Strip BD extras but keep menus? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 01-21-2010, 02:11 PM - Thread Starter
BigZAJ's Avatar
Is there anyway yet to just strip out the unwanted audio tracks and bonus features for blu-rays but keep the menu intact to allow for nice and pretty chapter selection??
BigZAJ is offline
post #2 of 10 Old 01-21-2010, 05:54 PM
davdev's Avatar
Here you go:
http://www.avsforum.com/avs-vb/showthread.php?t=1033822
It's a long thread, but most of what you will need is right in the begining
davdev is offline
post #3 of 10 Old 01-21-2010, 08:53 PM
jidelite's Avatar
Quoted: 41 Post(s)
I haven't tried this yet but here's something that the author of multiAVCHD is developing: http://forum.doom9.org/showthread.php?t=151925
jidelite
jidelite is offline
post #4 of 10 Old 01-21-2010, 11:28 PM
ANDYK48's Avatar
Just ript the Blu-Ray in a folder using ANYDVD HD.
Then browse to the stream folder where all m2ts files resides.
Delete the m2ts files that holds the extra crap and replace them with text files which you rename to the same names as the m2ts files.
This way the Blu-Ray structure is intact and you can enjoy your movie witout all tha annoying extras and warnings
ANDYK48 is offline
post #5 of 10 Old 02-02-2010, 09:11 PM - Thread Starter
BigZAJ's Avatar
I didnt think that worked?
BigZAJ is offline
post #6 of 10 Old 02-03-2010, 12:13 AM
ANDYK48's Avatar
BigZAJ,
This method definitely works
I have all my blu-rays ripped this way and they all work flawlessly.
ANDYK48 is offline
post #7 of 10 Old 02-03-2010, 01:24 AM
Pepster returns's Avatar
BigZAJ,
Thanks for this info, I might give it a bash.
A more important task than deleting the 'fluff' is to create a new LPCM track to you can output lossless audio over SPDIF.
I also use Clown BD converter (free) to create a new LPCM track from the TRUEHD or DTSMA as required so I can have lossless audio over SPDIF -works very very well.
The audio of my set up is 1st grade.
Pepster returns is offline
post #8 of 10 Old 02-03-2010, 04:01 AM
ANDYK48's Avatar
You cannot have lossless audio from SPDIF. SPDIF has not enough bandwidth for lossless audio. You may get LPCM through SPDIF but is not lossless
ANDYK48 is offline
post #9 of 10 Old 02-03-2010, 03:02 PM - Thread Starter
BigZAJ's Avatar
How can you identify what m2ts file is what?
BigZAJ is offline
post #10 of 10 Old 02-03-2010, 05:02 PM
kegobeer's Avatar
BigZAJ,
But can you play them from within Media Center? Are they easily cataloged for meta data, etc? I don't think that's possible, as Media Center does not support BD playback at all, so a third party app would be needed.
kegobeer is offline
Reply Home Theater Computers
