Static, then Freeze on HTPC - AVS Forum | Home Theater Discussions And Reviews
Old 11-29-2009, 05:49 PM - Thread Starter
Mike Alt's Avatar
My HTPC is unstable. It freezes once every couple days when I leave the tuner on with Live TV (whether TV is off or on). Interestingly, the image is frozen and appears static-y and the Dolby Digital symbol on my receiver flickers on and off. Everything is unresponsive (Ctrl-Alt-Del, Mouse, Remote) and the only solution is to do a hard reset. Processors are at 25% and 42% usage when I have one recording going and I'm watching another channel.
Any suggestions to trouble shooting? Drivers? Components? Temperature?
My system:
* Windows 7 64-bit
* Motherboard: Gigabyte GA-MA785GMT-UD2H
* Processor: AMD Athlon II X2 240 Regor 2.8GHz Dual-Core (ADX240OCGQBOX)
* RAM: OCZ Obsidian 4GB (2 x 2GB) DDR3 1600
* HD: Western Digital Caviar Green 1TB (WD10EADS)
* DVD: LG DVD Burner GH22NS50
* Case: Antec FusionRemote 350 Micro-ATX
* Tuner: AVerMedia AVerTVHD Duet Tuner A188 PCI-e
* Wi-Fi: ASUS WL-138g V2 PCI Wireless Adapter
Mike Alt is offline
Old 11-29-2009, 09:43 PM
byingtonr's Avatar
What version of the ATI Catalyst drivers are you using? I experienced a similar problem with drivers newer than 9.8.
byingtonr is offline
Old 12-04-2009, 05:59 AM - Thread Starter
Mike Alt's Avatar
Sorry for the delay, long work week...
ATI Radeon HD 4200 driver version: 8.6410.0
Catalyst Control Center version: 2009.0730.58.43017
Mike Alt is offline
Old 12-04-2009, 10:14 PM - Thread Starter
Mike Alt's Avatar
Any suggestions? Where should I focus? Faulty hardware or drivers?
I've read complaints about the RAM, so I'm tempted to return it and try a different brand.
Mike Alt is offline
Old 12-05-2009, 02:55 AM
pavelkolp's Avatar
I would double check your case and make sure everything is grounded properly, make sure that you didnt overtighten your MB screws, I would probably try to update BIOS on motherboard maybe do a manual timing set up on the ram, go buy a diffrent set of ram, dont buy the extreme gaming ram bs you will have problems if you wont set up the timing correctly there is a few possible issues if you want add me on msn pizzaguys2006@hotmail.com I will help you resolve the problem.
pavelkolp is offline
Old 04-29-2010, 09:12 PM - Thread Starter
Mike Alt's Avatar
Sorry to revive an ancient post, but wanted to bring closure. I lived with 1-2 reboots per night, finally got sick of it, and fiddled with RAM settings for hours. Ultimately, I found a combination that's been going for 2 weeks without a hitch!
Problem was that my motherboard and RAM weren't immediately compatible. After I updated the GA-MA785GMT-UD2H BIOS with the following details, the OCZ3OB1600LV4GK RAM stopped causing crashes:
> MB Intelligent Tweaker <<br /> Memory Clock: [x5.33] 1066Mhz
System Voltage Control: [Manual]
DDR3 Voltage Control: [+0.100V] 1.700V
CPU NB VID Control: [+0.175V] 1.3500V
>> DRAM Configuration [Enter] <<
DCTs Mode: [Unganged]
DDR3 Timing Items: [Manual]
CAS# latency: [7T]
RAS to CAS R/W Delay: [7T]
Row Precharge Time: [7T]
Minimum RAS Active Time: [24T]
Mike Alt is offline
