ATI Radeon HD 5800, 5700 and 5600 Series Thread: Supporting HD Audio Bitstreaming! - Page 85 - AVS Forum | Home Theater Discussions And Reviews
post #2521 of 7498 Old 12-18-2009, 05:11 PM
ricabullah's Avatar
The latest trial i have to do is giving it a go with Realtek drivers over tulli+Ati 12 hotfixes.
Chronical Tester
ricabullah is offline
post #2522 of 7498 Old 12-18-2009, 05:14 PM
Tulli's Avatar
Quoted: 117 Post(s)
Liked: 102
Originally Posted by SamuriHL View Post
I can try that. Hang on. I'm playing Ratatouille upscaled to 192/24 LPCM in WinDVD2010. No problem there. Now let's switch to PDVD9 and crank up a DTS-HD MA track. Um, yea, no problem. Playing perfectly.
Can't reproduce it again, maybe because of the 9.12 hotfix. Problem now is only on WinDVD10, so it really looks now like a player bug with this specific BD.
Anyway, will take a look at the Pioneer EDID when WIREBALLZ posts it, create a Pioneer_MOD.inf with the video and audio descriptors that have proved to work. IF this doesn't solve the DTS MA issue then it's driver bug of course.
EDID Overrides (capture, install/uninstall, troubleshooting)
Tulli is offline
post #2523 of 7498 Old 12-18-2009, 05:32 PM
Tulli's Avatar
Quoted: 117 Post(s)
Liked: 102
Originally Posted by WIREBALLZ View Post
Here it is Pioneer.ini log Attachment 161310 does it have to be windows 7 ? because this is vista sp2
Excellent ... looking at it now...
Tulli is offline
post #2524 of 7498 Old 12-18-2009, 05:41 PM
robertgr's Avatar
does someone know way cant i see in the graph studio the mpc decoder even after i selcted it in the MPC HC ?
insted i allways see the ffdshow video decoder but when i disable the ffdshow video decoder and i open a video file in the graph studio i dont see any video chein in the graph i see only the audio the video is empty
robertgr is offline
post #2525 of 7498 Old 12-18-2009, 05:52 PM
ricabullah's Avatar
No, forget it. Just keep Ati HDMI drivers.
Chronical Tester
post #2526 of 7498 Old 12-18-2009, 06:00 PM
SamuriHL's Avatar
That's very possible. Interesting to note that the 9.12 hotfix *seems* to have improved 24Hz with TMT3 on my 4850 on my bedroom machine. I haven't had time for a full movie test, but, just messing around with one of my images on that machine I haven't seen any stutter or sync issues. This was definitely a problem before. PDVD9 is also working well on that machine, so, I can't say I'm displeased with this latest round of drivers so far.
SamuriHL is offline
post #2527 of 7498 Old 12-18-2009, 06:05 PM
Tulli's Avatar
Quoted: 117 Post(s)
Liked: 102
Here it is Pioneer.inf log Attachment 161310 does it have to be windows 7 ? because this is vista sp2 but can do win 7 if need be
Ok, attached is the modded inf for the Pioneer. It works for Vista.
The audio descriptors actually were in a different order than the Onkyo's so a parsing problem is possible. I replaced only the audio descriptors and left the video part untouched.
To apply the EDID override follow step 3 from the link posted above.
Pioneer1019ah_MOD.zip 1.1689453125k . file
Tulli is offline
post #2528 of 7498 Old 12-18-2009, 06:17 PM
WIREBALLZ's Avatar
Sorry DTS-HD MA no go from MPC-HC on pioneer
WIREBALLZ is offline
post #2529 of 7498 Old 12-18-2009, 06:36 PM
Tulli's Avatar
Quoted: 117 Post(s)
Liked: 102
OK, so the AVR is not the issue then.
What about graphstudio? Does it work from there?
Err ... but some stupid question: did you reboot after applying the override?
Also, check that the override is correctly applied by going to
Control Panel->Device Manager->Expand on Monitors.
If you see a "Generic PnP Monitor" there for the pioneer, righ click on it, select update, and repeat step3 routine and, of course, reboot.
Tulli is offline
post #2530 of 7498 Old 12-18-2009, 06:36 PM
robertgr's Avatar
ware can i find dts hd ma samples and DD plus samples
robertgr is offline
post #2531 of 7498 Old 12-18-2009, 06:38 PM
WIREBALLZ's Avatar
Never used Graphstudio but will install it
post #2532 of 7498 Old 12-18-2009, 06:41 PM
Tulli's Avatar
Quoted: 117 Post(s)
Liked: 102
I edited my post above ...
Tulli is offline
post #2533 of 7498 Old 12-18-2009, 06:44 PM
WIREBALLZ's Avatar
I do see Pioneer override for monitor and rebooted it when i tested it.
post #2534 of 7498 Old 12-18-2009, 08:51 PM
hellokeith's Avatar
Originally Posted by sanne View Post
I'm having a hell of a time trying to follow this thread. Can someone clear up some confusion for me.
I ordered a 5770 which should come in today. I will be running Windows 7 64-bit. From what I understand there is an ATI HDMI audio driver and a Realtek HDMI audio driver....which one do I use and how do I set it up to bitstream HD audio via PowerDVD?
Many thanks.
I tried the Realtek one, and it made things worse. Stick with the ATI HDMI driver in Catalyst 9.12 or newer. As said before, you may have to create a custom monitor driver if you are having a disparity between the video capabilities of your monitor and the audio capabilities of your AVR.
hellokeith is offline
post #2535 of 7498 Old 12-18-2009, 09:33 PM
Tulli's Avatar
Quoted: 117 Post(s)
Liked: 102
9.12 Hotfix and 9.12 have the same buggy HDMI driver as 9.11's, so I'll stay with the Realtek 2.39.
Tulli is offline
post #2536 of 7498 Old 12-19-2009, 01:31 AM
goemonate's Avatar
I can confirm that there is a problem somehow with Pioneers/ VSX 1019AH-K with MPC-HC and DTS-HD MA all I get is flashing between dtshd ma and pcm no sound. True HD works no problems. I also have a Onkyo TX-SR805 and everything works DTS-HD MA and TrueHD perfect same computer same settings. FYI
My config is:
xfx Radeon HD 5750
Catalyst 9.12 and hotfix + Realtek 2.39 Hdmi Driver
Windows 7 64-bit
MPC HomeCinema 32bit (the latest SVN)
ffdshow_rev3164_20091214 32bit
Onkyo TX-SR805
Pioneer VSX 1019AH-K
I am finally not alone! I own a Pio SC-05. same situation as above.
goemonate is offline
post #2537 of 7498 Old 12-19-2009, 03:02 AM
tetsuo55's Avatar
Is this custom inf still required if my AVR does get properly detected?
I have a Onkyo TX-607 which gets detected as TX-607 in the hardware overview (i must admit that i use a 4770) with the newest updates windows is reporting full HD bitstreaming support for it (but it is not working, i'm getting blips and beeps)
tetsuo55 is offline
post #2538 of 7498 Old 12-19-2009, 04:33 AM
djlah's Avatar
anyone know the next coming 5350 is also support DTS-HD and TrueHD bitstream enabled? or already confirm all 5xxx series ATI are support?
should I wait for the most entry level 5 series or just get 5750 now?
I just want HD bitstream, totally no gaming required....
djlah is offline
post #2539 of 7498 Old 12-19-2009, 05:10 AM
Tulli's Avatar
Quoted: 117 Post(s)
Liked: 102
It helps resolving bad handshakes with my 4670, but no bitstreaming possible so far even so with this card for me.
Tulli is offline
post #2540 of 7498 Old 12-19-2009, 08:35 AM
tetsuo55's Avatar
thanks, i will try to make the new inf file then.
We are working hard on the hd bitstreaming part, hope albain can figure it out.
tetsuo55 is offline
post #2541 of 7498 Old 12-19-2009, 08:40 AM
SamuriHL's Avatar
Assuming madshi's incorrect, and there's something that can be figured out, anyway. I really do hope the 4xxx people end up with bitstreaming but I wouldn't hold my breath on that one.
SamuriHL is offline
post #2542 of 7498 Old 12-19-2009, 11:19 AM
ixion's Avatar
All 5xxx series will support HD audio bitstreaming. I didn't want to wait, so I got the XFX 5750 even though I don't do any gaming. It's small and silent.
ixion is offline
post #2543 of 7498 Old 12-19-2009, 12:14 PM
chadamir's Avatar
Quoted: 177 Post(s)
Liked: 59
Using a 5750 hooked up to an onkyo 606 im having no luck. I created an edid override using moninfo with no luck. I can without the override (and with) select the third option in pdvd9, but this does nothing and will eventually crash pdvd. I tried using ffdshow and mpc but I could not get it to stream anything, nor could I get it to use the mpc renderer (it kept defaulting to directshow as the renderer which did not work). I have the newest realtek drivers and I believe cat 9.11 is installed. I'm under vista sp1, do I need sp2?
chadamir is offline
post #2544 of 7498 Old 12-19-2009, 12:25 PM
disb's Avatar
Just ordered a 5770
Can't wait for it to arrive on Tuesday
disb is offline
post #2545 of 7498 Old 12-19-2009, 02:27 PM
ixion's Avatar
My experience so far...
Equipment and Software:
Integra DTC-9.8 Processor
Radeon 5750 with 9.12 drivers (not the hotfix)
Playback: Windows 7, 7MC with MediaBrowser, WMF disabled, Gabest splitter, audio using FFDShow tryouts 3164, using Windows Video Decoder
File formats:
MKV movies with 1080p and TrueHD or DTS-MA audio
M2TS movies with 1080p and TrueHD or DTS-MA audio
Problem #1:
During boot up, I get "an incompatible signal has been received" error and no video, but this goes away after Windows boots up and the ATI driver is loaded. This means I can't access my HTPC's BIOS should I need to. Also, the HDMI sync is sporadic, sometimes I have to switch to another source and switch back for my Integra processor to sync and display video.
Problem #2:
In 7MC, I can get MKVs with TrueHD or DTS-MA to bitstream to my processor. But for some movies (e.g. Into The Wild), the TrueHD audio is choppy and drops out every 4-5 seconds. I have no such problems with DTS-MA.
Problem #3:
M2TS files with VC-1 video is choppy. M2TS files with AVC are fine. Bitstreaming HD audio works in either case, but is choppy along with the video.
Problem #4:
No fast forward or rewind capability in MKV or M2TS. But I can skip ahead and back.
Any advice is appreciated. Thanks.
ixion is offline
post #2546 of 7498 Old 12-19-2009, 06:17 PM
chadamir's Avatar
Quoted: 177 Post(s)
Liked: 59
Well upgrading to SP2 got powerdvd to work, but ffdshow for some reason is converting to lpcm.
chadamir is offline
post #2547 of 7498 Old 12-19-2009, 07:21 PM
ricabullah's Avatar
I meant if you are using 12 hotfix don't use Realtek over it; keep Ati HDMI drivers. But if you don't, stay with Realtek.
Chronical Tester
post #2548 of 7498 Old 12-19-2009, 07:28 PM
SamuriHL's Avatar
I use the 9.12 hotfix driver with the realtek drivers. Works great.
SamuriHL is offline
post #2549 of 7498 Old 12-19-2009, 07:44 PM
ricabullah's Avatar
Gonna give it a shot again, thanks.
Chronical Tester
post #2550 of 7498 Old 12-19-2009, 08:02 PM
ricabullah's Avatar
Yeah, it works with Direct Sound Device over 12 hotfix +tuli's override +Realtek drivers.
Seven 64 btw
But i must say without Realtek, Ati HDMI output gave me better sound with THD on PDVD.
Chronical Tester
Reply Home Theater Computers
