Need HDTV Tuner Compatible with Time Warner - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 11-04-2009, 01:53 PM - Thread Starter
abar20's Avatar
I just built an htpc with windows 7 and an amd msi motherboard with hdmi out. I have time warner cable in los angeles. What can I do to start DVR on my pc.
My guess: -By a TV tuner
-install it in pci slot
- plug in my cable cord
-start recording with windows media center's record function?
If so, what the cheapest way to go about doing this?
PS: is there a way to get around the encrypted channels non clear qam format.. for instance the 'movie' channels?
abar20 is offline
post #2 of 5 Old 11-04-2009, 02:39 PM
Ecidious's Avatar
You'll need to get an HD-PVR (http://www.hauppauge.com/site/products/data_hdpvr.html) and a cable box that outputs via component if you need something right now. Otherwise with a basic tuner you might as well ditch the cable and just put an antenna up on your roof to get OTA HD because you'll probably only be able to get the same local channels in clear-qam anyways.
The new Ceton cable card tuner in Q1 2010 could also work if you're willing to wait, but I have some doubts about it being able to record some channels.
Ecidious is offline
post #3 of 5 Old 11-04-2009, 04:51 PM
Scott231's Avatar
You have several tuners to choose from. It depends on what type of signal you receive (include OTA captured via antenna or cable or dish) and how many tuners you want. Several nice dual tuners are listed on the infamous "page 85" tables.
The HD-PVR requires you to have a set top box and you do not need an internal tuner in your PC. Going this route allows you to capture many more channels (including premiums).
That being said, the cheapest route is a single tuner card ~$50. Dual tuners will double that. Capturing the premium movie channels requires monthly rental of a STB and an HD-PVR at ~$200.
HTH
Scott231 is offline
post #4 of 5 Old 11-04-2009, 05:55 PM
jrwalte's Avatar
FYI,
If all you need is ATSC/QAM, the AverMedia dual tuner A188 is only around $60.
jrwalte is offline
post #5 of 5 Old 11-04-2009, 09:49 PM
setherd's Avatar
HDhomerun FTW!!!
but if you want your encrypted stuff you need a HD-PVR until they release the update to allow OEM sales of ATI cable card tuners.
Take care,
Seth
AMD 5000+BE @2.6GHZ 2GB ram, 820GB storage
Gigabyte GA-MA78GM-S2H 780G chipset
Nvidia DualTV, HDHomerun, MCE keyboard and remote. SageTV
setherd is offline
Reply Home Theater Computers
