Auzentech Prelude - Intermittent audio problem during video playback - AVS Forum | Home Theater Discussions And Reviews
Old 11-14-2009, 12:26 PM - Thread Starter
msthilaire's Avatar
I have been struggling with an issue with my Auzentech X-Fi Prelude 7.1 card and was hoping someone would be able to help here.
The problem occurs during video playback only, essentially my receiver seems to lose the SPDIF signal for a second or so. The sound is perfect otherwise, but every few minutes it just cuts out for a couple seconds.
This happens while watching video over the internet ( hulu, etc ) and also while watching DVDs as well as downloaded videos. This also happens during audio playback with Pandora, etc.
I don't think it is affecting the analog output, so it's either my receiver getting confused, or the audio card outputting strangeness to the SPDIF output ( which confuses the receiver ). During the periods where it cuts out, the 'DTS' light on my reciever cuts out.
I was just actually playing with it during this post, and now I can't get any audio to come out of SPDIF at all. I'm pretty sure the drivers are at fault here, they haven't been updated in 4 months from what I can tell.
Any one have any tips/help on this?
Been scouring the web for hours for help, tried a ton of stuff, but nothing seems to solve the problem.
MY SETUP:
I'm running Windows Vista SP2 and the latest drivers from Auzentech 6.0.1.1283.
I have a Denon AVR 3805 Receiver, and the card is hooked up via the optical port to the SPDIF port.
In Windows, I have the default playback device set to 'Speakers' ( changing it to SPDIF Out as the default does not help ), and my configuration is set to 5.1 Surround.
If I click on SPDIF and look at the properties, I have DTS Audio and Dolby Audio checked off, along with 96khz as the sample rate.
I have it set to 'entertainment mode', with SVM set to off, EAX off, CMSS off, crystalizer off, Encoder set to DTS.
msthilaire is offline
Old 11-14-2009, 12:42 PM - Thread Starter
msthilaire's Avatar
One more bit of detail, if I turn off DTS encoding, the problem doesn't seem to occur at all, but of course thats one of the main reasons I wanted this card, the DTS sounds pretty awesome.
Similar problems with Dolby Digital as well
Old 11-15-2009, 04:33 PM - Thread Starter
msthilaire's Avatar
Does anyone have one of these cards, and can you get DTS to work?
