Building a New HTPC (Feedback Please) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 11-12-2009, 07:44 AM - Thread Starter
roadrunner75's Avatar
I am building my first HTPC. I want to store and play dvd and blu ray movies. I also want to keep this build under $500. Any and all comments are welcome.
Current Total: $481.93
1 GIGABYTE GA-MA785GPMT-UD2H AM3 AMD 785G HDMI Micro ATX AMD Motherboard
$94.99
1 PC Power and Cooling Silencer PPCS370X 370W ATX12V 80 PLUS Certified Active PFC Power Supply
$39.99
1 Western Digital Caviar Green WD15EADS 1.5TB SATA 3.0Gb/s 3.5" $109.99
1 LITE-ON Black 4X Blu-ray Reader SATA Model iHOS104-06
$59.99
1 APEX TX-381-C Black Steel Micro ATX Tower Computer Case
$24.99
1 OCZ Obsidian 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model OCZ3OB1600LV4GK
$78.99
1 AMD Athlon II X2 245 Regor 2.9GHz Socket AM3 65W Dual-Core $66.00
or maybe this processor
AMD Athlon II X3 425 2.7GHz Socket AM3 95W
roadrunner75 is offline
post #2 of 10 Old 11-12-2009, 07:51 AM
IAM4UK's Avatar
Quoted: 76 Post(s)
Liked: 81
Case may not be important to you; however, it is typically important for HTPC. If you think you will want a good case that will look at home in a stereo setup, consider getting such a case with your initial build.
Also, you did not mention television recording (DVR) as a function you seek in your HTPC. It is a very useful feature of HTPC for many...something you may also consider.
Your costs may increase a bit, as you have identified no input device nor operating system.
A.L.a.E.o.t.U.S., as proven 3/21 - never forget.
Defend liberty.
Knowledge isn't Truth; it's just mindless agreement.
IAM4UK is offline
post #3 of 10 Old 11-12-2009, 08:10 AM - Thread Starter
The case I want cost too much so I am going with the cheapest case I can find for now and upgrade later.
I would like to get television recording at some point but my budget does not allow it at this point. I will hold off on this for a future upgrade.
I will be using windows 7 as my OS. I already have it. I have not decided on whether to use the 32 or 64 bit OS though.
I already have wireless keyboard and mouse. I will get by with this for now.
post #4 of 10 Old 11-12-2009, 09:52 AM
Servicetech571's Avatar
Tuner cards don't have to be expensive. I'd drop the memory to 2GB and use the difference to buy a tuner card. The DVR is our most used function of the HTPC.
Also, keep in mind a 32bit OS can't see all of the 4GB memory.
Servicetech571 is offline
post #5 of 10 Old 11-12-2009, 11:19 AM
spivonious's Avatar
To add to the reply above, 2GB of RAM is plenty for an HTPC. I'd also not waste money on a faster processor unless you plan to do lots of transcoding (such as ripping DVDs).
spivonious is offline
post #6 of 10 Old 11-12-2009, 12:01 PM
Java Jack's Avatar
$94.99
$39.99
$59.99
$24.99
$78.99
Here are a couple of blogs I put together on HTPC builds.
http://links.amd.com/Build1
http://links.amd.com/Build2
They might help.
Regards.
Java
There are 10 types of people in the world, those that understand binary, and those that don't.
AMD@Home Blog: http://links.amd.com/Home
Twitter: http://twitter.com/Java_Jack
Java Jack is offline
post #7 of 10 Old 11-12-2009, 12:49 PM - Thread Starter
I have read that playing blu ray movies takes a lot out of your processor. They recommended at least a dual core.
post #8 of 10 Old 11-12-2009, 12:59 PM
mike_311's Avatar
you may want to lok at a another smaller HDD for the operating system. the WD green is only 5400 rpm and while great for media storage (i have one), you may take a performance hit with the slower drive.
"If the world didn't suck, we'd all fly off."
mike_311 is offline
post #9 of 10 Old 11-12-2009, 01:13 PM
Java Jack's Avatar
While it can hit a CPU hard, if you have a graphics chip/chipset that supports hardware acceleration, it does not hit it hard at all.
However, I still recommend dual core or higher for HTPC stuff.
Regards.
Java
post #10 of 10 Old 11-12-2009, 01:18 PM
Java Jack's Avatar
Actually, in my discussions with Seagate and WD, they have both optimized their drives for streaming content. They have tweaked the f/w on their drives so that it improves content recording and playback. They modify how it groups data blocks for storage and retrieval. You should not see too big a hit in performance. While I don't have any benchmarks, I have not observed any issues when using these type drives in an HTPC. However, that is all anecdotal and I don't have any hard benchmarks to back that up (at least none that I can share without violating NDAs)
Now, for gaming, etc. faster drives will perform better but I think it may be less important for an HTPC box.
Regards.
Java
Reply Home Theater Computers
