FFmpeg/ffdshow ISO MPEG-4 codec - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 12-13-2009, 08:54 AM - Thread Starter
JimB0b123's Avatar
Hi all,
I've downloaded a file from: http://www.bigbuckbunny.org/index.php/download/ that I wish to play.
If I run the file through GSpot, it says the CODEC that I need (and is not installed) is: Fmpeg/ffdshow ISO MPEG-4 or FMP4.
A quick google search will point me to plenty of codec packs and players but all I want is the single CODEC.
Has anybody else encountered this before?
JimB0b123 is offline
post #2 of 6 Old 12-13-2009, 09:45 AM
buzzqw's Avatar
XviD decoder should be able to handle this
ffdshow is a better choice
BHH
HDConvertToX, AutoMKV, AutoMen, AutoX264 developer, Panasonic P46G10, Htpc, Chromebox with openelec, PS3, Yahama 663, dune smart h1, nuc sandybridge, rpb1, rpb2, odroid-x....
buzzqw is offline
post #3 of 6 Old 12-13-2009, 11:51 AM - Thread Starter
JimB0b123's Avatar
I already have Xvid and unfortunately, it doesn't.
As for FFDShow, I don't want to use any codec packs.
Thanks for your help anyway.
post #4 of 6 Old 12-13-2009, 12:00 PM
buzzqw's Avatar
when you install xvid (i suggest to use the Koepi build's) you have the possibility to decode all mpeg4 formats..
maybe worth a try to reinstall xvid
BHH
buzzqw is offline
post #5 of 6 Old 12-13-2009, 12:53 PM - Thread Starter
JimB0b123's Avatar
I'm using this version:
http://www.koepi.info/xvid.html
There wasn't any option for enabling all MPEG4 codecs.
I managed to get the file to work in DirectShow by changing the FourCC to XVID.
However, after reading your post, I decided to open the "Configure Decoder" option in the start menu and now I am getting an error about opening the ax file for it. Is this a Windows Vista 64 bit error (file paths different or something?).
Ps. I've just (after replying) rerun the installation of Xvid. I see what you mean, I enabled the all options tickbox. The configuration option in the start menu still doesn't work, but I think that's because the xvid.ax file is stored in the syswow64 folder instead of perhaps the system32 folder. Would it just be a simple case of moving the file and reregistering it?
post #6 of 6 Old 12-13-2009, 01:45 PM
buzzqw's Avatar
yes, moving and registering again should do the trick
BHH
buzzqw is offline
Reply Home Theater Computers
