GeForce GTX-275 Questions - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 10-26-2009, 08:55 AM - Thread Starter
lcole's Avatar
I am putting together a workstation/HTPC and I am planning on using a GeForce GTX-275. I will have dual monitors for this system which will be using the two DVI outputs to run these. Many manufactories also have a TV-Out (s-video or HDMI) but I cannot find any information pertaining to the use of this port. Is it a separate output? Does it mirror what is displayed on DVI 1, 2 or both? Can all three outputs be used simultaneously?
Anyone that has experiance with this card, your input and comments would be appreciated...
Have a great day!
Lance
lcole is offline
post #2 of 8 Old 11-03-2009, 08:14 AM - Thread Starter
lcole's Avatar
Follow-up - I went ahead and got the ASUS GeForce GTX-275. Here is what I found out about the three outputs on the card.
The card does have three outputs - (2) DVI and on the ASUS (1) S-video/Component. However, ONLY ANY TWO CAN BE USED AT ANY GIVEN TIME. The S-video/Component (Y,Pb,Pr) out is not the best and only supports 4:3 at low resolution. So it is basically not a useful feature.
On the upside the GTX-275 is great!
lcole is offline
post #3 of 8 Old 11-03-2009, 08:47 AM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 332
DVI is pin compatible with HDMI
The GTX275 has dual TDMS so you can drive two different HDMI displays up to 1080p60.
You just need http://www.newegg.com/Product/Produc...82E16812105832
or a cable that goes DVI to HDMI.
Joel Barsotti
SpectraCal
CalMAN Lead Developer
sotti is offline
post #4 of 8 Old 11-03-2009, 08:57 AM
Derek K.'s Avatar
that isn't correct. the component output will almost any resolution or aspect ratio.
Derek K. is offline
post #5 of 8 Old 11-03-2009, 10:15 AM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 332
svideo is locked to 4:3, but all svideo is, since it is by deffinition 720x480i, with the video card scaling all other choices to 720x480i.
Joel Barsotti
SpectraCal
sotti is offline
post #6 of 8 Old 11-03-2009, 10:27 AM
Derek K.'s Avatar
svideo sure. the component video output doesn't have that limitation, though.
Derek K. is offline
post #7 of 8 Old 11-03-2009, 10:45 AM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 332
right.
Joel Barsotti
SpectraCal
sotti is offline
post #8 of 8 Old 11-03-2009, 11:14 AM - Thread Starter
lcole's Avatar
Thanks for the replies...
I am using the two DVI to drive a DVI computer monitor and a HDMI to my video system. I was intending to also use the S-video/Component out to drive an older TV that only has component inputs but limited to two at a time...
Derek K. Thanks for your post. I went back and set the older TV up again and it does have full range of resolutions and aspect ratios. On my original attempt I had tried an S-video cable first and it was limited as stated in my follow-up post. However when I switched to component adapter only the s-video options were still displayed. Today I used the component and a full range of options are now available. Thanks!
I still have the problem of only two outputs so a second video card is in the near future...
Any suggestions for that second card? Will drive older TV only.
lcole is offline
Reply Home Theater Computers
