AMD Athlon II X2 and TV tuners and WHS - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 01-13-2010, 06:06 AM - Thread Starter
MisterHux's Avatar
I'm thinking of setting up a media server (most likely WHS) and would like to insert a TV tuner (or 2 at least till ceton comes out). So I have two noob questions:
1. Has any one had issues with WHS recording TV using a capture card in its box? Or for that matter streaming live TV? Is this even possible?
2. Is the AMD Athlon II X2 powerful enough to handle recording HDTV channels, if its also potentially serving up a recorded video (or 2 at the same time)?
Thanks in advance.
MisterHux is offline
post #2 of 7 Old 01-13-2010, 07:17 AM
Servicetech571's Avatar
The Athlon II X2 should easily handle recording HDTV channels, it doesn't use much processing power since no encoding is involved.
Servicetech571 is offline
post #3 of 7 Old 01-13-2010, 11:04 AM - Thread Starter
MisterHux's Avatar
thank you for that answer ... I was pretty confident, its just nice to be 100% sure.
post #4 of 7 Old 01-13-2010, 12:04 PM
Suntan's Avatar
Quoted: 75 Post(s)
Liked: 107
For reference, I have 5 HD tuners hooked to a 5 year old single core Anthlon 64 3200+ PC, including playback. Any X2 has more than enough to record a couple of TV shows.
-Suntan
Suntan is offline
post #5 of 7 Old 01-13-2010, 06:00 PM - Thread Starter
MisterHux's Avatar
Awesome that's great to know. Now just need to figure out if WHS will work well with TV Tuners. The only sites i could find were from like 2-3 years ago ... hmmmm
post #6 of 7 Old 01-13-2010, 07:12 PM
potts.mike's Avatar
I have a whs running sagetv and had a haupauge hvr-1600 in it and the analog channels would never tune. I emailed haupauge and they dont suppert server OS and sage was no help either so Ipulle dit and put in my win7mce rig and it works perfectly.
That being said there are many people that use sagetv, whs, and a variety of tuner cards with no problems.
potts.mike is offline
post #7 of 7 Old 01-14-2010, 09:43 AM
water1's Avatar
Location: Pleasant Ridge & Suttons Bay, MI, Carefree, AZ
Here is some new information on TV tuners and WHS.
http://dvblogic.com/phpBB3/viewtopic.php?f=43&t=8923
John
water1 is offline
Reply Home Theater Computers
