EDID Overrides to solve bitstreaming issues for ATI 5xxx's - Page 134 - AVS Forum
 1Likes
post #3991 of 4009 Old 06-10-2014, 11:19 AM
papanik's Avatar
Hi dado7777, I have the same problem (only my secondary graphics card is nvidia, http://www.avsforum.com/t/1091403/edid-override-thread/3120#post_24814158), if you make any progress please post here.
Thank you
dado7777 likes this.
papanik is offline
post #3992 of 4009 Old 06-10-2014, 12:43 PM
dado7777's Avatar
Sorry to hear that. I asked all the official suppliers included but they give very elementary answers.
If I do I will, please do the same, good luck.
dado7777 is offline
post #3993 of 4009 Old 06-10-2014, 10:23 PM
rollcage7's Avatar
As you can assume i am also having a bitstream problem with Report.zip 5k .zip file
GraphiccardATIHD55502GB.doc 1682k .doc file
I know you can sort this problem... Waiting for your kind feedback
Regards
Ahmed
United Arab Emirates
rollcage7 is offline
post #3994 of 4009 Old 06-11-2014, 03:40 AM - Thread Starter
AVS Club Gold
Tulli's Avatar
Quoted: 16 Post(s)
Liked: 80
LGLW4500-ONKYOHT-538.zip 1k .zip file
Just in case, OS must be Win7 or 8.
rollcage7 likes this.
EDID Overrides (capture, install/uninstall, troubleshooting)
Tulli is offline
post #3995 of 4009 Old 06-11-2014, 03:42 AM
rollcage7's Avatar
Ohhhh Thanks for the Reply .. i ll check and get back to you ...
post #3996 of 4009 Old 06-11-2014, 09:13 PM
rollcage7's Avatar
Hi Tulli
Problem still not resolved .. DTS HD and DTS- HD MA audio bitstreem only in DTS or Dolby Digital in PowerDVD14 and TM respectively...
Attached Full REAL-TIMEEDID obtain from Monoinfo and GETEDID ... Hope to get it sort it out TODAY
post #3997 of 4009 Old 06-12-2014, 12:08 AM
Andremain's Avatar
Hello guys,
I am in some desperate need on an Optoma HD67 EDID file as my projector's EDID has become corrupted and Optoma wants me to send the projector from Cyprus to the UK for service . I am an IT guy but because the EDID file appears to have been completely been erased from the projector i cant even extract and repair it. Please help me out and send me the INF file which i have been trying to get a hold of for the past couple of weeks!
Thanks in advance!
If you could attach it here or PM me would be great!
PS: i don't need/want any modded files just the original!
Andremain is offline
post #3998 of 4009 Old 06-12-2014, 03:36 AM - Thread Starter
AVS Club Gold
Tulli's Avatar
Quoted: 16 Post(s)
Liked: 80
I only have the EDID of the Optoma HD66. Not sure that it works for the 67.
Tulli is offline
post #3999 of 4009 Old 06-14-2014, 09:19 PM
rollcage7's Avatar
Tulli,
Mind mind language ...BUT you are the ONE HELL f,,,,, GOD Dam GENIUSSSS!!!!!!!!!!!!!!!!!!!!!!!
THANKS A LOTTTTTTTTTT FOR YOU HELP
Actually it worked.... while i forget to make setting in players "NO Encoding"....
I am now getting lossless bit streaming directly to my PDVD & TM and Displayed in My ONKYO AVR
Thanks Again
post #4000 of 4009 Old 06-17-2014, 04:45 PM
Liked: 0
Realtime Info for Sony TV & Integra DTC9-8
Hi Tulli,
I am new to the forum and apologize as I accidentally did not include all the files needed earlier today. I have resolved that with the attachment below which includes 4 files:
RealTime Monoinf information as follows:
**Integra DTC-9.8.bin
**Integra DTC-9.8.inf
**Sony KDS-R70XBR2.bin
**Sony KDS-R709XBR2.inf
I respectfully request a custom inf. that will enable my setup (itemized below) to send uncompressed DTS-MA and Dolby True HD over HDMI 1.3a to my Processor. Since I just installed this new HD Radeon Card, I can not even get windows sound output properties to show DTS-MA or True HD as a supported format. Thus PowerDVD 9 doesn't offer the "non-decoded high definition option under HDMI audio" any longer. My main goal is viewing blu-ray 1080p with uncompressed DTS-MA to the Integra (3D is not a priority)
Vista 32bit (upgrading soon to win 7)
MSI Radeon HD6450
Integra DTC-9.8 (A division of Onkyo)
Sony KDS-R70XBR2 (used as a monitor only)
Sound out to Rotel Amp then 7 speakers plus subwoofer
PowerDVD 9 (I can purchase a different version if necessary)
Thank you so much for the information you provided on identifying and solving this problem.
problemsolver is offline
post #4001 of 4009 Old 06-17-2014, 05:01 PM - Thread Starter
AVS Club Gold
Tulli's Avatar
Quoted: 16 Post(s)
Liked: 80
I already posted the mod in the other thread:
EDID Override Thread
Tulli is offline
post #4002 of 4009 Old 06-17-2014, 06:57 PM
Liked: 0
Integra DTC9.8 with Sony KDS-R70XBR2
Thanks Tulli. Unfortunately, I still don't show DTS-MA or Dolby True HD as a supported output format under the AMD Hi Definition sound properties. It still only shows three supported formats (DTS audio, Dolby Digital, and MS WMA Pro Audio). I do appreciate your response and wish I had better news. PowerDVD does not show the third dropdown option "non-decoded sound from hi definition device" necessary for 7.1 uncompressed sound. Best Regards.
post #4003 of 4009 Old 06-18-2014, 03:01 AM - Thread Starter
AVS Club Gold
Tulli's Avatar
Quoted: 16 Post(s)
Liked: 80
If it worked before maybe the HDMI cable is the problem. Try also a clean install of the graphic driver. Double-check the installation of the EDID override (see 1st. post).
Tulli is offline
post #4004 of 4009 Old 06-18-2014, 08:53 AM
kaitokid's Avatar
Unhappy DELL 2407 (1920x1200) + Onkyo HT-R391 + ATI R9 280X
I am having the problem for a long time: can't bitstream DTS HD and Dolby True HD, from using 7750 to R9 280X. I've tried to update the display driver (change to 0x0F) and no use. The property of the HDMI audio device shows all formats are supported:
I've attached the driver I use for the display.. can anyone help? Thanks!
kaitokid is offline
post #4005 of 4009 Old 06-18-2014, 11:56 AM - Thread Starter
AVS Club Gold
Tulli's Avatar
Quoted: 16 Post(s)
Liked: 80
Native resolution must be HDTV (1080p/i or 720p) to bitstream HD audio. Set the Dell to 1920x1080 + the 0x0F hack. Or use separate connections with the AVR in extended mode + the 0x0F hack on the AVR monitor driver.
kaitokid likes this.
Tulli is offline
post #4006 of 4009 Old 06-18-2014, 01:45 PM
vladd's Avatar
Liked: 35
Heads up, my EDID editor and GetEDID links is down (server move). I will have it back up in the next week or so. Tulli, you are welcome to attach a copy to the first post if you prefer.
vladd is offline
post #4007 of 4009 Old 06-18-2014, 02:20 PM - Thread Starter
AVS Club Gold
Tulli's Avatar
Quoted: 16 Post(s)
Liked: 80
Sure, vladd.
Tulli is offline
post #4008 of 4009 Old 06-19-2014, 01:55 AM
kaitokid's Avatar
Thank you! Now I know the problem...
kaitokid is offline
post #4009 of 4009 Old 07-13-2014, 12:26 PM
Liked: 0
Win 8 with sony kdl 32ex340
Hello i'm having a similar problem with my pc, i have a home theater connected to my tv with a optical cable, when i use my ps3 trough my tv it transmits 5.1 channel sound, but when i connect my pc with windows 8.1 and a nvidia 650m, trough my tv it only says 2 channes, i have change the edid file using moninfo, created a .inf and installed it as a new driver, but after that i check moninfo and the real time edid does not change.
This is the original real time edid
Monitor
Model name............... SONY TV
Manufacturer............. Sony
Plug and Play ID......... SNY8102
Serial number............ n/a
Manufacture date......... 2012, ISO week 1
Filter driver............ None
EDID revision............ 1.3
Input signal type........ Digital
Color bit depth.......... Undefined
Display type............. RGB color
Screen size.............. 1600 x 900 mm (72,3 in)
Power management......... Not supported
Extension blocs.......... 1 (CEA-EXT)
DDC/CI................... Not supported
Color characteristics
Default color space...... Non-sRGB
Display gamma............ 2,20
Red chromaticity......... Rx 0,635 - Ry 0,336
Green chromaticity....... Gx 0,285 - Gy 0,608
Blue chromaticity........ Bx 0,146 - By 0,061
White point (default).... Wx 0,280 - Wy 0,290
Additional descriptors... None
Timing characteristics
Horizontal scan range.... 15-68kHz
Vertical scan range...... 58-62Hz
Video bandwidth.......... 150MHz
CVT standard............. Not supported
GTF standard............. Not supported
Preferred timing......... Yes
Native/preferred timing.. 1360x768p at 60Hz (16:9)
Modeline............... "1360x768" 85,500 1360 1424 1536 1792 768 771 777 795 +hsync +vsync
Detailed timing #1 ....... 1280x720p at 60Hz (16:9)
Modeline............... "1280x720" 74,250 1280 1390 1430 1650 720 725 730 750 +hsync +vsync
Standard timings supported
640 x 480p at 60Hz - IBM VGA
800 x 600p at 60Hz - VESA
1024 x 768p at 60Hz - VESA
EIA/CEA-861 Information
Revision number.......... 3
IT underscan............. Supported
Basic audio.............. Supported
YCbCr 4:4:4.............. Supported
YCbCr 4:2:2.............. Supported
Native formats........... 0
Detailed timing #1 ....... 1920x1080i at 60Hz (16:9)
Modeline............... "1920x1080" 74,250 1920 2008 2052 2200 1080 1084 1094 1124 interlace +hsync +vsync
Detailed timing #2 ....... 1920x1080p at 60Hz (16:9)
Modeline............... "1920x1080" 148,500 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync
Detailed timing #3 ....... 720x480p at 60Hz (16:9)
Modeline............... "720x480" 27,000 720 736 798 858 480 489 495 525 -hsync -vsync
Detailed timing #4 ....... 720x480p at 60Hz (4:3)
Detailed timing #5 ....... 1440x480i at 60Hz (4:3)
Modeline............... "1440x480" 27,000 1440 1478 1602 1716 480 488 494 524 interlace -hsync -vsync
CE video identifiers (VICs) - timing/formats supported
1920 x 1080p at 60Hz - HDTV (16:9, 1:1)
1280 x 720p at 60Hz - HDTV (16:9, 1:1)
1920 x 1080i at 60Hz - HDTV (16:9, 1:1)
720 x 480p at 60Hz - EDTV (16:9, 32:27)
720 x 480p at 60Hz - EDTV (4:3, 8:9)
720 x 480i at 60Hz - Doublescan (16:9, 32:27)
720 x 480i at 60Hz - Doublescan (4:3, 8:9)
1920 x 1080p at 24Hz - HDTV (16:9, 1:1)
640 x 480p at 60Hz - Default (4:3, 1:1)
NB: NTSC refresh rate = (Hz*1000)/1001
CE audio data (formats supported)
LPCM 2-channel, 16/20/24 bit depths at 32/44/48 kHz
AC-3 6-channel, 640k max. bit rate at 32/44/48 kHz
CE speaker allocation data
Channel configuration.... 2.0
Front left/right......... Yes
Front LFE................ No
Front center............. No
Rear left/right.......... No
Rear center.............. No
Front left/right center.. No
Rear left/right center... No
Rear LFE................. No
CE vendor specific data (VSDB)
IEEE registration number. 0x000C03
CEC physical address..... 2.0.0.0
Supports AI (ACP, ISRC).. Yes
Supports 48bpp........... No
Supports 36bpp........... No
Supports 30bpp........... No
Supports YCbCr 4:4:4..... No
Supports dual-link DVI... No
Maximum TMDS clock....... 150MHz
Audio/video latency (p).. n/a
Audio/video latency (i).. n/a
HDMI video capabilities.. No
Data payload............. 030C002000801E0F
CE video capability data
CE scan behavior......... Supports overscan and underscan
IT scan behavior......... Always underscanned
PT scan behavior......... Supports overscan and underscan
RGB quantization range... Selectable (via AVI YQ)
YCC quantization range... Not supported
Report information
Date generated........... 13/07/2014
Software revision........ 2.90.0.1000
Data source.............. Real-time 0x0091
Operating system......... 6.2.9200.2
Raw data
00,FF,FF,FF,FF,FF,FF,00,4D,D9,02,81,01,01,01,01,01 ,16,01,03,80,A0,5A,78,0A,83,AD,A2,56,49,9B,25,
0F,47,4A,21,08,00,01,01,01,01,01,01,01,01,01,01,01 ,01,01,01,01,01,66,21,50,B0,51,00,1B,30,40,70,
36,00,40,84,63,00,00,1E,01,1D,00,72,51,D0,1E,20,6E ,28,55,00,40,84,63,00,00,1E,00,00,00,FD,00,3A,
3E,0F,44,0F,00,0A,20,20,20,20,20,20,00,00,00,FC,00 ,53,4F,4E,59,20,54,56,0A,20,20,20,20,20,01,70,
02,03,25,F0,49,10,04,05,03,02,07,06,20,01,26,09,07 ,07,15,07,50,83,01,00,00,68,03,0C,00,20,00,80,
1E,0F,E2,00,7B,01,1D,80,18,71,1C,16,20,58,2C,25,00 ,40,84,63,00,00,9E,02,3A,80,18,71,38,2D,40,58,
2C,45,00,40,84,63,00,00,1E,8C,0A,D0,8A,20,E0,2D,10 ,10,3E,96,00,40,84,63,00,00,18,8C,0A,D0,8A,20,
E0,2D,10,10,3E,96,00,B0,84,43,00,00,18,8C,0A,A0,14 ,51,F0,16,00,26,7C,43,00,B0,84,43,00,00,98,1F
This is the one i created
Monitor
DDC/CI................... n/a
Detailed timing #1 ....... 1920x1080i at 27Hz (16:9)
Modeline............... "1920x1080" 33,290 1920 2008 2052 2200 1080 1084 1094 1124 interlace +hsync +vsync
Modeline............... "1440x480" 27,000 1440 1478 1602 1716 480 488 494 524 interlace +hsync +vsync
LPCM 6-channel, 16/20/24 bit depths at 32/44/48 kHz
Channel configuration.... 5.1
Front LFE................ Yes
Front center............. Yes
Rear left/right.......... Yes
Report information
Data source.............. File
Raw data
02,03,25,F0,49,10,04,05,03,02,07,06,20,01,26,0D,07 ,07,15,07,50,83,0F,00,00,68,03,0C,00,20,00,80,
1E,0F,E2,00,7B,01,0D,80,18,71,1C,16,20,58,2C,25,00 ,40,84,63,00,00,9E,02,3A,80,18,71,38,2D,40,58,
E0,2D,10,10,3E,96,00,B0,84,43,00,00,18,8C,0A,A0,14 ,51,F0,16,00,26,7C,43,00,B0,84,43,00,00,96,1F
Even after i install the driver, the real time edid does not change
camilogt is offline
Reply Home Theater Computers
User Tag List
