Tearing solution for MPC-HC for all media types - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 09-15-2009, 01:44 PM - Thread Starter
costp's Avatar
Hello Guys,
I was having problems with MKV files using MPC-HC and Reclock to correct the Tearing problem on my HTPC, i then thinked about changing the display Refresh rate before launching MPC-HC to correct it.
That's why i made a small Batch file using MediaInfo and Display Changer to adapt the Refresh Rate of the Display according to a video file then launching this video file in MediaPlayerClassic-HomeCinema.
It allow to remove Tearing much better than Reclock does with MPC as this solution change the display setting before starting MPC-HC, allowing to correct the Black Screen problem.
To use it , extract the zip in your MPC-HC directory and launch your video by dragging them onto the "Refresh_MPC-HC.bat" Batch file. It will take care of everything.
Content of this Batch :
Code:
@echo off
rem Auto Refresh Batch Selector for videos files
rem Version for Mpc-HC
rem this Batch use the excellent MediaInfo and DisplayChanger
rem MediaInfo - http://mediainfo.sourceforge.net
rem Copyright (c) 2002-2009, Jerome Martinez, zen@mediaarea.net
rem DC (Display Changer) - http://www.12noon.com/displaychanger.htm
rem Copyright (c) 12noon
rem goto current batch directory 'here the mpc-hc.exe location'
cd /d %~dp0
rem minimize the current Dos window
min.exe
rem Retrieve the FrameRate information via MediaInfo and put it into %frames%
mediainfo --inform=Video;%%FrameRate%% %1 >  temp
set /P frames=
Please don't forget to adapt the nref in the if "%frames%"=="xx.xxx" set nref=yy lines....
You can also use the Windows function "Open this file with..." and then activate the "Always use this program".
I always use MPC-HC but you can of course modify the batch to launch anything you want in place.
Everything is included (DC and MediaInfo -- Folowing the Licenses).
Work Great with all Containers/Media Types MPC-HC nd MediaInfo supports... (avi,mpeg,mp4,mkv,divx...)
Download it here http://jump.fm/IYJCE
costp is offline
post #2 of 8 Old 04-18-2012, 04:42 PM
magicone_fr's Avatar
The file isn't available anymore, could you upload it again please?
magicone_fr is offline
post #3 of 8 Old 04-18-2012, 04:55 PM
assassin's Avatar
Quoted: 78 Post(s)
Liked: 241
This thread is 2.5 years old and he hasn't posted since the day of his first post.
assassin is offline
post #4 of 8 Old 04-18-2012, 07:39 PM
almostinsane's Avatar
Quoted: 47 Post(s)
Liked: 42
And you can just copy his code from the box.
almostinsane is online now
post #5 of 8 Old 04-18-2012, 08:26 PM
whiteboy714's Avatar
lol. Thread necro for real.
whiteboy714 is offline
post #6 of 8 Old 04-18-2012, 08:29 PM
ghostlobster's Avatar
Zombie thread!
Brrrrrrrraaaaaaaiiiiiinnnnnnssssss!
Ray
===Ghostlobster===
ghostlobster is offline
post #7 of 8 Old 04-18-2012, 09:58 PM
olyteddy's Avatar
Quoted: 523 Post(s)
Liked: 912
Got copy and paste? The batch file is right there in his post...
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
post #8 of 8 Old 04-19-2012, 05:23 AM
A zip with all the tools included would be easier but if nobody has it, I will try to get them from the net...
Reply Home Theater Computers
