ATI HD 5000 Series Known Problems (5870 5850 5770 5750 5670 5570 5450) - Page 29 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #841 of 2707 Old 03-03-2010, 01:21 PM
somy's Avatar
There is also one another issue I want to mention:
It seems that I cannot get x.v.color output to work
Anyone has experience?
somy is offline
post #842 of 2707 Old 03-03-2010, 05:02 PM
rjyap's Avatar
I can get the EDID for tulli to test out. I previously posted W6000 EDID and 805 EDID (without projector connected). Do you need another EDID from AVR with projector connected? This black level is giving me headache as every time I turn on my pc, I need to change the pixel format between YCbCr 4:4:4 and RGB Full until it give me 0-255 output for my current setting.
rjyap is offline
post #843 of 2707 Old 03-03-2010, 05:10 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 330
I don't think they support x.v.color do they?
Joel Barsotti
SpectraCal
CalMAN Lead Developer
sotti is offline
post #844 of 2707 Old 03-03-2010, 05:12 PM
Tulli's Avatar
Quoted: 117 Post(s)
Liked: 102
Well no, as the mod I sent to you has the projector EDID base block data in the base block (just as if it were repeated by the Onkyo 805) so it can perfectly be used to test for color problems on ATI 5xxxs.
Do you have a 5xxx card? ... I can't remember...
EDID Overrides (capture, install/uninstall, troubleshooting)
Tulli is offline
post #845 of 2707 Old 03-03-2010, 05:26 PM
dangerousbri's Avatar
Originally Posted by Andy o View Post
Can you try setting it to 24-bit 48 kHz, and 5.1? It may or may not fix the problem (probably not) but just in case. Can you try GPU-Z and monitor your system for a while and make sure GPU clock stays put? If you only have the problem with commercial DVDs then it might be encryption, have you tried ripping them with something like AnyDVD and see if it makes a difference?
I tried both those things and finally gave up. I put my old card back in the computer and I am sending it back. Thanks for all your help.
dangerousbri is offline
post #846 of 2707 Old 03-03-2010, 06:01 PM - Thread Starter
Andy o's Avatar
They're supposed to. I know I'm getting 30-bit deep color, but have no idea how I can test for xvYCC.
Andy o is offline
post #847 of 2707 Old 03-03-2010, 06:24 PM
tonytoronto's Avatar
Very exiting, I would very much like to be the volunteer, but unfortunately I cannot really connect my PC directly to my projector (cable is too short)
Would an Epson 8100 and ATI 5450 do?
tonytoronto is offline
post #848 of 2707 Old 03-03-2010, 07:16 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 330
oh wow look at that.
Joel Barsotti
SpectraCal
sotti is offline
post #849 of 2707 Old 03-03-2010, 07:57 PM
rjyap's Avatar
I had both 4850 and 5770. The EDID is capture using 4850 (as previously MonInfo doesn't work with 5xxx). 4850 is working fine but 5770 is giving me the wrong black level output for RGB Full.
I had check my projector settings and I can confirm the below tuning is correct for:
HDMI 0-255 - Brightness 50 and Contrast 50. Good for RGB Full range.
HDMI 16-240 - Brightness 43 and Contrast 57. Good for YCbCr 4:4:4, RGB Limited and also Xtreamer (NMT output at video level)
rjyap is offline
post #850 of 2707 Old 03-03-2010, 08:11 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 330
An interesting idea....
Since we know that RGB is correct and YCrCb is incorrect, what is the YCrCb output for a given stimulus. How can you go back and forth to test? How small of a bump would you need to have to see a difference?
Here is what I think happened.
Y has a range of 16-235, but Cr and Cb have a range for 16-240, I think they are using the 220 steps of Y instead of the 225 steps of Cr for the CR data. With the correct offset, but the wrong range you come up about 2 steps short on your CrCb data, wich does several things including increasing your green by about 3 or 4 pixels and red by 1 or 2 pixels.
At low stimulus percentages where each pixel step is a pretty sizeable percentage increase and with green being 70% of the luminance this could cause big percentage errors. At higher IRE's where the one or two pixel steps cause smalle relative increases in output, they'd converge on RGB output.
Exactly what we saw.
I wrote an RGB to YCrCb calculator to play with it. I'll test tonight to see if I can measure some stuff to confirm my theory.
RGB-YCC.zip 5.4130859375k . file
Joel Barsotti
SpectraCal
sotti is offline
post #851 of 2707 Old 03-03-2010, 08:42 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 330
actually I think Cr, Cb of -3 is the right answer, that means you don't have a legal RGB value until you have a Y of 6, wich I believe is the magic number where stuff started working in your waveform monitor.
Joel Barsotti
SpectraCal
sotti is offline
post #852 of 2707 Old 03-04-2010, 12:37 AM - Thread Starter
Andy o's Avatar
OK guys here's my EDID, sorry for taking so long.
vsx01_krp.zip 0.33984375k . file
File Type: zip vsx01_krp.zip (348 Bytes, 19 views)
Andy o is offline
post #853 of 2707 Old 03-04-2010, 12:48 AM
somy's Avatar
Yeah, I think so. Epson 8100 is also a 3LCD projector the same as mine Panasonic PT-AE3000.
somy is offline
post #854 of 2707 Old 03-04-2010, 12:53 AM
somy's Avatar
I know I'm probably a bit off the topic, but maybe the wrong color has something to do with xvYCC because xvYCC needs YCC output. However, I cannot enable xvYCC in my projector even though both my projector and receiver support xvYCC, so I assume this is another EDID issue.
somy is offline
post #855 of 2707 Old 03-04-2010, 12:55 AM
somy's Avatar
Interesting idea, so you're suggesting it is due to wrong conversion? I will try to record the R, G, B values of 75% red, 75% green and 75% Blue and 75% white today. The correct value of them should be (235-16)*0.75+16=180
Maybe ATI needs to fix this problem for us!
somy is offline
post #856 of 2707 Old 03-04-2010, 04:06 AM
sanderdvd's Avatar
Quoted: 163 Post(s)
Liked: 30
There is no perfect solution now, and to be safe just choose RGB full.
But like I said there are many things that can be changed so I assume there must be some things to tell about all these settings?
sanderdvd is offline
post #857 of 2707 Old 03-04-2010, 04:25 AM
somy's Avatar
Sorry I'm not sure I understand your question.
somy is offline
post #858 of 2707 Old 03-04-2010, 04:26 AM
somy's Avatar
Sotti,
I come to think that the colour issue I have might be because BT.601 is used instead of BT.709. Does anyone know if there is any BT 601 test pattern so that I can see if it looks correct?
somy is offline
post #859 of 2707 Old 03-04-2010, 05:32 AM
Tulli's Avatar
Quoted: 117 Post(s)
Liked: 102
That's the Kuro->AVR EDID, right? The AVR is most probably repeating the Kuro base block specs, but we can only be sure by comparing with the Kuro EDID.
Here's the EDID Manager analysis:
Code:
                        Time: 7:56:49 AM
                        Date: Thursday, March 04, 2010
                        EDID Manager Version: 1.0.0.14
        ___________________________________________________________________
        Block 0 (EDID Base Block), Bytes 0 - 127,  128  BYTES OF EDID CODE:
                        0   1   2   3   4   5   6   7   8   9
                000  |  00  FF  FF  FF  FF  FF  FF  00  41  2F
                010  |  00  00  01  01  01  01  00  12  01  03
                020  |  80  6E  3E  78  2A  6D  A4  A1  54  35
                030  |  B3  26  14  4A  52  2F  CF  00  81  80
                040  |  8B  C0  A9  40  81  40  81  00  81  40
                050  |  90  40  B3  00  02  3A  80  18  71  38
                060  |  2D  40  58  2C  45  00  4E  6C  42  00
                070  |  00  1E  02  3A  80  D0  72  38  2D  40
                080  |  10  2C  45  80  4E  6C  42  00  00  1E
                090  |  00  00  00  FD  00  17  55  0F  45  10
                100  |  00  0A  20  20  20  20  20  20  00  00
                110  |  00  FC  00  56  53  58  2D  30  31  54
                120  |  58  48  0A  20  20  20  01  25
(8-9)           ID Manufacture Name : PIO
(10-11)         ID Product Code     : 0000
(12-15)         ID Serial Number    : N/A
(16)            Week of Manufacture : 0
(17)            Year of Manufacture : 2008
(18)            EDID Version Number : 1
(19)            EDID Revision Number: 3
(20)            Video Input Definition       : Digital
(21)            Maximum Horizontal Image Size: 110 cm
(22)            Maximum Vertical Image Size  : 62 cm
(23)            Display Gamma                : 2.20
(24)            Power Management and Supported Feature(s):
                        Active Off/Very Low Power, RGB Color, Non-sRGB, Preferred Timing Mode
(25-34)         Color Characteristics
                        Red Chromaticity   :  Rx = 0.626  Ry = 0.330
                        Green Chromaticity :  Gx = 0.206  Gy = 0.696
                        Blue Chromaticity  :  Bx = 0.150  By = 0.080
                        Default White Point:  Wx = 0.290  Wy = 0.320
(35)            Established Timings I
                        640 x 480 @ 60Hz (IBM, VGA)
                        640 x 480 @ 72Hz (VESA)
                        640 x 480 @ 75Hz (VESA)
                        800 x 600 @ 56Hz (VESA)
                        800 x 600 @ 60Hz (VESA)
(36)            Established Timings II
                        800 x 600 @ 72Hz (VESA)
                        800 x 600 @ 75Hz (VESA)
                        1024 x 768 @ 60Hz (VESA)
                        1024 x 768 @ 70Hz(VESA)
                        1024 x 768 @ 75Hz (VESA)
                        1280 x 1024 @ 75Hz (VESA)
(37)            Manufacturer's Timings (Not Used)
(38-53)         Standard Timings
                        1280x1024 @ 60 Hz (5:4 Aspect Ratio)
                        1360x765 @ 60 Hz (16:9 Aspect Ratio)
                        1600x1200 @ 60 Hz (4:3 Aspect Ratio)
                        1280x960 @ 60 Hz (4:3 Aspect Ratio)
                        1280x800 @ 60 Hz (16:10 Aspect Ratio)
                        1400x1050 @ 60 Hz (4:3 Aspect Ratio)
                        1680x1050 @ 60 Hz (16:10 Aspect Ratio)
(54-71)         Detailed Descriptor #1: Preferred Detailed Timing (1920x1080 @ 60Hz)
                        Pixel Clock            : 148.5 MHz
                        Horizontal Image Size  : 1102 mm
                        Vertical Image Size    : 620 mm
                        Refresh Mode           : Non-interlaced
                        Normal Display, No Stereo
                        Horizontal:
                                Active Time     : 1920 Pixels
                                Blanking Time   : 280 Pixels
                                Sync Offset     : 88 Pixels
                                Sync Pulse Width: 44 Pixels
                                Border          : 0 Pixels
                                Frequency       : 67 kHz
                        Vertical:
                                Active Time     : 1080 Lines
                                Blanking Time   : 45 Lines
                                Sync Offset     : 4 Lines
                                Sync Pulse Width: 5 Lines
                                Border          : 0 Lines
                        Digital Separate, Horizontal Polarity (+), Vertical Polarity (+)
                        Modeline: "1920x1080" 148.500 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync
(72-89)         Detailed Descriptor #2: Detailed Timing (1920x1080 @ 50Hz)
                        Horizontal:
                                Blanking Time   : 720 Pixels
                                Sync Offset     : 528 Pixels
                                Border          : 0 Pixels
                                Frequency       : 56 kHz
                        Vertical:
                                Border          : 0 Lines
                        Modeline: "1920x1080" 148.500 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync
(90-107)        Detailed Descriptor #3: Monitor Range Limits
                        Horizontal Scan Range: 15kHz-69kHz
                        Vertical Scan Range  : 23Hz-85Hz
                        Supported Pixel Clock: 160 MHz
                        Secondary GTF        : Not Supported
(108-125)       Detailed Descriptor #4: Monitor Name
                        Monitor Name: VSX-01TXH
(126-127)       Extension Flag and Checksum
                        Extension Block(s)  : 1
                        Checksum Value      : 37
        Block 1 ( CEA-861 Extension Block), Bytes 128 - 255,  128  BYTES OF EDID CODE:
                        0   1   2   3   4   5   6   7   8   9
                128  |  02  03  51  F1  5C  14  05  1F  90  12
                138  |  03  13  04  11  02  16  07  15  06  20
                148  |  01  1E  26  0F  24  1D  25  0E  23  1A
                158  |  0B  19  0A  3B  09  7F  07  0F  7F  07
                168  |  15  07  50  3E  1E  C0  4D  02  00  57
                178  |  06  00  5F  7E  01  67  7E  00  77  1F
                188  |  03  83  4F  00  00  6C  03  0C  00  13
                198  |  00  B8  2D  C0  11  11  22  22  E2  00
                208  |  79  01  1D  80  D0  72  1C  16  20  10
                218  |  2C  25  80  4E  6C  42  00  00  9E  01
                228  |  1D  80  18  71  1C  16  20  58  2C  25
                238  |  00  4E  6C  42  00  00  9E  00  00  00
                248  |  00  00  00  00  00  00  00  AD
(128-130)       Extension Header
                        Revision Number    :    3
                        DTD Starting Offset:    81
(131)           Display Support
                        DTV Underscan, Basic Audio, YCbCr 4:4:4, YCbCr 4:2:2
                        Number of Native Formats: 1
(132-160)       Video Data Block
                        1920x1080i @ 50Hz - HDTV (16:9, 1:1)
                        1920x1080i @ 59.94/60Hz - HDTV (16:9, 1:1)
                        1920x1080p @ 50Hz - HDTV (16:9, 1:1)
                        1920x1080p @ 59.94/60Hz - HDTV (16:9, 1:1) [Native]
                        720x576p @ 50Hz - EDTV (16:9, 64:45)
                        720x480p @ 59.94/60Hz - EDTV (16:9, 32:27)
                        1280x720p  @ 50Hz - HDTV  (16:9, 1:1)
                        1280x720p @ 59.94/60Hz - HDTV (16:9, 1:1)
                        720x576p @ 50Hz - EDTV (4:3, 16:15)
                        720x480p @ 59.94/60Hz - EDTV (4:3, 8:9)
                        720(1440)x576i @ 50Hz - SDTV (16:9, 64:45)
                        720(1440)x480i @ 59.94/60Hz - SDTV (16:9, 32:27)
                        720(1440)x576i @ 50Hz - SDTV (4:3, 16:15)
                        720(1440)x480i @ 59.94/60Hz - SDTV (4:3, 8:9)
                        1920x1080p @ 23.97/24Hz - HDTV(16:9, 1:1)
                        640x480p @ 59.94/60Hz - EDTV (4:3, 1:1)
                        1440x576p @ 50Hz (16:9, 32:45 or 64:45³ ))
                        2880x576p @ 50Hz (16:9, 16:45, 32:45, or 64:45´)
                        1440x480p @ 59.94/60Hz (16:9, 16:27 or 32:27³ )
                        2880x480p @ 59.94Hz/60Hz (16:9, 8:27, 16:27, or 32:27´ )
                        1440x576p @ 50Hz (4:3, 8:45 or 16:15³ )
                        2880x576p @ 50Hz (4:3, 4:15, 8:15, or 16:15´ )
                        1440x480p @ 59.94/60Hz (4:3, 4:9 or 8:9³ )
                        2880x480p @ 59.94Hz/60Hz (4:3, 2:9, 4:9, or 8:9´ )
                        2880x576i @ 50Hz (16:9, 16:45-160:45² )
                        2880x480i @ 59.94/60Hz (16:9, 8:27-80:27² )
                        2880x576i @ 50Hz (4:3, 2:15 – 20:15² )
                        2880x480i @ 59.94/60Hz (4:3, 2:9–20:9²)
(161-188)       Audio Data Block
                        Audio Format #1    : LPCM, 2-Channel, 24-Bit, 20-Bit, 16-Bit
                        Sampling Frequency : 192 kHz, 176.4 kHz, 96 kHz, 88.2 kHz, 48 kHz, 44.1 kHz, 32 kHz
                        Audio Format #2    : LPCM, 8-Channel, 24-Bit, 20-Bit, 16-Bit
                        Audio Format #3    : AC-3, 6-Channel, 640 k Max bit rate
                        Sampling Frequency : 48 kHz, 44.1 kHz, 32 kHz
                        Audio Format #4    : DTS, 7-Channel, 1536 k Max bit rate
                        Sampling Frequency : 96 kHz, 88.2 kHz, 48 kHz, 44.1 kHz
                        Audio Format #5    : DSD, 6-Channel
                        Sampling Frequency : 44.1 kHz
                        Audio Format #6    : E-AC-3, 8-Channel
                        Audio Format #7    : DTS-HD, 8-Channel
                        Audio Format #8    : MLP/Dolby TrueHD, 8-Channel
                        Audio Format #9    : WMA Pro, 8-Channel
                        Sampling Frequency : 96 kHz, 88.2 kHz, 48 kHz, 44.1 kHz, 32 kHz
(189-192)       Speaker Allocation Data Block (SADB)
                        Rear Left Center/Rear Right Center Audio Channel (RLC/RRC)
                        Rear Left/Rear Right Audio Channel (RL/RR)
                        Front Center Audio Channel (FC)
                        Low Frequency Effect Audio Channel (LFE)
                        Front Left/Front Right Audio Channel (FL/FR)
(193-205)       Vendor Specific Data Block (VSDB)
                        IEEE Registration Identifier: 0x000C03
                        CEC Physical Address        : 0x0013
                        Maximum TMDS Clock          : 165MHz
(206-208)       Video Capability Data Block (VCDB)
(209-226)       Detailed Descriptor #1: Detailed Timing (1920x1080i @ 50Hz 16:9 Apsect Ratio)
                        Pixel Clock            : 74.25 MHz
                        Refresh Mode           : Interlaced
                        Horizontal:
                                Border          : 0 Pixels
                                Frequency       : 28 kHz
                        Vertical:
                                Active Time     : 540 Lines
                                Blanking Time   : 22 Lines
                                Sync Offset     : 2 Lines
                                Border          : 0 Lines
                        Modeline: "1920x1080i" 74.250 1920 2448 2492 2640 1080 1084 1094 1124 interlace +hsync +vsync
(227-244)       Detailed Descriptor #2: Detailed Timing (1920x1080i @ 60Hz 16:9 Apsect Ratio)
                        Horizontal:
                                Border          : 0 Pixels
                                Frequency       : 33 kHz
                        Vertical:
                                Border          : 0 Lines
                        Modeline: "1920x1080i" 74.250 1920 2008 2052 2200 1080 1084 1094 1124 interlace +hsync +vsync
(245-254)       Post DTD Padding
                        Residual Byte Padding: 00000000000000000000
(255)           Checksum Value: 173
Tulli is offline
post #860 of 2707 Old 03-04-2010, 05:46 AM
Mike5's Avatar
See if this is useful.
Color 601-709.zip 49.328125k . file
Mike5 is offline
post #861 of 2707 Old 03-04-2010, 05:51 AM - Thread Starter
Andy o's Avatar
Oh man, you want me to move my TV? Yeah, that one's passing through the VSX-01TXH. I thought I edited the post with that info but I guess I forgot and closed the tab. I'll see if I can just mirror my way behind the monitor tomorrow and connect the cable.
Andy o is offline
post #862 of 2707 Old 03-04-2010, 06:08 AM
Tulli's Avatar
Quoted: 117 Post(s)
Liked: 102
It's most probably OK, from what I see, so you could really just install the EDID override with the .inf I created from that binary and test for color changes.
vsx01_krp Monitor Driver.zip 1.2353515625k . file
Tulli is offline
post #863 of 2707 Old 03-04-2010, 06:12 AM
somy's Avatar
Tulli,
Do you know what does this section do:
somy is offline
post #864 of 2707 Old 03-04-2010, 06:15 AM
somy's Avatar
Mine is here:
http://www.avsforum.com/avs-vb/attac...0&d=1267201627
It's through my Onkyo 906 unfortunately, but maybe it's worth to compare mine to Andy's
somy is offline
post #865 of 2707 Old 03-04-2010, 06:17 AM
somy's Avatar
Thanks Mike, but I prefer a video that can be played in PowerDVD.
somy is offline
post #866 of 2707 Old 03-04-2010, 06:23 AM
nickpicker's Avatar
Tulli,
That's the color primaries for the display, useful e.g. when creating a custom 3D-LUT for madVR.
The problem is, of course, that the manufacturer sets those values for each device of the product family, i.e. they are not compensated for small deviations in the manufacturing process, or the age or operating temperature of your tv.
nickpicker is offline
post #867 of 2707 Old 03-04-2010, 06:27 AM
nickpicker's Avatar
Code:
                        Time: 7:56:49 AM
                        0   1   2   3   4   5   6   7   8   9
                        Horizontal:
                                Border          : 0 Pixels
                                Frequency       : 67 kHz
                        Vertical:
                                Border          : 0 Lines
                        Horizontal:
                                Border          : 0 Pixels
                                Frequency       : 56 kHz
                        Vertical:
                                Border          : 0 Lines
                        Checksum Value      : 37
                        0   1   2   3   4   5   6   7   8   9
                        Revision Number    :    3
                        2880x576i @ 50Hz (4:3, 2:15 - 20:15² )
                        2880x480i @ 59.94/60Hz (4:3, 2:9-20:9²)
                        Horizontal:
                                Border          : 0 Pixels
                                Frequency       : 28 kHz
                        Vertical:
                                Border          : 0 Lines
                        Horizontal:
                                Border          : 0 Pixels
                                Frequency       : 33 kHz
                        Vertical:
                                Border          : 0 Lines
Two things:
1. The device identifies itself as Monitor Name: VSX-01TXH, so the AVR is definitely not passing-thru all monitor information 1:1.
2. The device says it supports: YCbCr 4:4:4, YCbCr 4:2:2. So no RGB 4:4:4 (as my Panasonic plasma reports). Is that correct?
post #868 of 2707 Old 03-04-2010, 06:45 AM
Tulli's Avatar
Quoted: 117 Post(s)
Liked: 102
Originally Posted by nickpicker View Post
Two things:
As for 1., no, that's how it works as I explained in previous post. Even with the Plasma going through the AVR the Monitor Descriptor will be replaced by the AVR's.
As for 2., that's the "Standard Default Color Space" bit set to 0 (RGB, right?).
I just checked a sample of EDIDs in my DB (monitor, projector, plasma, DLP, LCD), and ALL of them have the same setting.
Tulli is offline
post #869 of 2707 Old 03-04-2010, 06:58 AM
somy's Avatar
Mine doesn't support RGB, do you see anything special in mine EDID?
somy is offline
post #870 of 2707 Old 03-04-2010, 07:00 AM - Thread Starter
Andy o's Avatar
Ooops sorry, it was not for me. I'm fine as far as I'm concerned. It was for others to try if my display's EDID (not the AVR's audio block) would get their cards to output full RGB pixel format as it should.
Andy o is offline
Reply Home Theater Computers
