MakeMKV & Handbrake issue - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 01-22-2010, 12:59 PM - Thread Starter
redshinobi's Avatar
whats up all?!
so, i made some mkv's using MakeMKV 1.4.11 beta. the results are fine. however, i'd like to get the size smaller, like down to 60%. unfortunately when using handbrake, it errors out after like 5 seconds
any one else with this problem? im using win7. not sure if thats the problem. it was always ends up "handbrake.cli encountered a problem and has stopped working"...
i was able to encode/shrink other stuff, so i dont think it is handbrake. no sure... please help!!! thanks!
redshinobi is offline
post #2 of 16 Old 01-22-2010, 02:23 PM
Pagali's Avatar
Quoted: 12 Post(s)
Try Ripbot264. Works much better for me than any of the others.
Pagali is offline
post #3 of 16 Old 01-22-2010, 02:48 PM
hvn4179's Avatar
I'm doing exactly like you did (makemkv 1.4.11 beta then re-encode to mp4 w/ handbrake version 0.9.4) w/o any problem. However, they're running on XP SP2.
hvn4179 is offline
post #4 of 16 Old 01-22-2010, 03:58 PM
ScoHo's Avatar
Not for me. I recently tried both and while Handbrake seems a little slower it is easier to use and doesn't require 3 other programs to be installed. Quality seems just as good or better as well.
To original poster, I just started using Handbrake and have only ripped a few discs, but haven't gotten any errors (I'm using Windows 7 x64). Is it just for one particular disc? I would try the Handbrake forums. I do the same method - MakeMKV > Handbrake (h264 MKV).
ScoHo is offline
post #5 of 16 Old 01-22-2010, 05:51 PM
archer75's Avatar
Quoted: 222 Post(s)
Liked: 81
The problem with using makemkv is after your rip it you have to then demux it so you can throw the video in handbrake. Kind of a pain. Just rip with eac3to. Throw the video in handbrake and then merge with mkvmerge.
I have been having problems with ripbot and quality lately. So I started using handbrake and I had the same errors as you. The fix is to use the snapshot build.
But I get better results with handbrake now. Settings are auto crop, high profile and save as an mkv. For the file size I get better image quality in handbrake.
Streaming Devices: Nvidia Shield TV, 2x Roku 3's, 1st and 2nd gen chromecast, Amazon Fire TV stick 2nd gen, Apple TV 4, xbox 360, xbox one
Displays: Vizio M602i-B3, LG OLED65B6, panasonic ax100u on a 145" S-I-L-V-E-R painted screen, 40" Samsung(don't recall model #)
Receivers: Denon X3300, Yamaha RX-V663. Bluray/UHD player: Oppo UDP-203
Retired - HTPC: Intel e6300 2.8ghz, Intel DG45ID, 2gb DDR2, Radeon 5570, MCE IR receiver
archer75 is offline
post #6 of 16 Old 01-22-2010, 06:30 PM
ScoHo's Avatar
I haven't been doing that. I rip with MakeMKV and then when I encode with Handbrake I just don't include the audio. Is there a problem with doing that?
ScoHo is offline
post #7 of 16 Old 01-22-2010, 07:30 PM
chucky08016's Avatar
After you rip the movie with MakeMKV, try using MediaCoder. I've been using this to shrink the movies with great success with no issues at all.
Link: http://www.mediacoderhq.com/
No need to demux. MediaCoder can copy the audio over completely intact if you tell it to.
chucky08016 is offline
post #8 of 16 Old 01-23-2010, 12:25 AM - Thread Starter
redshinobi's Avatar
Thanks everyone.
Yeah, my friend uses ripbot but he is running to subtitle problems when trying play it on the Patriot Box Office. I'll give the other suggestions a try and let you guys know.
post #9 of 16 Old 01-27-2010, 02:17 PM
ScoHo's Avatar
redshinobi, did you ever figure out this error you were getting in Handbrake? I'm now getting it trying to encode 'The Dark Knight'.
chucky, I was looking at mediacoder. Looks pretty robust...I'm surprised there isn't more discussion of it on here as it is essentially a front-end for a lot of the programs already discussed. The nagware is a little annoying but that can be turned off for the most part. Seems you can even convert the HD audio to FLAC with it. The interface is kind of klunky, but there are settings galore. What settings do you use?
ScoHo is offline
post #10 of 16 Old 01-27-2010, 02:33 PM
pkscout's Avatar
This is a known bug with the current version of Handbrake. The SVN of the development build fixes this and works fine for me to convert the 36gb MKV file to a 2GB MP4 file (for my iPhone).
pkscout is offline
post #11 of 16 Old 03-08-2010, 10:44 AM - Thread Starter
redshinobi's Avatar
I'm using ripbot to compress it... sure takes a long time tho
I didnt want to use ripbot just cuz the audio part, from what i've read, isn't too great with ripbot. If I want good audio, they->forums suggests, tsmux-ing it ripbot the video, then mux the TrueHD(or whatever) back together. OH! what a long process, haha. Well I'm not going to care about Audio til I that Denon AVR... someday :S
post #12 of 16 Old 03-08-2010, 04:28 PM
Quoted: 424 Post(s)
Liked: 348
Have you tried the FLAC option in RipBot? Converting HD audio to FLAC creates no discernible difference in the audio as it is lossless. It's like converting a file from ZIP to RAR.
Balthazar2k4 is offline
post #13 of 16 Old 03-08-2010, 04:36 PM
archer75's Avatar
Quoted: 222 Post(s)
Liked: 81
If you use the proper decoders. I don't know if ripbot is capable of using arcsoft to decode DTS-MA HD and if it can't then it would indeed be lossy.
archer75 is offline
post #14 of 16 Old 03-08-2010, 08:18 PM
Quoted: 424 Post(s)
Liked: 348
RipBot does support the ArcSoft decoder. Go to the directory you have installed RipBot to. If you look in the "ax" directory under "tools", you will see the "ArcSoft DTS Decoder" directory. In there is a readme file that details how to setup its use.
post #15 of 16 Old 03-16-2010, 11:29 AM - Thread Starter
redshinobi's Avatar
Thanks Balthazar2k4. I'll give it a try.
Before I was using MakeMKV then ripbot... it's probably better to go anydvd and ripbot ?
anyone have a suggestion for a sub $400 AVR?
post #16 of 16 Old 03-16-2010, 08:18 PM
Quoted: 424 Post(s)
Liked: 348
I use AnyDVD then RipBot. It has worked great thus far. As for a receiver, I would tell you to wait if you can. There are a slew of new models with HDMI 1.4 coming down the chute in the next few months. There will be several models from various manufacturers under $400.
Reply Home Theater Computers
