IR blaster on Imon VFD - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 09-30-2009, 10:40 AM - Thread Starter
Nate8727's Avatar
Does anyone know how to setup an IR blaster on an IMON VFD (thermaltake)?
I've got 2 tuners in a Windows 7 Ultimate setup (Tuners are different). I don't know how to setup the ir blaster. I have a separate usb MCE ir receiver/ir blaster, but that just repeats the remotes signals and isn't going to work. So how do you connect an IR blaster to a VFD so it can work with a Comcast HD-DVR (Motorola DCX3400)?
Also, how would I setup 2 tuners to do the ir blaster? I also have a Logitech Harmony 880 universal remote that controls everything.
I guess I'm just confused with the whole process all together.
Any help would be greatly appreciated.
EDIT:
If I can't control the STB, then would it be possible to just have 1 incoming cable connection to the STB, and then a splitter on the out of the STB with 2 connections going to the tuners on the HTPC? This way I can have all of my channels on the Comcast DVR, and my windows 7 setup, and that would give me 4 tuners total (2 STB, 2 HTPC). Or will it not let me do that?
Nate8727 is offline
Reply Home Theater Computers
