I'm not stupid, but: 4550, 4650, 4670? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 54 Old 01-17-2010, 06:25 PM - Thread Starter
KenIAm's Avatar
I know there have been numerous threads on this topic, and I've read them all. But, even though I don't think I'm stupid, I still can't figure out which to get.
My criteria:
1. PQ
2. Fanless
3. Low power / heat
4. Price
It's for watching mainly OTA 1080i recorded on a Hauppauge 2250, fed to a Denon 2310CI AVR (via HDMI cable, I assume). No gaming whatsoever.
In order of ascending price:
$35 Gigabyte 4550
$51 Sapphire 4550
$70 HIS 4650
$87 HIS 4670
Obviously the price differences are fairly small, but OTOH, why spend $87 if a $35 card will do exactly as well for me.
Can anyone help me decide? Thanks!
Ken
KenIAm is offline
post #2 of 54 Old 01-17-2010, 06:32 PM
rdunnill's Avatar
My criteria:
1. PQ
2. Fanless
3. Low power / heat
4. Price
$35 Gigabyte 4550
$51 Sapphire 4550
$70 HIS 4650
$87 HIS 4670
Ken
The 4670 will use Vector Adaptive 1080i deinterlacing, while the others may not.
Blu-ray: 50+
HD-DVD: 23
DVD: 600+ and lost count
rdunnill is offline
post #3 of 54 Old 01-17-2010, 06:32 PM
kevinqian's Avatar
it all boils down to 1080i Deinterlacing quality. VA vs. MA. What is acceptable to you will determine your decision. Personal experience tells me the much vaunted VA deinterlacing does not give you the night and day benefit over MA. But if you are a PQ perfectionist, spend away.
kevinqian is offline
post #4 of 54 Old 01-17-2010, 06:38 PM
Mallet21's Avatar
The 4550 is a very solid card for the price.
Mallet21 is offline
post #5 of 54 Old 01-17-2010, 06:52 PM - Thread Starter
KenIAm's Avatar
PQ is the most important thing to me, however I definitely don't qualify for "perfectionist" level. Since I don't have any experience with VA or MA deinterlacing, Kevin, your comments were exactly what I needed.
Sounds like the Gigabyte or Sapphire 4550 should be fine, then. Thanks, guys, very much!
KenIAm is offline
post #6 of 54 Old 01-17-2010, 07:14 PM
kevinqian's Avatar
If you don't mind Nvidia, a GT 220 will also get you VA deinterlacing (according to Renethx) for about $50. Slap on a fanless cooler for another $10 and you are golden.
I just bought this fanless cooler and it works great for my video card.
http://www.compuvest.com/Search.jsp?...u=332000788-00
post #7 of 54 Old 01-17-2010, 07:17 PM - Thread Starter
KenIAm's Avatar
Thanks, Kevin, but I do prefer ATI right now.
KenIAm is offline
post #8 of 54 Old 01-17-2010, 07:27 PM
galileo2000's Avatar
you can get Asus 4650 for $25 AR from newegg.com.
Good time to buy computers and computer parts: NEVER
galileo2000 is offline
post #9 of 54 Old 01-17-2010, 08:46 PM - Thread Starter
KenIAm's Avatar
It looks like $30, but either way, that's a great AR price. Except the reviews are pretty mixed, it has a fan (quiet apparently, but fans sometimes get noisier after a while), but even so there are some complaints it runs very hot.
I think I'd prefer the Gigabyte 4550 for $5 more, but thanks for the suggestion.
If I had a chance, though, I'd reorder my priorities. My HTPC has somewhat poor airflow, so "low heat" has to be right after PQ.
KenIAm is offline
post #10 of 54 Old 01-17-2010, 09:15 PM
kevinqian's Avatar
poor airflow and passive coolers do not mix. You might want to reconsider getting a fanless.
post #11 of 54 Old 01-17-2010, 09:16 PM
archer75's Avatar
Quoted: 52 Post(s)
Liked: 40
The 4670 scores higher on the HQV tests. The 4550 comes with it's own issues.
If it were me i'd get the 4670 out of your choices. But then it's not too far off from the price of a 5670 which I plan on picking up soon.
HTPC: Intel e6300 2.8ghz, Intel DG45ID, 2gb DDR2, Radeon 5570, MCE IR receiver, Yamaha RX-V663 receiver via HDMI, panasonic ax100u, 145" S-I-L-V-E-R painted screen, 2x Roku 3's, chromecast, Amazon Fire TV, Vizio M602i-B3
archer75 is offline
post #12 of 54 Old 01-17-2010, 09:29 PM
mariner888's Avatar
Try these 1920x1080x60p clips:
http://jp.sanyo.com/xacti/products/l...00/sample.html
archer75 is right. Get a 5670 if you need a 4670 class card.
mariner888 is offline
post #13 of 54 Old 01-17-2010, 09:38 PM - Thread Starter
KenIAm's Avatar
I'm used to systems in which the graphics cards are never taxed, so don't become anything beyond warm. I'm afraid that might not be the case here, so you may be right. I've never owned a graphics card with a fan, so that's perhaps much of my hesitancy.
But now I'm up to $100 or so (but it's a good point, considering the price of the 4670). Still nothing compared to the rest of the gear, of course, but it does all add up.
And here I thought I had it all decided. Still, better to be confused now then sorry later.
KenIAm is offline
post #14 of 54 Old 01-17-2010, 09:45 PM - Thread Starter
KenIAm's Avatar
My HTPC with its current graphics processor couldn't possibly play those clips. My PC (a 4670) plays them well using VLC, but stutters like crazy using QT. And it's got an i7 with 12GB of RAM.
KenIAm is offline
post #15 of 54 Old 01-17-2010, 09:53 PM
chung_chang's Avatar
5670 also gives you bitstreaming of HD audio to your receiver. None of the cards mentioned above (including nVidia) can do that. 5670 also draws about the same power as the 4670. In fact, 5670 draws less power than the 4670 at idle. Less power means less heat and lower electric bill.
chung_chang is offline
post #16 of 54 Old 01-17-2010, 10:04 PM
mariner888's Avatar
4650 only offers marginal improvement over 4550 for high bit rate and interlaced stuff.
You may want to wait for the upcoming 5570.
post #17 of 54 Old 01-17-2010, 10:08 PM - Thread Starter
KenIAm's Avatar
I have only a 5.1 setup with no plans to upgrade, so I don't know if I'd benefit from audio bitstreaming. Especially since I plan on getting a standalone BD player as opposed to putting one in my HTPC.
As for power consumption, this graph shows a 5670 consuming 22W @idle, compared to just 10W for a 4670 (and 5W for 4550). I haven't had a chance to look for other graphs, though, so maybe this one is wrong?
KenIAm is offline
post #18 of 54 Old 01-17-2010, 10:10 PM - Thread Starter
KenIAm's Avatar
5570?! I don't mind waiting, but what would the extra power be used for? (Or am I just being confused by ATI's naming scheme, and the 5570 is below the 5650?)
KenIAm is offline
post #19 of 54 Old 01-17-2010, 10:13 PM
djlah's Avatar
I trying play the 1920x1080 fullHD clip by MPC-HC (with ffdshow 3171)
but I only get audio with black screen. while using PowerDVD9 are ok.
any tips?
djlah is offline
post #20 of 54 Old 01-17-2010, 10:21 PM
kevinqian's Avatar
I've read rumors that 5500 series is limited to 64bit memory, same as the 4550.
post #21 of 54 Old 01-17-2010, 10:24 PM
mariner888's Avatar
@KenIAm: 5570 is 4550's replacement. Low power and with slightly higher specs.
@djlah: Try MS or PDVD H264 decoders.
post #22 of 54 Old 01-17-2010, 10:29 PM - Thread Starter
KenIAm's Avatar
Aha! I assumed it would be called the 5550; silly me. Thanks; that might be what I'll do (what's a few more months?).
KenIAm is offline
post #23 of 54 Old 01-17-2010, 10:45 PM
djlah's Avatar
thanks to mariner888, add PDVD decoders, now ok.
djlah is offline
post #24 of 54 Old 01-17-2010, 11:18 PM
Favelle's Avatar
If one is a "PQ perfectionist", would they even be watching material that needed deinterlacing anyways?
In terms of LFE, size does matter!
Favelle is offline
post #25 of 54 Old 01-17-2010, 11:39 PM
mariner888's Avatar
True enough. You need 1920x1080x60p.
post #26 of 54 Old 01-18-2010, 03:03 AM
azafeiros's Avatar
My vote would be for 4670.....Specifically 4670 sapphire ultimate-fanlesss!!!!
major point = silence +VA
azafeiros is offline
post #27 of 54 Old 01-18-2010, 04:15 AM
ArtosDracon's Avatar
and yet it's the price of a 5670(almost) and the 5570 is only about 2 months out last I heard.
ArtosDracon is offline
post #28 of 54 Old 01-18-2010, 05:27 AM
severian1967's Avatar
I have that exact Gigabyte 4550 fanless card, and it's been exemplary. Hooked into my Onkyo AVR to my 52" Samsung, I've had zero problems with it, plays everything very well. I don't watch interlaced stuff though.
severian1967 is offline
post #29 of 54 Old 01-18-2010, 06:28 AM
azafeiros's Avatar
For me the silence factor is priceless. Does the 5670 come out fanless?
I watch 1080i material a lot (home movies from my sony hd camera) therefore VA is a must
post #30 of 54 Old 01-18-2010, 06:42 AM
not yet, but it's been out for about a week so it'll take a little time, but I expect it to, the 5570 definitely will, the 5350 which has been previewed as well is passive in it's native ATi design.
Reply Home Theater Computers
