Good HTPC build? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 09-28-2009, 09:19 PM - Thread Starter
wolverin0's Avatar
I intend to use this solely for HD playback, MKV 1080p mostly (since my PS3... still... too much power for "nothing"), in the Guide to building an HTPC, in the comparison between the low ends, the AMD choise seems to be the best, but I don't know if its an updated guide, since I've read that DG45 mobos are geting updates constantly and improving performance. (The guide says: Updated August 1st 2008, and there have been many many DG45 updates)
Wich of this builds would you recommend me? (Please, avoid looking at prices, things are way expensive in Argentina...)
LOW-END:
AMD:
AMD ATHLON II X2 245 AM3 BOX 2.9GHZ 2MB 65W U$S81
20324 MB ASUS AM2+ M4A78-EM 780G GBLAN HDMI U$S 120
RAM: DDR2 2GB 800 Mhz Ocz Gold Edition Heatsink Blister U$S 35.89 ( x2? )
Codegen Horizontal 500w Usb Audio U$S 53.00
Wireless Encore Pci 54mps Wi-fi U$S 13.64
HDD 1tb 7200rpm Hitachi Desktar 7k1000.b U$S 98.45
U$S 401.98
or +
Amd Phenom X3 8650 2.3 Ghz Am2 Box U$S 109.75
U$S 430
Intel Pentium E5200 2.5/800 Mhz 2mb L2 U$S 89.50
MB INTEL DG45ID S-775 HDMI+DVI DDR2 B1333 MH 145.45
U$S 435.93
INTEL:
or+
20032 CPU INTEL CORE 2 DUO E7200 1066MHZ BOX 138.5
U$S 485.99
Should I get 4GB instead of 2GB? i'll be using Vista SP2 or Se7en, is it worth it? What about the processor upgrades?
Wich are the differences between DG45FC and DG45ID¿?
Sorry for this post (its a must for me...), and please help me choose wisely because i'm in a low budget since I've bought Muteki + Series 6 + PS3 this last year, and dont want to expend un-wisely a single dollar
* if you need some other info, please ask me
Thanks in advance.
wolverin0 is offline
post #2 of 3 Old 09-29-2009, 12:01 AM
diizzy's Avatar
I have the DG45ID motherboad and I'm very happy with it, keep in mind though that the IGP might leave you not fully satisfied depending on what you're expecting. The Intel chipset and LAN is a very solid combination which pretty much works with everything but the IGP lacks performance so you should get a pretty beefy CPU if you want to play 1080p without any issues. I'm not sure if it still doesn't support 24 Hz (I personally don't find it as a big deal as my TV doesn't support it) which may be an issue for you. In the end I added a Radeon 4670 which bumped performance quite a bit and gave gaming performance quite a boost. I'm also quite sure that the Intel board also supports stock voltage RAM (1.8V) which I highly doubt that the OCZ is.
You should really look for another PSU, Codegen are very bad and it'll most likely act up within a year or so.
The AMD solution is a better choice if you look at hardware acceleration out of the box but it still might not be enough. You should also have a look at the 785 series as they have a better IGP for video.
//Danne
diizzy is offline
post #3 of 3 Old 09-29-2009, 02:16 AM
zzyckz's Avatar
There's an updated guide to the newer hardware, look in here!
zzyckz
zzyckz is offline
Reply Home Theater Computers
