Hauppauge 1250 remote question - AVS | Home Theater Discussions And Reviews
post #1 of 4 Old 10-25-2009, 08:09 PM - Thread Starter
costco_buyer's Avatar
I am about ready to pull the trigger and place the order for the components for my new HTPC.
I will get the Hauppauge 1250, but was wondering if the included remote was any good for controlling MCE (win7). Does anybody have any experience with this? Or should I buy the Anyware GP-IR01BK in addition?
Also, the 1250 will be capable of displaying / let me record both Clear QAM stations and SD content with win7 MCE, correct?
Thanks for any last moment advise, I don't want to make a mistake and miss anything, or end up buying too much!
costco_buyer is offline
post #2 of 4 Old 10-25-2009, 10:14 PM - Thread Starter
One more question: how does the 1250 compare to the 1800? Is it better to have two tuners: one analog / one digital vs. one tuner for analog & digital in the 1250?
Thanks a lot for any help, I am planning on placing my order tomorrow.
post #3 of 4 Old 10-26-2009, 08:17 AM - Thread Starter
Anybody?
I think I found the answer to the remote question: if I get the 1250, I'll need another remote, as what comes with the tuner card is not really a MCE remote.
But what about the 1800 vs. the 1250? Is it true that when using the 1800, I would need an external splitter before going into the card (my analog & digital channels come through the same coax out of the wall)? I don't like that idea, because I already will have to split the signal between TV and HTPC, and I am concerned about the signal strength. I did have some signal strength problems in the past.
post #4 of 4 Old 10-26-2009, 08:19 AM
mike_311's Avatar
i have two 1250s, the remote that comes with only controls the card, not MCE, you need an ir receiver that plugs into a usb in order to control MCE.
"If the world didn't suck, we'd all fly off."
mike_311 is offline
Reply Home Theater Computers
