Why do DVD's display differently on my laptop than they do on my Plasma? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 10-23-2009, 08:08 PM - Thread Starter
kwitel's Avatar
Quoted: 39 Post(s)
To clarify; why are the black bars so much more pronounced on my laptop, which has a 16:9 screen than they are on my Plasma using the same exact DVD?
I am using my laptop to play a movie tonight and am connecting it to my Plasma. The black bars are HUGE. Any way to remedy this?
kwitel is offline
post #2 of 14 Old 10-23-2009, 08:22 PM
Bigbird999's Avatar
Tv and laptop specs andor link?
BB
New wealth is created in 2 ways:
You dig it from the ground (mining and oil)
Or you grow it (fishing, farming and forestry).
Everything else is just processing what you dug up or grew.
Bigbird999 is offline
post #3 of 14 Old 10-23-2009, 08:27 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 330
the TV is over scanning cutting off the picture all around, the laptop is not.
Joel Barsotti
SpectraCal
CalMAN Lead Developer
sotti is offline
post #4 of 14 Old 10-23-2009, 08:55 PM - Thread Starter
kwitel's Avatar
Quoted: 39 Post(s)
BB
TV is a 1080i Panny from a year ago. Laptop is a 1440x900 Dell Latitude.
This statement doesnt make any sense.
The TV isnt cutting anything off; the picture is too narrow when using my laptop and having it connected to my TV. Im trying to figure out why black bars are always more pronounced on my laptop and in turn, on my TV when I use my laptop as a DVD source.
kwitel is offline
post #5 of 14 Old 10-23-2009, 09:13 PM
K-Spaz's Avatar
TV is 16:9
Laptop is 16:10
K-Spaz is offline
post #6 of 14 Old 10-23-2009, 09:25 PM
Bigbird999's Avatar
Specs - ie Panny model # and laptop video card specs? Until then we are just guessing as to what corrective action is required.
BB
post #7 of 14 Old 10-23-2009, 10:03 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 330
1440x900, 900/10 = 90, 90x16 = 1440
laptop is 16:10 that's why the bars are much bigger on the laptop.
Fist caller got it right.
My guess is legit thought, especially since when I guess you had already incorrectly told us both were 16:9. A lot of movies are not 1.78:1 (16x9), but are 2.35:1 (star wars, lord of the rings, ect..)
A perfect pixel for pixel image of a 2.35:1 movie on a 16x9 screen
But HDTV's scale and crop images by 5% to a safe area (unlike PCs)
So even if you have a 16x9 laptop, unless you knew to put your plasma in pixel perfect mode, you would have smaller black bars on the TV.
Joel Barsotti
SpectraCal
sotti is offline
post #8 of 14 Old 10-23-2009, 11:02 PM - Thread Starter
kwitel's Avatar
Quoted: 39 Post(s)
BB
Panny TH-50px75u
Laptop is using and Intel video card (no idea which one)
Understood; thanks for the clarification.
So when I use my laptop as a source, is there anything I can do on the laptop or TV to minimize those bars?
Finally, what is "pixel perfect mode"?
kwitel is offline
post #9 of 14 Old 10-23-2009, 11:22 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 330
Originally Posted by kwitel View Post
Panny TH-50px75u
no you want the big bars anyway. That is the full image.
You should find the control and put it into native/pixel perfect/dot by dot mode.
Joel Barsotti
SpectraCal
sotti is offline
post #10 of 14 Old 10-24-2009, 09:12 AM - Thread Starter
kwitel's Avatar
Quoted: 39 Post(s)
This is the part I dont undertsand. How do I put it into "native/pixel perfect mode"?
kwitel is offline
post #11 of 14 Old 10-24-2009, 11:49 AM
Bigbird999's Avatar
The TV is a 1366x768 native resolution and that is what you should feed it. . How are you connecting from laptop>TV? (HDMI, VGA, DVI)? I'm not sure if the panny will accept the native resolution over HDMI, if it does not, then feed the standard HD resolution, 1280x768. And set your tv to 'Just scan' or 'dot for dot' to get 1:1 pixel mapping.
BB
post #12 of 14 Old 10-24-2009, 12:19 PM
jreese831's Avatar
Look through your TV's menus; it should be in there somewhere.
"Two possibilities exist: Either we are alone in the Universe or we are not. Both are equally terrifying." - Arthur C. Clarke
jreese831 is offline
post #13 of 14 Old 10-24-2009, 01:12 PM - Thread Starter
kwitel's Avatar
Quoted: 39 Post(s)
BB
I am going from my Laptops "DisplayPort" out to HDMI (via a converter).
What im not getting is the whole "feeding" thing. How exactly do you "feed" 1280x768 vs. any other resolution setting? Is that on the computers end or the TV's end?
As for the TV "scanning" or doing "dot for dot"-I have to find that...
kwitel is offline
post #14 of 14 Old 10-24-2009, 01:37 PM
walford's Avatar
Not all 1366x768 HDTVs will accept 1366x768 or 1360x768 over HDMI or component since it is not an ATSC standard resolution they may accept it over VGA and if they do accept it over VGA they do not overscan it. Your laptop should have a standard 15 pin VGA type output connector in addition to whatever it is you are calling "display port"
walford is offline
Reply Home Theater Computers
