Need cheap IR receiver + cheap wireless keyboard - AVS Forum | Home Theater Discussions And Reviews
Old 12-10-2009, 11:58 AM - Thread Starter
scsnospam's Avatar
I've placed an order for a Dell Zino. I have a Harmony remote, but need a USB based IR receiver, as well as some kind of wireless keyboard with built in trackpad or trackball for very light use in my htpc setup.
Any recommendations?
scsnospam is offline
Old 12-10-2009, 12:07 PM
MegaHurtz83's Avatar
I believe this should work for your USB receiver
http://www.amazon.com/Windows-Contro...0471902&sr=1-3
I use a similar one in my HTPC setup and it works beautifully.
LG 55" LED TV // Onkyo TX-SR705 // Custom MediaPortal HTPC // Toshiba Blu-ray and HD-DVD // Shaw 1TB DVR // Logitech Harmony 1100 remote // Wharfedale Diamond 5.1 audio
MegaHurtz83 is offline
Old 12-10-2009, 12:18 PM
avekevin's Avatar
Would this work also? It seems to include both an IR transmitter and receiver.
http://cgi.ebay.com/HP-MCE-USB-IR-RE...%3D4%26ps%3D63
avekevin is offline
Old 12-10-2009, 01:41 PM - Thread Starter
scsnospam's Avatar
Thanks for the quick replies. Ordered one already !!
Old 12-10-2009, 02:21 PM
bryansj's Avatar
Quoted: 1142 Post(s)
Liked: 562
This is what I use with my Harmony 890. I also have a wireless mouse and keyboard for my HTPC, but I find that I rarely use them. Most of the time I just use remote desktop from my laptop to connect to the HTPC.
bryansj is offline
Old 12-10-2009, 02:37 PM
avekevin's Avatar
How does the transmitter part work? I'm not sure where it plugs in - I don't have a mini jack port for it....
Kevin
avekevin is offline
