Batch File with AnyDVDHD? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 12-24-2009, 08:46 PM - Thread Starter
sethhorwitz's Avatar
Is there any way to write a script, or batch, so AnyDVD will auto rip an ISO of a Blu Ray to a default directory? I can probably write a hack job script that emulates keyboard strokes to get the job done, but I'd like something more polished. I'm looking to do this, as I want to run a headless Blu Ray ripper like so:
1. Put Blu Ray in drive.
2. Let Windows Autoplay kick off a batch, or script, to use AnyDVD's built in "Rip to ISO" functionality.
3. Auto Eject the disc.
... Rinse ... Wash ... Repeat ... etc.
Thanks for any help.
--Seth
P.S. The "ripper" box runs XP Pro, if that matters.
sethhorwitz is offline
post #2 of 10 Old 12-24-2009, 09:05 PM
ilovejedd's Avatar
Quoted: 76 Post(s)
Liked: 67
Why not use ImgBurn for ripping? AnyDVD HD runs in the background to handle the decryption anyway so you can use pretty much any software to do the actual ripping.
ilovejedd is offline
post #3 of 10 Old 12-24-2009, 11:06 PM - Thread Starter
Hmmm. I wanted to keep as few moving parts as possible, but I'll check it out. Would ImgBurn do what I'm looking for? I believe AnyDVD prompts me for a region when a disc is loaded. Would this cause a break in the process? Again, I'm looking to run this without a monitor or keyboard. Literally just load a disc into a tray, close it, and wait for the disc to be ejected. (knowing that the ISO has ripped to the drive) Thanks.
-Seth
post #4 of 10 Old 12-25-2009, 07:38 AM
scat2002's Avatar
I have a few .bat scripts that might be useful
Batch file 1: MakeISO.bat.txt
remove the .txt extension
Purpose: Makes a ISO of the current dvd using ImgBurn
I prefer using ImgBurn to make ISO images because I had problems with the ISO images from AnyDVD HD.
You must edit these three lines in Bold to set the paths correctly for your machine.
Change only the Bold selection of the line
rem Enter your DVD drive letter below
set SRC=q:
rem Enter your target folder to store the ISO image in below
set DEST=H:\\ISO_Rips
rem Set the path to ImgBurn below
set PathToImgBurn=C:\\Program Files (x86)\\ImgBurn
You must have ImgBurn and AnyDVD HD installed
Batch file 2: Rip2Fldr.bat.txt
Purpose: Automated copy a DVD folder structure to hard drive
while making a folder of the DVD'S Volume Label and storing the information there.
Please note some volume labels for DVD's are not very informative and you should rename accordingly.
You must edit these two lines in Bold to set the paths correctly for your machine.
set SRC=I:
rem Enter your target folder to store the DVD in below
set DEST=H:\\DVD_Folder_Rips
You must have AnyDVD HD installed.
Enjoy
Scat
MakeISO.bat.txt 1.5654296875k . file
Rip2Fldr.bat.txt 2.361328125k . file
scat2002 is offline
post #5 of 10 Old 12-25-2009, 07:57 AM - Thread Starter
Cool, I'll have to poke around with that. Before I do, two questions. First, does the batch wait for the ISO file to be created? (After which I can add some code to auto-eject the drive.) Second, can Windows "autorun" kick off a batch file, or does it have to be an exe? Thanks for pointing me in the right direction. I'll have to start some research now.
-Seth
post #6 of 10 Old 12-25-2009, 08:48 AM
ilovejedd's Avatar
Quoted: 76 Post(s)
Liked: 67
-Seth
ImgBurn already has a built-in option to eject disks after ripping. You just need to add /eject yes to the commandline.
post #7 of 10 Old 12-25-2009, 08:54 AM - Thread Starter
Thanks again. Time to get my hands dirty. (Although not very dirty, thanks to your help.)
post #8 of 10 Old 12-25-2009, 09:04 AM
namdlo's Avatar
I don't have AnyDVD HD but I know that std AnyDVD has an "external program" section that you can start programs from based on the type of media inserted.
I've used scripts with CloneDVD (using tcclone) so I'm sure you can do something similiar with ImgBurn.
namdlo is offline
post #9 of 10 Old 09-26-2013, 09:30 AM
Lupin 3rd's Avatar
Quoted: 13 Post(s)
Hi guys,
today I've tested Rip2fldr.bat on my win 7 32bit and Any DVD HD installed.
but it seems do not work.
I've tested it with DVDs in the drive and also Bds ...nothing!
Maybe this batch is too old?
Lupin 3rd is offline
post #10 of 10 Old 09-26-2013, 02:14 PM
el_kano's Avatar
You need to change the bat file to match your system.
Is the path to imgburn correct?
You say you have 32 bit windows 7, so that may not have the '(x86)' part of the path?
el_kano is offline
Reply Home Theater Computers
