ATI TV Wonder Digital Cable Tuner - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 11-11-2009, 11:28 AM - Thread Starter
Sundance's Avatar
Has anyone been able to get this to work on their HTPC? From what I am reading the restrictions are starting to loosen up a bit.
IMPORTANT NOTICE!!!!
Microsoft recently removed the requirements for Digital Cable TV Service with release of Windows 7. Now with Windows 7 and compatible hardware, you can install an ATI Digital Tuner and start receiving HD Protected Cable TV content into your Media Center PC!
http://www.engadget.com/2009/09/09/m...m-requirement/
Sundance is offline
post #2 of 9 Old 11-12-2009, 08:49 PM
MeowMeow's Avatar
Which exact model are you running?
I just did a Win7 install, and when I ran update it had no problem installing my HDTV Wonder 650.
MeowMeow is offline
post #3 of 9 Old 11-12-2009, 10:03 PM
Aricept's Avatar
I bought one a couple days ago after reading the blog at anandtech. It's the internal version that is powered by a floppy connector. It connects either to an external USB port or internal header. You have to provide the cable for whatever one you choose. It also didn't come with the daughter card for composite/svideo input that is shown in the manual as optional.
Windows 7 downloaded the Microsoft app and approved Win7MC for cablecard use. I then installed the card and Microsoft Update provided the lastest driver. Then the driver updated the firmware on the card to update support for SDV and the copy freely flag.
I'm waiting for Comcast to come out with the actual Cable Card in a few days, but I'm using it as a NTSC, ClearQAM tuner until then. It's a hybrid design using a 550 for the analog half. Oddly enough my signal on the coax was too hot and was giving me dropouts on certain stations. My previous Nvidia (analog) and Avermedia Duet (ClearQAM) never had issues with the signal strength. After installing an attenuator the card is working perfect. I haven't tried ATSC, but it is supported.
I could just be seeing things, but I think my old Nvidia dual tuner analog card has a slightly better analog picture than the ATI, but it could just be me imagining things. No difference in the digital realm like you would expect.
Anyway, I figure I'll play around with the card and eventually buy a Ceton 4 tuner card when they are released next year.
Aricept is offline
post #4 of 9 Old 11-13-2009, 07:42 AM
Scallica's Avatar
Welcome to last week...please search before posting.
http://www.avsforum.com/avs-vb/showthread.php?t=1194491
HTPC Enthusiast
Scallica is offline
post #5 of 9 Old 09-28-2012, 02:39 PM
racprops's Avatar
Quoted: 26 Post(s)
The truth about ATI’s Wonder Digital Cable Tuner:
This is what I found and was told:
These were NEVER meant for retail sales.
These were made for HP and DELL SPECIALLY PREPAIRED Computers.
These are OEM Products for HP and DELL ONLY (which is why they come in brown boxes.)
They will NOT WORK with many cable systems that use switched channels, as there is no input for the tuner adaptor you need for these channels. (Cox in Phoenix AZ for one.)
There is NO SUPPORT from ATI/AMD.
Getting Media Center to “see” the box is a hard fight.
Getting any real idea of what will work is next to impossible, I did hours of research on the internet and found almost no info.
After a bunch of calls to ATI/AMD I reached a second level tech support and a tech whom was with ATI Before being bought by AMD and he said:” These were NEVER meant for retail sales. These were made for HP and DELL SPECIALLY PREPARED Computers. These are OEM Products for HP and DELL ONLY (which is why they come in brown boxes.) That he felt they were basically incompatible with Windows 7 and most cable systems now in use. That the techs at ATI were NEVER given ANY training on them. That there is NO SUPPORT WHAT SO EVER!!”
I spent hours working and searching for help installing and setting this up, I had to buy a upgraded video card as Win 7”s cable adviser would not pass my video card, only to get media center to finely “see” the box to then be unable to turn on the card and could not hook up to the cable provide tuner adapter due to not having a USB input on the ATI Box.
This being the only site with ANY information, and it is light...
I do not know as no one I talked with could say IF it will “see” and use the dual tuner card I received from the cable company.
My advice, skip this misbegotten POS and either get a full time cable box from your provider, or a much better cable card for your computer, this is not worth the trouble even at $29.00 I paid.
Rich
racprops is offline
post #6 of 9 Old 09-28-2012, 04:51 PM
signcarver's Avatar
If you had posted this two years ago, I could understand your rant but they pretty much have been discontinued for 2 years (support ceased April 1, 2010, I believe most of the computer companies stopped in 2008)
The tuning adapter plugs into the computer not the ATI DCT and there are windows 7 drivers for the cisco ST1520 tuning adapter I haven't tried them with an ati since the firmware has been updated in them but from what I have heard from others it does work but may require an occasional reset
The product has been dead for years, why should there be
This shouldn't be as I know a few people still using them however with them being "used" and much tech sold today isn't meant to last 3 years many are broke... The hardest part should be passing the DCA and getting the card paired... My understanding is they are supposed to work with the new "M" cards but I believe they worked better with the old S cards but now cable providers are required to provide m cards but may have a few s cards available for older devices.
You should have done more research prior to buying and you would have known they have been "dead" for 3 years, I suggest the thegreenbutton.tv (whch is an attempt to win back people from the old thegreenbutton.com which is now windows expert exchange but should still resolve properly, and many abandoned it after the switch), Also in your search, ATI DCT will probably post more results than ATI Digital Cable Tuner.
This has been known for years so isn't new however there were a few more companies that also had them other than just hp and dell (sony for one) and there was never meant to be support from ati as the computer manufacturers (HP, Dell, Sony) were the ones who would be giving support.
Rich
I mentioned two sites above you will probably get better results for the ATI DCT. There are ways to pass the DCA with lower end hardware, however with cox phoenix and nearly everything being marked copy once, usually the best it can do is record and serve to an xbox without the "upgrade" to your display/videocard to get a protected display path but requiring a protected path has been known for years about cablecard tuning. As far as skipping it, I agree with applying that advice to the ATI DCT as it had been abandoned years ago. Your choices now are Ceton, SD, or if on a budget perhaps the Hauppauge DCR-2650 (stripped down usb version of SD's prime) and I think all are better than cox's cable boxes. Another thing "bad" about the ATI in the cox market is that it isn't a 1GHz tuner so it can't tune the plus pack channels which is a real plus over the cox boxes (unless you have the WHDVR setup).
signcarver is offline
post #7 of 9 Old 09-28-2012, 08:17 PM
Andy_Steb's Avatar
Quoted: 31 Post(s)
Liked: 158
Racprops, you do know that you are responding to a thread that is 3 years old.
Andy_Steb is offline
post #8 of 9 Old 11-10-2012, 10:43 AM
tommyts's Avatar
The post may be 3+ years old, but your your reply helped me out, so I just wanted to say thanks. I've had my ATI DCT for 5 nearly-trouble-free years now, essentially as soon as they were introduced... and it appears it may have finally given up (not real sure though, but can't spend more time diagnosing and trying to repair myself).
tommyts is offline
post #9 of 9 Old 11-13-2012, 09:43 AM
blueiedgod's Avatar
Quoted: 254 Post(s)
Liked: 94
I too used ATI DCT since day one, until Ceton arrived on my door step in 2010. I had 2 of them, and they worked fine with the Tuning adapter from Time Warner, and Verizon FiOS prior that.
Sometime in 2010, Verizon changed to Symulcrypt, but since AMD/ATI abandoned ATI DCT's there was no update to the drivers to include symulcrypt. They still work with Cable, but won't work with most FiOS set ups.
Most of the stuff in racprops post is true, i.e. they were not intended to retail sales, but the reas is just pure BS.
6 TV's in the house on FiOS and we only pay $4.99/month to connect them all!!! Power to the CableCard and WMC7!!!
blueiedgod is offline
Reply Home Theater Computers
