HTPC with Zalman HD160XT Rev.1 Running on windows 7!! - Page 2 - AVS Forum | Home Theater Discussions And Reviews
Old 05-12-2010, 12:41 PM
PiwiKiwi's Avatar
I have had some problems with the software also.
However, after forcing Windows 7 (and Vista) to use the published drivers the touchscreen always worked fine.
What problems is everyone having?
ciao,
Piwi.
HD160XT rev. 1
PiwiKiwi is offline
Old 05-12-2010, 04:33 PM
nc88keyz's Avatar
Quoted: 153 Post(s)
Liked: 78
I am reminded again to contact jessechen@eeti.com....The USA distributor has not responded to multiple requests. Hoping i can get this addressed soon.
Still trying to work through this .
HT1: UN78JS9500, AVR: AVRX-7200WA, AMP: UPA-7, SPKRS: L/R: Veritas 2.3I C: 2.0CI SUR: V2.0R,, SUB: SVS SB13Ultra x2 ATMOS: 4X RC-6C, NUC i5/KODI, ChromeBox/KODI, ShieldTV
HT2: LC80LE844U, AVR: AVR4311CI, SPKRS: L/C/R: Veritas 2.2C, SUR: RC-RCRx2, SUB: 10.3x2
STORAGE: DS1812, DX513 x 2 - 4TBx18 Hybrid Raid, (It Just Works!!) R/C: HarmonyOneX2, Harmony880x1
nc88keyz is offline
Old 07-15-2010, 03:30 PM
PanamaMike's Avatar
Is this case worth buying? Want to know if I could use the case touchscreen in a usable dual screen mode. Not using the cheesy MM software.
Will the case accept normal MCE remote control commands.
How can I tell what Rev. a case is from an online dealer?
Mike
PanamaMike is offline
Old 08-09-2010, 02:51 PM
RBeck's Avatar
I ordered a S4000UEGG and instead I recieved a S4000UAGG. I was told that the number was wrong. I am still trying to get to the bottom of it.
Secondly I don't know what cable to get to conect to the screen itself. Any help would be greatly appreciated.
RBeck is offline
Old 09-05-2010, 11:14 AM
JonHolstein's Avatar
@christix
what was the advantage with ordering that part over ordering from Zalman distributor?
(PCB in sweden)
JonHolstein is offline
Old 09-05-2010, 05:39 PM
ciao,
Piwi.
HD160XT rev. 1
I dont have a system up and running for testing.
But as far as Ive understood, people cant get the touchpanel to work in 64bit versions of the OS, and according to Zalman it doesnt.
"If you check the serial number(beginning with HD160XT(S/B)(0/A/B/C).) and the letter in red(0/A/B/C) is either 0 or A, it's compatible only with Windows Vista 32. If it's either B or C, it is okay with both Vista 32/64."
From zalman.
Do you have HD160XT and not the HD160XT plus? (this is only for HD160XT not the plus version)
Is your case really rev. 1 (serialnumber 0/A)?
Are you running 64bit OS?
If yes on all, how did you force the driver?
And where dit you get the driver?
Old 02-05-2012, 03:56 AM
PiwiKiwi's Avatar
Sorry for not visiting the forum in a loooooong while.
No, I'm running 32bit Win7. Just a few "Compatibility Mode" and "Use Anyway" dialogs....if I remember right. It's been a while.
My setup is working great, it's been really stable all 2011.
I'm just now getting into trouble with the limitations of a 32bit operating system, certain applications require more RAM than Win will allow AND my motherboard won't recognize more than 3 GB of RAM.
Soooo....anybody got their HD160XT working nicely on Win7 64bit?
If so, please advise, I hear there are issues with touchscreens and such.
Paul.
PiwiKiwi is offline
Old 08-20-2012, 09:56 AM
nc88keyz's Avatar
Quoted: 153 Post(s)
Liked: 78
Does anyone know if Jesse EETI still has these available for a conversion?
HD160XT Rev.1 here. I think i forgot about this a couple years ago, There were some communication issues with EETI and my email . It might be lost cause.
nc88keyz is offline
Old 04-11-2015, 04:23 PM
vcrpro3's Avatar
Quoted: 107 Post(s)
Liked: 25
This is a year 2015 response to this thread; I have a used Zalman i bought a couple of months back. Having same problems with the touchscreen as this thread about...In researching the part that some of the people on this list obtained...came up with this on April 11, 2015...http://www.ebay.com/itm/Resistive-To...b8d2cd....that circuit board sure in the heck looks the same.....
Originally Posted by kanonkurt View Post
Thank You for the info! Microsoft really has its advantages and disadvantages , and the absence of a good solution for secondary screens in Mediacenter is really bad.
I received the Touch Controller PCB today and I took a picture of it, please look at the attached file. Could You please verify that this is the right one?
I didn't find any double sided tape, was that supposed to be included?
/Fredrik
vcrpro3 is offline
