ATI Radeon HD 5800, 5700 and 5600 Series Thread: Supporting HD Audio Bitstreaming! - Page 91 - AVS Forum | Home Theater Discussions And Reviews
post #2701 of 7498 Old 12-28-2009, 06:38 AM
indieke2's Avatar
Tulli, the Ruby does not seem the problem, as the denon is hooked on the Panasonic plasma. Files play fine, and I only needf it for tweaking and sometimes satelite tv.
No the problemis that the card output only 30 hz, except when I link it to the Ruby that is working well in 60 hz, by the dvdi-hdmi adapter output.
I will grab the edid, if you want, but I don't know exactly whazt I have to do for that. The realtek 2.39 is installed. Maybe I installed it twice, and maybe deleted it, i can try to install it again.
I like my HT, wine and pretty girls. But...am I the only one
indieke2 is offline
post #2702 of 7498 Old 12-28-2009, 06:50 AM
Tulli's Avatar
Quoted: 118 Post(s)
Liked: 103
OK, so problem is the Panasonic, which is weird indeed. And you get choppy sound when bitstreaming on WinDVD2010 with the realtek installed? Makes no sense to me.
It wouldn't hurt to do a proper reinstall of ATI 9.12 hotfix, Realtek 2.39 and then apply the EDID override.
Use Drivercleaner or Driversweeper to clean old traces would be also recommended.
To capture the Panasonic EDID it is enough to plug it to the PC and then grab the real-time EDID with moninfo and create the .inf file. But you cannot do it on a 5xxx card right now.
EDID Overrides (capture, install/uninstall, troubleshooting)
Tulli is offline
post #2703 of 7498 Old 12-28-2009, 09:02 AM
Thefabulousfab's Avatar
Originally Posted by winb83 View Post
might as well bring up my issue here and at least see if anyone else is having the same problem.
The issue I've been having is when I watch videos over HDMI on my TV the audio cuts in and out every few seconds. Sometimes it randomly doesn't do that but if its not doing that then there's a sort of popping static in the background while the normal audio plays over it.
This only occurs during video playback. I can play games, listen to music, or basically do anything else and none of this happens. Lastly if I use VLC none of this this happens in fact if I disable ffdshow's video and use DXVA with Media Player Classic all the issues go away. This all only happens with the HDMI audio, regular audio through speakers or headphones has no issues. this leads me to believe there's some type of conflict with the ATI card and ffdshow.
system specs are
Q9550 Core 2 Quad processor
3GBs of RAM
ATI HD5770 GPU
32 bit Windows 7 Ultimate OS
Realtek latest HD Audio drivers (2.39 i believe) and the ATI HDMI audio drivers on their page.
it seems as if the PC should be powerful enough to handle things without requiring DXVA. anybody have any idea why it can't?
Originally Posted by snickerers View Post
I have the same problem with ffdshow and my 5850 and haven't been able to fix it. I did find out that the dropouts got much worse, once every couple of seconds, if I switched to 1080p/24hz, at 60hz the dropouts don't happen as often. This is really distracting when trying to watch something.
I've got exactly the same problem with an ati 5750 on a Pioneer 1018 and win7 32bits... ;-( and I might go back to my 4670 if we don't find a solution within a couple of days.
Can you comment on your config for trying to find a comon trunk as it doesn't seem to be the case for everyone...
Mine is:
5750 powercolor scs3
pioneer 1018 avr
win7 32 bits
cat 9.12 hotfix with or without tulli's latest pio override
with or without latest realtek driver (the result is the same)
An other thing I found interesting is that the problem is much much worse when I activate a scalling (720p --> 1080p) in ffdshow...
+is more present on 1080p mkv's than on 720p's
+is not present with mpchc dxva
+but is present( but in a lesser maner with mpchc's inbuilt x264 decoder (non dxva)
If anyone got an idea...
Thefabulousfab is offline
post #2704 of 7498 Old 12-28-2009, 09:24 AM
indieke2's Avatar
Btw,a I am re-instaling....Do we still need the 9.12 hotfix, if we DL 9.12 today? It release is set on 17/12, te hotfix was 16/12....
indieke2 is offline
post #2705 of 7498 Old 12-28-2009, 09:54 AM
winb83's Avatar
Quoted: 30 Post(s)
Mine is:
pioneer 1018 avr
win7 32 bits
I think its drivers. I'm trying to come up with a way to word an email to send it to ATI. I like my card and I won't get rid of it but this issue is disappointing. maybe they can fix this if it isn't some type of hardware limitation.
you and I have different cards in the same series and we're both having this problem. Snickerers has a different card in the same family with the 5850 and the problem is still there. I also know of another person who has a 5770 and has the same issue so this isn't some type of isolated thing different people across different HD5XXX cards are having this issue.
winb83 is offline
post #2706 of 7498 Old 12-28-2009, 10:09 AM
I think you'r right...
But I wanted to be sure about maybe the same avr or maybe the same version of win7 (32 versus 64bits) mine is 32
If everybody with the problem is on win7 32bit I could try a reinstall in win7 64 in a couple of days...
post #2707 of 7498 Old 12-28-2009, 10:19 AM
snickerers's Avatar
Mine is:
pioneer 1018 avr
win7 32 bits
Mine is:
XFX 5850
Intel X25-M G2 SSD for system drive
i5 750 with Gigabyte P55-UD3R
Onkyo RC180
Win 7 x64
tried 9.12, 9.11, and 9.12 hotfix, all have the problem
ATI hdmi driver and Realtek
I'm using shark007's codecs and various versions of ffdshow
I've also had a problem with passing Dolby Digital in Live TV and recordings. It either doesn't send the signal or just repeats the same one second of audio until I get the video error screen. Sometimes I can stop playing and resume and it fixes itself, but when that doesn't work I have to manually uninstall the hdmi driver and reinstall it to get it working again.
P.S. The 5850 is the only sound device I have enabled now.
snickerers is offline
post #2708 of 7498 Old 12-28-2009, 10:34 AM
our config are completely different... We will have to rely on ati on this one
Thanks for your answers...
post #2709 of 7498 Old 12-28-2009, 10:39 AM
winb83's Avatar
Quoted: 30 Post(s)
I have a dual boot. The problem is existent in Windows XP 32 bit though it seemed to be slightly less prevalent. I watched a few shows on there and had no issues at first but the issue randomly came up and didn't go away.
I don't think it has anything to do with your OS.
winb83 is offline
post #2710 of 7498 Old 12-28-2009, 10:44 AM
David602's Avatar
Originally Posted by Tulli View Post
Andy, I actually had made another Pioneer mod. Just checked it and it's fine.
Does this apply for owners of Xonar HDAV cards as well or is this limited to the ATI cards?
Intel I5 Haswell HTPC with KODI / Pio Elite VSX-01TXH / Sharp 60" LCD / Def. Tech Speakers / 10 TB HDD Arrays
David602 is offline
post #2711 of 7498 Old 12-28-2009, 11:09 AM
Tulli's Avatar
Quoted: 118 Post(s)
Liked: 103
It applies to HDAV1.3 cards as well but, frankly, it's surprising that the Pioneers have this issue with DTS MA bitstreaming with ffdshow on the Xonar too. I have no clue of what's going on there.
In fact, AFAIK Pioneer AVRs reportedly bitstream fine on PDVD9 and WinDVD10 without EDID override, so the problem/bug is ffdshow's exclusively & strangely enough, only for Pioneer AVRs???
I will do an experiment now. Will uninstall the EDID Override I use to bitstream PDVD9 with my Denon and see if WinDVD2010 works ...
Tulli is offline
post #2712 of 7498 Old 12-28-2009, 12:30 PM
ricabullah's Avatar
Check some of my experience with a Denon : (quoted from doom9)
Originally Posted by rica View Post
Hotfix results: (On a 1910 Denon AVR)
PDVD9:
No third option at all, it just gives core dts and ac3 for DTSHD and THD.
ffdshow 54:
THD:
gives only core ac3 with any renderer.
DTSHD-MA:
gives HD bitstreaming with Default Direct Sound Device.
So finally gonna restore to where i was before.
I think Xmas vacation has already begun for Ati guys but not for EDID stuff
So the current situation is:
Over Ati 5*** series (with-if needed- or without tulli's override monitor driver)
Seven:
Just with Ati 9.12 hotfix drivers:
DTSHD: no problem with PDVD9 and MPC-HC (ffdshow 54+ MPC Audio Renderer)
THD: No problem with PDVD9 and the best renderer is Ati HDMI Output for MPC-HC (with ffdshow 54)
Realtek 239 over 12 hotfix:
Both HD formats may use Default DirectSound Device.
Vista:
ffdshow HD bitstreaming only works with Ati 9.12 hotfix drivers by alone using MPC HC Audio renderer on Vista; Realtek 239 doesn't work.
While PDVD9 can work even Realtek 239 is loaded over 9.12 hotfix.
_ _ _ _ _
Chronical Tester
ricabullah is offline
post #2713 of 7498 Old 12-28-2009, 12:30 PM
Tulli's Avatar
Quoted: 118 Post(s)
Liked: 103
OK, guys, this is what I got (Win7 x64, Sapphire 5770, 9.12 Hotfix, Realtek 2.39, Denon 988).
  • EDID Override is ONLY required for bitstreaming on PDVD9. This is because of PAP surely.
  • Predictably , WinDVD2010 and MPC-HC bitstream DTS MA anyway. I got terrible audio drops with MPC-HC playing Quantum of Solace DTS MA but not at all with X-Men Last Stand . Tried TrueHD, no issues. Using Default DS audio renderer.
So, I guess we may safely conclude that WinDVD2010 just works, no matter what, and it's right now the way to go to safely bitstream on the ATIs. It requires NO EDID override at all on my setup, and this seems to be the case with Pioneer AVRs too.
As for ffdshow DTS MA bitstreaming seems to be still buggy somehow, as I got one BD playing fine & the other not. IMO the Pioneer issue is then related to this.
Pioneer ffdshow beta testers should hopefully solve this with Albain on the "ffdshow tryout project : HD audio discussion" thread at doom9.
Cheers.
Tulli is offline
post #2714 of 7498 Old 12-28-2009, 12:33 PM
Tulli's Avatar
Quoted: 118 Post(s)
Liked: 103
Interesting that you got no TrueHD bitstreaming without the EDID override. I could bitstream with both ffdshow54 and vladd's x64 compiled version (v49 I think), ...
Tulli is offline
post #2715 of 7498 Old 12-28-2009, 12:45 PM
ricabullah's Avatar
Haven't given it a go with an x64 version.
Chronical Tester
post #2716 of 7498 Old 12-28-2009, 12:51 PM
ricabullah's Avatar
To all Pioneer owners: (who have 4*** series cards as well)
You should give the EDID to tulli; just use your ex-4*** cards.
Chronical Tester
post #2717 of 7498 Old 12-28-2009, 12:57 PM
Tulli's Avatar
Quoted: 118 Post(s)
Liked: 103
Well, Rica, after last tests, and unless there're HDMI handshake issues, there should be NO need to override the EDID for Pioneers. AFAIK they already bitstream fine with PDVD9, right?
No, the problem with DTS-MA is exclusive to the ffdshow beta and it's a bug IMO, so it should be better worked out on the ffdshow/hd audio doom9 thread.
Tulli is offline
post #2718 of 7498 Old 12-28-2009, 01:00 PM
ricabullah's Avatar
Got it
Chronical Tester
post #2719 of 7498 Old 12-28-2009, 01:55 PM
ricabullah's Avatar
tulli, i'll try with 12/17 drivers as well, seem promising with their release notes.
But takes long time to download it
Chronical Tester
post #2720 of 7498 Old 12-28-2009, 02:15 PM
stanglx's Avatar
I have a 4870 X2 with a Pioneer SC05 with no issues at all - I am not bit streaming if you that is what you are getting at thought.. The RealTek driver fixed an issue with switching from one input to another and losing connection
stanglx is offline
post #2721 of 7498 Old 12-28-2009, 02:18 PM
SamuriHL's Avatar
I want to know if these drivers are REALLY any newer than either the regular 9.12 or 9.12 hotfix.
SamuriHL is offline
post #2722 of 7498 Old 12-28-2009, 02:53 PM
ricabullah's Avatar
Seems nothing has changed comparing with hotfix results; without tulli's override on Denon 1910 (just 12/17 drvers without Realtek 239 on Seven/64:
Code:
PDVD9:
ffdshow 54:
THD:
DTSHD-MA:
Anybody may confirm ffdshow doesn't work with THD on Xonar too without using tulli's override on any Denon? (just with 12/17 drivers or hotfix)
_ _ _ _ _
Chronical Tester
post #2723 of 7498 Old 12-28-2009, 03:02 PM
SamuriHL's Avatar
What about the driver version though?
SamuriHL is offline
post #2724 of 7498 Old 12-28-2009, 03:06 PM
SamuriHL's Avatar
@tulli
So you know how I've been fighting handshaking issues with my 606 for the past few weeks? It's not limited to the 5870 anymore. It would seem the 606 has a serious flaw and after about 12-14 months (seems I've been lucky I guess) the HDMI daughter board starts to fail. ARGH! Given the absolute HORROR stories I've been hearing about getting them repaired, and the fact that I refuse to be without a receiver for any length of time, it's possible I'm about to go receiver shopping this week. Oh yey. I had hopes of getting a digital camera but um, yea. I'll most likely be looking at Yamaha or Denon. I'm so NOT amused. Once I get the new receiver set up, I'll probably then fight the good fight with Onkyo to see if I can get the 606 fixed and put it in the bedroom for the 4850. hahahaha. In any case, the 606 is not making me happy right now at ALL. The sad part is I REALLY like this receiver. A lot!
SamuriHL is offline
post #2725 of 7498 Old 12-28-2009, 03:21 PM
ricabullah's Avatar
8.681 Date 12/17:
http://game.amd.com/us-en/drivers_ca...common-vista64
BTW without tulli but with Realtek 239 over 12/17 didn't work and gave the same results.
Chronical Tester
post #2726 of 7498 Old 12-28-2009, 03:25 PM
SamuriHL's Avatar
It's the exact same version number as the 11/24 driver from the hotfix.
SamuriHL is offline
post #2727 of 7498 Old 12-28-2009, 03:30 PM
ricabullah's Avatar
It's clear
Now i'm returning back to tulli's driver.
Chronical Tester
post #2728 of 7498 Old 12-28-2009, 03:32 PM
marsboer's Avatar
One question:
Is there a way to speed up the time it takes for the receiver/ATI-card to lock on to the bitstream audio (either Dolby Digital/DTS or HD-audio codecs)?
With my Pioneer BDP-51FD my receiver locks on instantly in each scene giving output immediatly, but for the ATI 5750-card in my HTPC it seesm like it needs to initialize the sound for each time the audio stops or switches. Like when I am hitting pause in blu-ray or DVD (using PowerDVD for BD and WMP12 for everything else).
Now I get a 2-5 second delay before sound is coming when using bitstream, I wan't it to be like my standalone player.
Is there a way to do this?
My receiver is Yamaha RX-V3900 but I doubt it is the problem as it has behaved flawlessly when connected to other standalone players. It's not that my 5750 is not working great today, but there is room for improvement.
marsboer is offline
post #2729 of 7498 Old 12-28-2009, 03:39 PM
SamuriHL's Avatar
Depending on what I get for a new receiver, I'll be needing one of those overrides myself. I'm TEMPTED to maybe got with a 607 as I really do like the Onkyos, but, do I dare trust them again? I don't know. The only Denon's I could find in my price range locally are all 5.1 which I don't want.
SamuriHL is offline
post #2730 of 7498 Old 12-28-2009, 03:41 PM
Tulli's Avatar
Quoted: 118 Post(s)
Liked: 103
Sorry to hear that, Samuri. I'm quite happy with my still "Made in Japan" Denon (current Denons aren't) so I expect it to last a little longer than that . It works wonderfully with the 5770 especially, with no handshake problems at all. It's also connected to a secondary HTPC with a 4670 with which it works fine too. Guess I'm lucky! (Oh well, there's the EDID override working great of course!)
Anyway, I would not dare to recommend you one, but if you could grab an older model with a MSRP ~$1K (this is what I did of course ... got my 2 years old model new for $599 free shipping) you'd certainly reduce the risk of being ripped off by getting one of those new cheap/full-of-features AVRs for ~$500.
Just my .02.
Tulli is offline
Reply Home Theater Computers
