EDID Overrides to solve bitstreaming issues for ATI 5xxx's - Page 12 - AVS Forum | Home Theater Discussions And Reviews
 12Likes
post #331 of 4297 Old 02-26-2010, 05:14 AM
Beamer's Avatar
Tulli
Now we know that my registry is smarter than the average Is there any mileage in updating the EDID override entry with your new findings?
I don't profess to entirely understand what you discovered but I am intrigued to understand who is really responsible for the problem and what the fix my ultimately be.
I rebuild my system several times per year for one reason or another and would hate to have to go back to the override file and associated dual monitor issues.
Beamer is offline
post #332 of 4297 Old 02-26-2010, 05:43 AM
somy's Avatar
Tulli, I have a questions regarding EDID overwrite for you.
If I take EDID from Windows, can I modify it and then overwrite it?
I'm asking because it's not possible to connect to my projector directly via HDMI, and what I need is to add accept RGB to EDID.
somy is offline
post #333 of 4297 Old 02-26-2010, 05:52 AM - Thread Starter
Tulli's Avatar
Quoted: 118 Post(s)
Liked: 103
Well, this is what I understand:
1. Uninstalling the override, even with the option of deleting all driver software, does not prevent leftovers in the registry. So further cleanup is needed by uninstalling "hidden" devices (I've added the procedure to the OP).
2. With leftovers in place in the registry it is still possible for the system to still associate the override to a "GenericPnP" monitor. I have no clue as to how this works.
And what I still don't understand in your case is how or why you had issues with the Kuro when first installing the override, and now you don't.
Can you please do this little test?:
- Connect to the Kuro through the Denon.
- Now, let's look for which reg entry is active. To do this go to Device Manager, right click on the corresponding "GenericPnP" monitor, and select Properties.
Select "Device Instance Path" for Property. That's the exact device entry in the registry at Computer\\HKEY_LOCALMACHINE\\System\\CurrentControlSet\\Enum \\DISPLAY.
EDID Overrides (capture, install/uninstall, troubleshooting)
Tulli is offline
post #334 of 4297 Old 02-26-2010, 05:59 AM - Thread Starter
Tulli's Avatar
Quoted: 118 Post(s)
Liked: 103
Absolutely.
Tulli is offline
post #335 of 4297 Old 02-26-2010, 07:04 AM
Pyrophoric's Avatar
Originally Posted by Tulli View Post
Here's your mod.
Great, will try it when I get home tonight. Thanks!
Pyrophoric is offline
post #336 of 4297 Old 02-26-2010, 07:26 AM
jplant's Avatar
Thanks Tulli! blu ray bitstreaming is 100% working now!
jplant is offline
post #337 of 4297 Old 02-26-2010, 08:28 AM
somy's Avatar
Hi Tulli,
My inf in registry is attached.
I don't see anything that disallows RGB full output.
Strange.
Onkyo906.zip 1.1796875k . file
somy is offline
post #338 of 4297 Old 02-26-2010, 08:29 AM
vladd's Avatar
Liked: 39
This might not work. Your AVR may not be able to pass the RGB data or may convert it to YCC. I'd be interested to see if it works though. You will want to change byte 24h (0 based).
vladd is offline
post #339 of 4297 Old 02-26-2010, 08:31 AM
vladd's Avatar
Liked: 39
Hi Tulli,
Strange.
According to your EDID, your display is an RGB display so nothing is preventing it. Are you sure your display is capable of full RGB? If so, can you get full RGB if you connect directly to the TV instead of going through the AVR?
vladd is offline
post #340 of 4297 Old 02-26-2010, 09:08 AM - Thread Starter
Tulli's Avatar
Quoted: 118 Post(s)
Liked: 103
Hi Tulli,
Strange.
Like vladd says bits 4-0 of byte 24 can be set to "non RGB multicolour" (see here).
But I also need the specific EDID of the display device directly connected to the ATI.
Tulli is offline
post #341 of 4297 Old 02-26-2010, 01:30 PM
Beamer's Avatar
Its points to the entry that ends with UID259. I'm hopeful you can pick it out from the earlier registry posting. It appeared like a generic monitor entry.
Beamer is offline
post #342 of 4297 Old 02-26-2010, 02:44 PM
Andy o's Avatar
I just downloaded the latest version of moninfo and I'm not getting the realtime EDID of my 5770 and the KRP-500 monitor (neither connected directly to it nor through the VSX-01 AVR). somy was gonna try my EDID which I can confirm can take 0-255 signals.
Andy o is offline
post #343 of 4297 Old 02-26-2010, 02:56 PM
vladd's Avatar
Liked: 39
The UID259 entry is the one that is overridden in your registry. I think it's safe to say that overrides do not get removed even when uninstalling the driver but I'm going to test this extensively with my laptop next week (since I won't be able to do much else).
You can try useing my GetEDID tool. If you are running an override, it will grab the override EDID and it will grab the realtime if you are not. (Basically it grabs exactly what the ATI driver is seeing.)
Edit: The EDID that somy posted earlier clearly accepts RGB signals. There is nothing in an EDID datablock that says if it accepts limited or exanded RGB though, only YCC 4:4:4 and YCC 4:2:2 (his accepts both).
vladd is offline
post #344 of 4297 Old 02-26-2010, 03:00 PM
Andy o's Avatar
Can I just run it through the AVR, or do I have to do it directly to the monitor? It's a PITA to move it to connect the cable (the AVR passes through the video, not like for instance HK's which reprocess always and probably have their own video EDID).
Andy o is offline
post #345 of 4297 Old 02-26-2010, 03:05 PM
vladd's Avatar
Liked: 39
If you are getting RGB 0-255 throught the AVR, you can capture the EDID that way.
vladd is offline
post #346 of 4297 Old 02-26-2010, 03:11 PM
Andy o's Avatar
Yep, getting all the same options seemingly. I'll get to it, thanks.
Andy o is offline
post #347 of 4297 Old 02-26-2010, 03:29 PM - Thread Starter
Tulli's Avatar
Quoted: 118 Post(s)
Liked: 103
There are 2 groups of entries ending with UID259:
  1. The connection through the DENON:
    DISPLAY\\DON0009\\5&206f7bc7&0&UID259
    and
  2. the Kuro direct one:
    DISPLAY\\PIO00C4\\5&206f7bc7&0&UID259
Which one are you getting? (DON0009 or PIO00C4)
Both have the device description of the GenericPnp Monitor:
"DeviceDesc"="@monitor.inf,%pnpmonitor.devicedesc%;Generic PnP Monitor"
Here's the first group going through the DENON with the override:
Code:
[HKEY_LOCAL_MACHINE\\SYSTEM\\CurrentControlSet\\Enum\\DISPLAY\\DON0009\\5&206f7bc7&0&UID259]
"Capabilities"=dword:000000e4
"ConfigFlags"=dword:00000000
"HardwareID"=hex(7):4d,00,4f,00,4e,00,49,00,54,00,4f,00,52,00,5c,00,44,00,4f,\\
  00,4e,00,30,00,30,00,30,00,39,00,00,00,00,00
"CompatibleIDs"=hex(7):2a,00,50,00,4e,00,50,00,30,00,39,00,46,00,46,00,00,00,\\
  00,00
"ContainerID"="{1f0bcaf1-0a9a-11df-befe-001fd080d22b}"
"ClassGUID"="{4d36e96e-e325-11ce-bfc1-08002be10318}"
"Driver"="{4d36e96e-e325-11ce-bfc1-08002be10318}\\\\0002"
"Security"=hex:01,00,04,90,00,00,00,00,00,00,00,00,00,00,00,00,14,00,00,00,02,\\
  00,60,00,04,00,00,00,00,00,14,00,00,00,00,10,01,01,00,00,00,00,00,05,12,00,\\
  00,00,00,00,18,00,00,00,00,10,01,02,00,00,00,00,00,05,20,00,00,00,20,02,00,\\
  00,01,00,18,00,00,00,00,10,01,02,00,00,00,00,00,05,20,00,00,00,2b,02,00,00,\\
  00,00,14,00,00,00,00,10,01,01,00,00,00,00,00,05,04,00,00,00
"Class"="Monitor"
"Mfg"="@monitor.inf,%generic%;(Standard monitor types)"
"Service"="monitor"
[HKEY_LOCAL_MACHINE\\SYSTEM\\CurrentControlSet\\Enum\\DISPLAY\\DON0009\\5&206f7bc7&0&UID259\\Device Parameters]
"EDID"=hex:00,ff,ff,ff,ff,ff,ff,00,11,ee,09,00,01,01,01,01,00,11,01,03,80,6e,\\
  3e,78,2a,d7,b3,ae,51,50,94,23,0c,4a,47,21,08,00,81,80,01,01,01,01,01,01,01,\\
  01,01,01,01,01,01,01,02,3a,80,d0,72,38,2d,40,10,2c,45,80,4e,6c,42,00,00,1e,\\
  02,3a,80,18,71,38,2d,40,58,2c,45,00,4e,6c,42,00,00,1e,00,00,00,fd,00,17,3d,\\
  0f,45,0f,00,0a,20,20,20,20,20,20,00,00,00,fc,00,44,45,4e,4f,4e,2d,41,56,41,\\
  4d,50,0a,20,01,6c
"MaxResolution"="1600,1200"
"DPMS"="1"
[HKEY_LOCAL_MACHINE\\SYSTEM\\CurrentControlSet\\Enum\\DISPLAY\\DON0009\\5&206f7bc7&0&UID259\\Device Parameters\\EDID_OVERRIDE]
"0"=hex:00,ff,ff,ff,ff,ff,ff,00,11,ee,09,00,01,01,01,01,00,11,01,03,80,6e,3e,\\
  78,2a,d7,b3,ae,51,50,94,23,0c,4a,47,21,08,00,81,80,01,01,01,01,01,01,01,01,\\
  01,01,01,01,01,01,02,3a,80,d0,72,38,2d,40,10,2c,45,80,4e,6c,42,00,00,1e,02,\\
  3a,80,18,71,38,2d,40,58,2c,45,00,4e,6c,42,00,00,1e,00,00,00,fd,00,17,3d,0f,\\
  45,0f,00,0a,20,20,20,20,20,20,00,00,00,fc,00,44,45,4e,4f,4e,2d,41,56,41,4d,\\
  50,0a,20,01,6c
"1"=hex:02,03,4b,f1,5c,14,05,9f,10,12,03,13,04,11,02,16,07,15,06,20,01,0e,23,\\
  0f,24,1d,25,1e,26,0a,0b,19,1a,38,09,7f,07,0f,7f,07,17,07,50,3f,06,c0,4d,02,\\
  00,57,06,00,5f,7e,01,67,5e,00,83,5f,00,00,6c,03,0c,00,11,00,b8,2d,c0,11,11,\\
  22,22,01,1d,80,d0,72,1c,16,20,10,2c,25,80,4e,6c,42,00,00,9e,01,1d,80,18,71,\\
  1c,16,20,58,2c,25,00,4e,6c,42,00,00,9e,00,00,00,00,00,00,00,00,00,00,00,00,\\
  00,00,00,00,d1
[HKEY_LOCAL_MACHINE\\SYSTEM\\CurrentControlSet\\Enum\\DISPLAY\\DON0009\\5&206f7bc7&0&UID259\\Device Parameters\\MODES]
[HKEY_LOCAL_MACHINE\\SYSTEM\\CurrentControlSet\\Enum\\DISPLAY\\DON0009\\5&206f7bc7&0&UID259\\Device Parameters\\MODES\\1600,1200]
[HKEY_LOCAL_MACHINE\\SYSTEM\\CurrentControlSet\\Enum\\DISPLAY\\DON0009\\5&206f7bc7&0&UID259\\LogConf]
[HKEY_LOCAL_MACHINE\\SYSTEM\\CurrentControlSet\\Enum\\DISPLAY\\DON0009\\5&206f7bc7&0&UID259\\Control]
And here the second group (the Kuro directly connected to the ATI) with no override:
Code:
[HKEY_LOCAL_MACHINE\\SYSTEM\\CurrentControlSet\\Enum\\DISPLAY\\PIO00C4]
[HKEY_LOCAL_MACHINE\\SYSTEM\\CurrentControlSet\\Enum\\DISPLAY\\PIO00C4\\5&206f7bc7&0&UID259]
"HardwareID"=hex(7):4d,00,4f,00,4e,00,49,00,54,00,4f,00,52,00,5c,00,50,00,49,\\
  00,4f,00,30,00,30,00,43,00,34,00,00,00,00,00
  00,00
"ContainerID"="{a91a7c51-0dca-11df-9125-001fd080d22b}"
"Driver"="{4d36e96e-e325-11ce-bfc1-08002be10318}\\\\0004"
"Class"="Monitor"
"Service"="monitor"
[HKEY_LOCAL_MACHINE\\SYSTEM\\CurrentControlSet\\Enum\\DISPLAY\\PIO00C4\\5&206f7bc7&0&UID259\\Device Parameters]
"EDID"=hex:00,ff,ff,ff,ff,ff,ff,00,41,2f,c4,00,00,00,00,00,00,12,01,03,80,6e,\\
  0f,45,0f,00,0a,20,20,20,20,20,20,00,00,00,fc,00,50,49,4f,4e,45,45,52,5f,54,\\
  56,0a,20,20,01,1e
[HKEY_LOCAL_MACHINE\\SYSTEM\\CurrentControlSet\\Enum\\DISPLAY\\PIO00C4\\5&206f7bc7&0&UID259\\LogConf]
Tulli is offline
post #348 of 4297 Old 02-26-2010, 03:44 PM - Thread Starter
Tulli's Avatar
Quoted: 118 Post(s)
Liked: 103
Originally Posted by vladd View Post
... I think it's safe to say that overrides do not get removed even when uninstalling the driver ...
I've tested today and the override reg entry is in fact removed after uninstall (with the option of "Delete all diver software for this device" selected, when available).
As shown in my previous post, Beamer has the override identified as a GenericPnP monitor. I don't know how it got through, but if the uninstall procedure that I added to the OP is followed to the letter, all overrides reg entries will be removed (at least I have not been able to produce a leftover by following the procedure).
Tulli is offline
post #349 of 4297 Old 02-26-2010, 03:47 PM
vladd's Avatar
Liked: 39
Great, so you're still leaving it up to me to figure out if I'm reading an override or not. Thanks a lot.
vladd is offline
post #350 of 4297 Old 02-26-2010, 03:48 PM - Thread Starter
Tulli's Avatar
Quoted: 118 Post(s)
Liked: 103
That's really odd indeed, and that's the version that I'm using with no issues on a 5750 and a 5770 HTPCs, WinX32 & WinX64, Cat 10.2 in both.
Tulli is offline
post #351 of 4297 Old 02-26-2010, 05:27 PM
trapo's Avatar
I reported my clean test result in the other thread, but it's concentrated in video issues now and my post were lost. After clean the registry entries and reboot, I tested the HD formats with default monitor driver and you're right, TrueHD has gone, only DTS-HD works. I reinstalled EDID override (modded with U2410 ICC color profile) and it works fine again. One last doubt: if I have a 5.1 system, I don't need to change the last byte (192kHz) of the audio block to "7E", am I right?
Thanks again, Tulli.
trapo is offline
post #352 of 4297 Old 02-26-2010, 08:02 PM - Thread Starter
Tulli's Avatar
Quoted: 118 Post(s)
Liked: 103
You're right, "7E" would only set 176.4Khz as supported, which you don't need. Thx for the report, trapo!
Tulli is offline
post #353 of 4297 Old 02-27-2010, 12:22 AM
Beamer's Avatar
    and
Code:
  00,00
"Class"="Monitor"
"Service"="monitor"
  4d,50,0a,20,01,6c
"DPMS"="1"
  50,0a,20,01,6c
  00,00,00,00,d1
Code:
  00,00
"Class"="Monitor"
"Service"="monitor"
  56,0a,20,20,01,1e
Sorry, I knew being lazy and not posting the whole entry would backfire
It was this one: DISPLAY\\DON0009\\5&206f7bc7&0&UID259
Beamer is offline
post #354 of 4297 Old 02-27-2010, 05:27 AM
riverace's Avatar
I cant bitstream TrueHD, any help would be appreciated
HK-354+Vizio-VF551.zip 1.443359375k . file
riverace is offline
post #355 of 4297 Old 02-27-2010, 05:38 AM
somy's Avatar
Thanks for your help! The EDID is not accurate since I'm getting it from my AVR. In my AVR (Onkyo 906) I set HDMI to through.
Maybe the problem is that my display (panasonic PT-AE3000) doesn't accept RGB. It mentions in the manual that when conneting via DVI or sVGA, the colour space is RGB.
Anyway, there is also a problem for me to get correct colour if I output YCrCb, so I'll have to live with RGB full (which will be compressed by ATI to YUV 16/235) and expand everything to 0-255.
somy is offline
post #356 of 4297 Old 02-27-2010, 05:53 AM
Pyrophoric's Avatar
Here's your mod.
Thank's again for you help. Unfortunately, the EDID override didn't solve the mouse lag issue. Maybe it's time I call Denon tech and see what suggestions they have.
Still, I am fine running one HDMI for audio and one for video directly to the TV.
post #357 of 4297 Old 02-27-2010, 08:03 AM
Georgios1's Avatar
Tulli,
thanks a million !!! Thanks for your help and patience !!!
The override worked perfectly on both my pj and Tv !!
Bitstreaming Dolby True Hd without any problems now...
Thanks again
Georgios1 is offline
post #358 of 4297 Old 02-27-2010, 08:07 AM - Thread Starter
Tulli's Avatar
Quoted: 118 Post(s)
Liked: 103
Strange, TrueHD is marked as supported for all sample rates in the HK354 EDID. Can you bitstream DTS HD?
Tulli is offline
post #359 of 4297 Old 02-27-2010, 10:43 AM
riverace's Avatar
No neither one, TMT3 says it is (when I select information) but the receiver does not display MA or HD, just standard DD / DTS. There is a high likelyhood I dont know WTF im doing, but Ive followed all the advise here and all is working except for the HD / MA bitstreaming. Video card is a Power Color 5450, Ive downlocked it as Andy O sugested and I currently don't have any issues, save what I thought could be an EDID issue bitstream lossless audio.
Any guidance is appreciated.
riverace is offline
post #360 of 4297 Old 02-27-2010, 10:48 AM
cybrsage's Avatar
Liked: 154
[BREAKING NEWS]
February 24, 2010
So guys
we finally found the true cause of the bitstreaming issue (thanks to rasmusb - posting on doom9.org - and SamuriHL, who led me to solution). It's a FAULTY value in the EDIDs of DENON, SONY, and some ONKYO AVRs/AVPs which sets 192kz as UNSUPPORTED for TrueHD, and even DTS HD on the SONYs that I've checked (which should be right according to the DTS HD Whitepaper though ... thx to Davinleeds for the reference).
This means that ATI was never responsible at all for the issue. OTH maybe ATI could still produce a fix so that everyone can bitstream on the 5xxxs without needing an EDID override. So post a feedback to ask them for the fix, and even leave a link to this thread, by going to the following page:
http://www.amdsurveys.com/se.ashx?s=5A1E27D27E29B0E3
[/BREAKING NEWS]
Does this mean you need to make a new EDID override for my Panasonic Plasma - Denon 3808 combo?
cybrsage is offline
Reply Home Theater Computers
