LG Blu-ray drive stopped reading Blu ray discs - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 12-17-2009, 11:31 PM - Thread Starter
powersbw's Avatar
I have a LG GGC-H20L drive, 1.03 firmware, using windows 7. This drive played Blu-ray discs flawlessly as recent as last Friday, but today when I tried to play 2 different Blu-ray discs, the drive isn't reading the disc. I have AnyDVD HD, and even that doesn't recognize that there is a disc in the drive. Regular DVDs play fine.
Has this happened to anyone? I suspect the Blu laser crapped out on me, but wanted to post for suggestions before I ran out to get a replacement.
powersbw is offline
post #2 of 5 Old 12-18-2009, 12:06 PM - Thread Starter
powersbw's Avatar
To add a little extra detail: when I put a Blu-ray disc in the drive, the blue light flashes for 3-4 seconds, and then nothing happens. Again, regular DVDs play without issue.
powersbw is offline
post #3 of 5 Old 12-18-2009, 02:10 PM
spivonious's Avatar
Can you try it in another PC? Just to narrow it down to the drive hardware itself.
spivonious is offline
post #4 of 5 Old 12-18-2009, 02:21 PM
hirent's Avatar
Are these new discs or previously working BDs?
Hold it up to a light and see if the disc is transparent. I've had it happen to me with a couple of discs (same drive as yours).
Also, if the discs are from Netflix, check if there's a crack near the edge.
hirent is offline
post #5 of 5 Old 12-18-2009, 07:58 PM
rl623's Avatar
I have had that problem since i installed my new Lg burner last week.Plays and burns regular dvd's fine but won't do squat with the blu-ray.I was thinking the blu-ray laser wasn't working ??
rl623 is offline
Reply Home Theater Computers
