Confused about color spaces - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 09-28-2009, 01:12 PM - Thread Starter
Glaucous's Avatar
Hello.
I'm using my computer as a HTPC. This is how the signal comes to my HDTV.
Windows 7 Media Player Classic Homecinema (configured at 16-235) ->
ATI HD4870 (configured at 16-235) via HDMI ->
Denon AVR-1909 (configured at 16-235) via HDMI ->
Finlux HDTV (which I assume is configured at 16-235)
I'm not sure if this is correct. It seems like the Black in movies is not the same black as the bars around it. I mean, at some point movies use the blackest black (16)? The black bars around created by MPC-HomeCinema, are blacker than the movie, always.
Should all of them be configured at 16-235, or maybe just one of them? I'm not sure how to make sense out of all this. I read this following post about it.
http://www.avsforum.com/avs-vb/showt...&&#post5386113
And downloaded the THX calibration JPEG, and ran it in MPC-HC. And when I view it, 16 - which I believe should be blackest black, is grey. Which should mean that either I misunderstood his post, which is very possible, or something isn't configured right?
If you have any good links about it, please post them, I'm right now running through the forum looking for a good way to calibrate it. I believe I might have missed some post, but I'm working on it.
Glaucous is offline
post #2 of 6 Old 09-28-2009, 01:35 PM
sotti's Avatar
Quoted: 331 Post(s)
Liked: 335
The ATI is compressing 0-255 into 16-235, so if you application is ouputting 16-235 then the ATI card is elevating the levels again.
If that is your intended usage scenario, oen up the ATI card to output full range 0-255, and then when the app outputs 16 the video card will also output 16 and live will be good.
sotti is offline
post #3 of 6 Old 09-29-2009, 12:54 AM - Thread Starter
Glaucous's Avatar
So, I would get the same results by setting MPC-HC to 0-255, and ATI to 16-235? This way my desktop won't look to bright/dark.
Glaucous is offline
post #4 of 6 Old 09-30-2009, 08:50 AM
mkedda's Avatar
good question, would like to see the final version of this.
mkedda is offline
post #5 of 6 Old 09-30-2009, 09:13 AM
mkedda's Avatar
Both options assume a tv/projector with 16-235 color space.
It would seem that RGB Full should be set if you are using HDMI because the interface itself will narrow the color range down to 16-235 by specification. So, setting RGB limited may result in obtaining a 32-219 color space due to the double colapse
However, if you are using VGA or DVI than you should use RGB limited because the dvi/vga spec is 0-255 and since the interface does not clip ranges you would want to make sure you send 16-235.
mkedda is offline
post #6 of 6 Old 09-30-2009, 11:46 AM
Rigby Reardon's Avatar
Not true. For RGB the HDMI specification specifically permits the use of PC levels:
Black and white levels for video components shall be either Full Range or Limited Range. YCBCR components shall always be Limited Range while RGB components may be either Full Range or Limited Range."
I would recommend setting the video card and display to studio levels simply to stay consistent with other CE devices that are used with the display. Of course double conversion by player software and video card should be avoided. If no shaders are activated, MPC-HC should leave the video levels alone.
Rigby Reardon is offline
Reply Home Theater Computers
