do an Express Uninstall of all ATI software and a HDMI driver will be offered with the hotfix.
rickcfer is offline
post #2456 of 7498 Old 12-17-2009, 05:53 PM
Andy o's Avatar
Anyone installed the 9.12 official (not hotfix) drivers and checked the version?
Andy o is offline
post #2457 of 7498 Old 12-17-2009, 05:55 PM
SamuriHL's Avatar
That's weird. I don't have the ATI HDMI driver installed. It never showed an HDMI driver during the hotfix install. What's the version on it?
EDIT: I just looked. SAME exact driver from 9.10. So it's not an updated HDMI driver at all.
SamuriHL is offline
post #2458 of 7498 Old 12-17-2009, 05:57 PM
Davinleeds's Avatar
If I uninstalled, I would guess it would reinstall it's own driver. But I'm asking as a hotfix, does it require uninstall of the Realtek Hdmi driver?
post #2459 of 7498 Old 12-17-2009, 06:02 PM
rickcfer's Avatar
Quoted: 46 Post(s)
Liked: 24
Correct, it would install the HDMI driver that is part of the hotfix package,ie the hotfix DOES contain a HDMI driver. It would probably overwrite the Realtec driver.
rickcfer is offline
post #2460 of 7498 Old 12-17-2009, 06:07 PM
Tulli's Avatar
Quoted: 117 Post(s)
Liked: 102
bleh ... hotfix didn't work. Seems my Denon 988 is still not on the list of selected happy few AVRs that ATI drivers like ... Back to my EDID override again.
Tulli is offline
Reply Home Theater Computers
