Best Keyboard and Mouse/Trackball - Whatcha got??? - Page 10 - AVS Forum | Home Theater Discussions And Reviews
post #271 of 456 Old 11-15-2010, 03:46 PM
starscomeout's Avatar
Originally Posted by jkellynewyork View Post
wow - this looks interesting - looks like it just came out - tempting
http://www.amazon.com/Cideko-Keyboar.../dp/B0030UJK2G
I have one of these for my bedroom HTPC and it works pretty good. The only problem is that it has none of the F keys which I rarely need anyways. Worth a try, and if you don't like it then Amazon has an excellent return policy.
-Don
starscomeout is offline
post #272 of 456 Old 11-16-2010, 06:39 PM
mumble's Avatar
Anyone tried the Logitech Keyboard Controller that normally accompanies the Revue (GoogleTV) with a HTPC? It's $99, battery powered and seems to look pretty "coffee table appropriate".
I'm thinking of getting one to replace a Dinovo Edge that no longer charges. Obviously the replaceable batteries are a big plus for me on this one!!!
http://www.amazon.com/gp/product/B00...g=hdex-roku-20
mumble is offline
post #273 of 456 Old 12-07-2010, 11:11 AM
goondog's Avatar
the lenovo device is back on sale at about $20. cheapest ive seen. going to jump on it but whats the verdict on this things range?
my zino is behind a cabinet does it need to be opened or line of sight?
or do i just go with dinovo mini or some other bluetooth device.
http://slickdeals.net/forums/showthread.php?t=2458269
goondog is offline
post #274 of 456 Old 12-07-2010, 11:32 AM
frankspin's Avatar
I have this guy, http://www.newegg.com/Product/Produc...-018-_-Product
After getting the trackball fixed it's been fantastic. Smaller than a traditional keyboard and it has built in mouse functions.
frankspin is offline
post #275 of 456 Old 12-07-2010, 01:44 PM
none74's Avatar
I just got rid of my Lenovo, I didn't like the lack of Function keys, it turned out to be VERY inconvenient not to have the failsafe Alt+F4 to shut down programs, as well, the keys are VERY difficult to use to type and personally, I think the area where you can click should be much, much bigger. It is so restricted that you have to THINK about where to push to actuate clicks...
If small is your ONLY consideration, its a decent option, otherwise there are much better keyboards out there. I found the range to be somewhat below average for the devices rated at 30 feet, but it is possible to use it through cabinets. If you want very good hidden functionality, get a bluetooth device, they seem to handle distance and obstruction much better, imho.
none74 is offline
post #276 of 456 Old 12-07-2010, 01:45 PM
none74's Avatar
How did you "fix" the trackball ? I have this one too, and I detest the sloppy feel the track ball has, is there an easy fix for this ??
none74 is offline
post #277 of 456 Old 12-07-2010, 04:28 PM
frankspin's Avatar
I RMA'd it with Iogear. I just made mention that it's a known issue via reviews on NewEgg (go through the reviews, Iogear actually responded to some of them). When I finally got it back, about a week to week 1/2, it's been amazing. The trackball doesn't feel as loose and has a little more resistance when moving around. Most of all, I no longer have the issue where everytime I clicked on something the mouse pointer jumped all over the screen.
post #278 of 456 Old 12-07-2010, 04:50 PM
none74's Avatar
Ahhh, RMA, more expensive to ship it back than to just buy a different one and hope for a better product...I've tried dozens of candidates, and still have not found the "definitive" wireless keyboard/mouse for me.
none74 is offline
post #279 of 456 Old 12-07-2010, 06:41 PM
David James's Avatar
Quoted: 40 Post(s)
Liked: 80
I just got this one today. I will only use it for SageTV, browser functions and possibly hulu, boxee and or kylo.
Anything I need to do which isn't possible through that keyboard, I'll do via UltraVNC.
David James is offline
post #280 of 456 Old 12-12-2010, 07:36 PM
investmentcar's Avatar
What do you think of it?
I want one that has these few features:
>compact - like a laptop/netbook size with no num pad.
>bluetooth
>has media buttons
>integrated trackpad
>easy for 1 or 2 hand operation
I can't seem to find one that is ideal. Hopefully someone will produce one soon...
investmentcar is offline
post #281 of 456 Old 12-30-2010, 09:33 AM
smithmal's Avatar
Originally Posted by jvarisco View Post
I ordered one in early March, before they hiked the price up, and got it last week.
So far I'm impressed. The unit feels well built and has more heft in it that you'd think, and doesn't feel like it would shatter if you dropped it. It's obviously plastic, but doesn't feel fragile. I do personally like the fact it's put together with screws in the back via internal plastic tabs - not that it matters that much but if I have to open the unit it will be far easier.
The unit charges via mini-USB, and has an on-off switch on the side. Can't comment on battery life yet (as I don't use it a lot, that's what my remote is for). One possible bug I've had is that if left on and unattended for a while it becomes unresponsive until I turn it off and back on - not a huge issue and might be some power-saving feature I don't know how to properly use.
The keyboard feels nice to me - it's easy for me to type on, and the function keys are really cool - volume up/down/mute (mute doesn't seem to work with my windows install however), a button to rotate the orientation of the mousepad, and my favorite - a CTR-ALT-DEL combo. It seems to have everything you'd practically need, including a small direction pad for use as arrow keys.
Touchpad/mouse buttons I'm lukewarm on. Given the size of it, I'd say it performs admirably, but even with mouse sensitivity turned up to max it will still take 2-3 swipes to go all the way across a 1080p screen. The mouse buttons work fine as well, and are directly underneath the trackpad. My only complaint is that the d-pad is between the two buttons, which doesn't yet feel "right" when I'm trying to mouse click without looking at the unit. I'm sure I'll get used to it.
The backlight works really well - it's quite bright, far more than I expected it to be.
Also, the laser pointer in it is surprisingly strong - my cats found it quite fun. Not useful for HTPCs but a bonus for pets nonetheless.
Aside from the small issues mentioned above, I really like it. My complaints about the device are things you can't really get around in a keyboard/mouse combo this size. I only occasionally need to use the mouse/keyboard on my HTPC setup, so I'm estatic that I can finally exchange my gyration air remote and laptop-style keyboard for something way smaller, and doesn't require 6 batteries to power!
Anybody who has specific questions, feel free to ask and I'll do my best to answer.
Looks like the price for the Rii remote has gone down to $39.99:
http://www.tomtop.com/computers-netw...9b_p10332.html
Props to adrenalynn over at Slatedroids.com for posting this.
smithmal
smithmal is offline
post #282 of 456 Old 12-30-2010, 11:47 AM
none74's Avatar
smithmal
Just wanted to add to the review that was previously posted. I got this remote and like pretty much everything about it, except the slightly sluggish mouse pad response, and the TERRIBLE range of the bluetooth receiver.
I had to put the receiver on a long USB extension and hang it in sight to get it to work well. Anyone wanting it should note that, the reception is very, very poor for the included bluetooth dongle and you'll need to be very close to your computer, or, buy a MUCH better receiver AND have it in line of sight, and somewhat close(within about 10 feet is what I had to do...). So, the search for the perfect solution continues...
none74 is offline
post #283 of 456 Old 01-03-2011, 09:04 PM
bb80301's Avatar
I also found the bluetooth range for the rii keyboard with the included dongle very weak. I had a spare bluetooth dongle from a Microsoft mouse & I tried that in place. Turns out that the range improved quite a bit - so it appears that the problem is with the included dongle rather than the keyboard unit itself.
bb80301 is online now
post #284 of 456 Old 05-31-2011, 04:11 PM
podopple's Avatar
I'm going to try this one, looks like a variation on the rii. Function keys, scroll wheel, backlight keys. I'll let you know how it goes when it arrives.
Watching a movie on a tv is like watching a movie on a tv, watching a movie on a projector is like being at the movies!
podopple is offline
post #285 of 456 Old 05-31-2011, 04:28 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
The problem with these rii keyboards is that it has no F12 key. On that one I dont see the scroll wheel. It could be just sliding your finger up and down the right edge of the touch pad?
That said, the + or - keys on mine won't be recognized when I'm in BIOS so I had to grab my "real" keyboard to change the boot drive order last week. But it does have F12.
Sammy2 is offline
post #286 of 456 Old 05-31-2011, 05:54 PM
podopple's Avatar
One of the pics down the page shows a scroll wheel near the laser. Didn't even notice the function keys stopping short at 8. BIOS I kinda figured I'll need to get old trusty out. Not really a concern with the use this keyboard is intended for. Once it's all up and running it'll get minimal use, web addresses, short messages etc. There's not one perfect keyboard in my opinion for the htpc. I would of preferred one similar in design to this but with backlight keys
podopple is offline
post #287 of 456 Old 06-01-2011, 08:09 AM
Darth Sensate's Avatar
Originally Posted by Darth Sensate View Post
Received and have been using the IpazzPort "-05" for a few weeks now.
http://www.amazon.com/iPazzPort-subs.../ref=pd_cp_e_3
I was pleasantly surprised at how nice the tactile feed back on the keys are.
They are easy to press and you KNOW that you have pressed them.
The unit is small and VERY light.
The backlight works really well.
The trackpad is pretty accurate and reliable.
The key layout is nice.
It takes a little getting used to going from a full QWERTY 84 key keyboard to this one but almost everything you need is here. This is NOT recommended for people who need to type emails or anything extensive. Touch-typists will likely hate this keypad... but then, it IS a keypad and NOT a keyboard. Cell phone users with the thumbskills will love this keypad.
The only difficulties I have had are with the "SF", second function, lock to get to the arrow keys. It works but it just takes some getting used to. And I have not found a key-combo equivalent to Alt-Tab to cycle application windows or Ctrl-Tab to cycle application tabs.
I actually used this keypad and my old BTC 9116 simultaneously just for fun and they work just fine.
BTC is now disconnected. I allowed my old PC with BIOS set to USB legacy support to go into standby and it work with one click on the spacebar.
I forced the PC to standby manually and did the same. worked.
I pressed the front button on the chassis to standby the unit and woke it up again with a SINGLE press of the spacebar.
Only one time did I have to pull the USB "dongle" to get Windows XP to recognize the keyboard. It appeared to have a problem with being impatient... I clicked the spacebar and then started pressing other keys and more spacebar clicks and mouse button clicks, XP started but no keypad or mouse function. Cycling the powerswitch on the side of keypad had no effect.
Afterwards I had no further issues with the wake from standby as long as I did not bang on the keys while XP was booting. I'll have to try this with an Ubuntu install as well.
Been several months now and the keypad is still working just fine. My thumbskills have improved significantly. Battery is still solid and the durability of the pad seems just fine. Signal/reception is solid as well.
Darth Sensate is offline
post #288 of 456 Old 06-01-2011, 08:48 AM
elliscs's Avatar
Really like the form factor of the Logitech Revue keyboard, but haven't found out how to make it work on my system yet.
elliscs is offline
post #289 of 456 Old 06-01-2011, 09:56 AM
Zon2020's Avatar
Has anyone tried the Rii Touch N7? It looks slightly larger and has the touchpad in the center rather than on the right. Wondered how that works in practice.
But it does appear to have 12 function keys.
I am really tempted to try one of these. Amazon sells it for $49.99. They also have a Bluetooth knockoff of the regular Rii for $39 in case you're trying to avoid 2.4 wireless.
Zon2020 is offline
post #290 of 456 Old 06-01-2011, 10:02 AM - Thread Starter
assassin's Avatar
Quoted: 82 Post(s)
Liked: 244
My brother uses this and loves it, fwiw.
assassin is offline
post #291 of 456 Old 06-01-2011, 10:09 AM
Zon2020's Avatar
Can you get enough precision to control a cursor on a big screen with the really small touchpad on these Rii devices? That's my biggest hesitation.
Zon2020 is offline
post #292 of 456 Old 06-01-2011, 11:04 AM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
I have the one pictured above and it works great. The touch pad is plenty sensitive enough but to go diagonally across the screen takes 2 or 2½ strokes. That is the cost of having precision of the mouse pointer. This is adjustable to how you may like it. There's also a scroll wheel on the extreme right side of the touch pad. and you can left-click by tapping the pad or by using the mouse buttons below the touch pad. The 4-way arrow toggle is really awesome to have too. There's also an explorer button that instantly opens IE.
Sammy2 is offline
post #293 of 456 Old 06-01-2011, 11:11 AM
Zon2020's Avatar
Thanks. Think I'll order one. The diNovo Mini seemed unnecessarily expensive; and I just wasn't sold on the Lenovo N5901. I use an IoGear GKM561R on my other system and really like it for what it is, but I really want something much smaller for the new one. This Rii Touch N7 might just be the ticket. It's reassuring to read an endorsement from someone who has actually used it.
Zon2020 is offline
post #294 of 456 Old 06-01-2011, 11:14 AM
joeydrunk's Avatar
Quoted: 14 Post(s)
Are you talking about the mini keyboard that's pretty much identical to the dinovo?
joeydrunk is offline
post #295 of 456 Old 06-01-2011, 11:15 AM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
I will say that it doesn't have the range advertised. It needs line of sight and works to about 15 feet which for me is plenty. Who needs to operate their HTPC from 30 meters (100 feet or so)? You also have to keep it charged up because it starts to get finicky when you don't. I plug it in to the supplied USB cable every night using the On-Off Charge function on my Gigabyte MoBo because it is pretty functional and can be used for a lot of maintainence tasks.
Sammy2 is offline
post #296 of 456 Old 06-01-2011, 11:23 AM
Zon2020's Avatar
Could you plug the USB cable into a USB phone/iPod charger? I have several of those plugged into a surge protector that gets turned on each night to recharge my phone, two iPods and my Kindle overnight. I could easily add this to the mix.
So I take it that the "stays charged for 30 days" is a bit of an exaggeration too?
Zon2020 is offline
post #297 of 456 Old 06-01-2011, 11:38 AM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
It's mini-USB so I suppose so. It probably would stay charged for longer if I didn't use it heavily for maintainence of the system.
Sammy2 is offline
post #298 of 456 Old 06-01-2011, 06:35 PM
DrApnea's Avatar
Logitech K800 and matching MX mouse
http://www.logitech.com/en-us/keyboa...d/devices/7288
http://www.logitech.com/en-us/mice-p...sE|6135||Image
This was the only setup I could find that would give me the range, backlit, rechargable, and ability to actually type out things without having to hunt for keys. I have a Lenovo Multimedia Remote but never use it because typing on it sucks. For media center interface it is just a rosewill IR remote until I can upgrade to a better one.
DrApnea is offline
post #299 of 456 Old 06-01-2011, 06:42 PM - Thread Starter
assassin's Avatar
Quoted: 82 Post(s)
Liked: 244
In the lenovos defense you really shouldn't be using it for a lot of typing
assassin is offline
post #300 of 456 Old 06-01-2011, 07:55 PM
FantaXP7's Avatar
Quoted: 44 Post(s)
Liked: 38
I have this one here
http://techgage.com/article/microsof..._desktop_8000/
I really liked the idea of this one over all others I had seen at the time of getting it, which is a few years ago now. I like how nicely they incorporated media center related keys. The back button as you would see it on an mce remote, green button, etc...
I also thought that since it was bluetooth that it would be a plus. But I am sometimes shocked at the range of the bluetooth...I will be on my bed and my HTPC being lower to the ground will ruin the range. I have to aim it high towards the ceiling to break lag...
Also, I am not accustomed to the style of keyboard even after a few years of owning. But that goes to show you how much typing you will ever need to do with a HTPC. I usually adapt my typing to whatever new keyboard I get, never really had to with this one.
Anyways, looking back I would have spent less. Overall it is a good choice, not ideal though.
I would like to try this one sometime, although I have read mixed reviews and it is older
http://www.tomshardware.com/reviews/...oard,1098.html
FantaXP7 is offline
Reply Home Theater Computers
