EDID Overrides to solve bitstreaming issues for ATI 5xxx's - Page 135 - AVS Forum | Home Theater Discussions And Reviews
 11Likes
Old 08-14-2014, 02:13 PM
Liked: 0
Does it actually make a difference (in quality) wether the DTS-signal is decoded by my AVR or by my Computer?
funky-munky is offline
Old 08-14-2014, 04:17 PM - Thread Starter
Tulli's Avatar
Quoted: 117 Post(s)
Liked: 102
No difference.
EDID Overrides (capture, install/uninstall, troubleshooting)
Tulli is offline
Old 08-17-2014, 10:54 PM
Liked: 0
Hi Tulli,
I'm glad I found this thread! I'm also having trouble with my receiver playing DTS HD MA.
My setup is as follows:
Panasonic TC-P50G10 HDTV
Onkyo HT-R380 receiver
AMD Radeon HD 6770 (with latest update)
I ran MonInfo and I created the INF files from there for my TV and receiver. Also, the INF files said "Registry" in their Display ID's in MonInfo. I hope these are the ones you need. I appreciate any help you could provide me with. Thank you.
TMODdev is offline
Old 08-18-2014, 08:58 AM - Thread Starter
Tulli's Avatar
Quoted: 117 Post(s)
Liked: 102
The captures only included the basic block (128-bytes). Use the attached mod:
Panasonic-TC-P50G15 - Onkyo HT-R380.zip
TMODdev likes this.
Tulli is offline
Old 08-18-2014, 11:48 AM
Liked: 0
Thank you Tulli! It's finally working! Much appreciated.
TMODdev is offline
Old 08-22-2014, 10:21 AM
Liked: 0
Hi guys, new there!
With my ATI card I can't get multichannel support and all audio codecs, just stereo and Dolby Digital. I try different AMD drivers, no differences. See picture:
I tried to undesrtand if I have the EDID problem, so I create my .inf file. Here's the step I did:
1) connected HDMI directly to my LG 42LV340A and created .inf with moninfo
2) connected HDMI to receiver Denon X4000 and created .inf with moninfo
3) opened the denon .inf and pasted the string from lg .inf after HKR,EDID_OVERRIDE,"0",
4) saved, installed and rebooted
no differences at all!
i did something wrong?
thanks!
Pissa is offline
Old 08-22-2014, 11:24 AM - Thread Starter
Tulli's Avatar
Quoted: 117 Post(s)
Liked: 102
Just read my previous exchange with TMODdev as it applies to your case. According to your CAP the problem should be in the AVR. Set the HDMI to not replicate the TV audio specs (in older DENONs it needs to be set to "AMP"). Otherwise make sure to use an AMD provided driver (not Microsoft).
Tulli is offline
Old 08-22-2014, 01:11 PM
Liked: 0
You mean that my .inf has only the basic block?
How do I get the full one?
Can't remeber that option, I'm going to check and report to you.
Yes I use ONLY AMD drivers!
Pissa is offline
Old 08-22-2014, 01:15 PM - Thread Starter
Tulli's Avatar
Quoted: 117 Post(s)
Liked: 102
Sorry, I meant my exchange with @funky-munky .
Tulli is offline
Old 08-22-2014, 01:45 PM
Liked: 0
in HDMI configuration I have:
- auto lip sync: ON
- HDMI audio out: AVR
- video output: monitor 1
- pass through HDMI: OFF
- HDMI control: OFF
not selectable because HDMI control is OFF:
- pass through souce: -
- power off control: -
I confirm drivers are by AMD and not by Microsoft.
I think the setting you ask me to check is HDMI audio out, I can choose AVR or TV but unfortunately it's already selected on AVR.
Pissa is offline
Old 08-22-2014, 02:27 PM
Liked: 0
the really strange fact is that if I install realtek ati hdmi drivers (that I don't want to use because they are incompatible with wasapi) I get this situation:
really don't understand what could be the problem....
Pissa is offline
Old 08-22-2014, 03:58 PM - Thread Starter
Tulli's Avatar
Quoted: 117 Post(s)
Liked: 102
What is your setup? (OS and specific AMD graphic card)?
Tulli is offline
Old 08-23-2014, 02:40 AM
Liked: 0
Asrock 939A790GMH with AMD HD3300 IGP graphic card -> http://www.asrock.com/mb/AMD/939A790GMH/
Windows 8.1 x86
Pissa is offline
Old 08-23-2014, 05:13 AM - Thread Starter
Tulli's Avatar
Quoted: 117 Post(s)
Liked: 102
The Radeon HD3000 series has limited bandwidth to compressed 5.1 and 2 channels uncompressed audio:
http://www.guru3d.com/articles-pages...-review,3.html
Tulli is offline
Old 08-23-2014, 05:33 AM
Liked: 0
and so?
also don't understand why with ATI drivers I have these settings, and with Realtek ones those settings....
Pissa is offline
Old 08-23-2014, 06:18 AM - Thread Starter
Tulli's Avatar
Quoted: 117 Post(s)
Liked: 102
The IGP has S/PDIF bandwidth limitation. That's it: only stereo uncompressed or 5.1 compressed audio (perhaps only AC3, per ATI driver detection).
Tulli is offline
Old 08-23-2014, 06:49 AM
Liked: 0
so edid override has nothing to do with my system, right?!
I'm using xbmc and powerdvd 14,they can manage wasapi exclusive mode, if I use them in that way it's ok?
Pissa is offline
Old 08-23-2014, 07:25 AM - Thread Starter
Tulli's Avatar
Quoted: 117 Post(s)
Liked: 102
Correct. You can get lossless 2-PCM (e. g. for music). For multichannel set PDVD to passthrough the audio stream (non-decode mode).
Tulli is offline
Old 08-23-2014, 07:52 AM
Liked: 0
many thanks mate!
Pissa is offline
Old 10-03-2014, 08:54 AM
Liked: 0
Hello Tulli
First of all I will like to thank you for all the work you are doing to help people here. I have been reading this long thread for a few days now and trying to learn as I am very new to all this. My current set up is very similar to lots of other people who have mentioned in the forum. Currently I have my HTPC connected to my Sony TV using the HDMI cable and my TV is connected to Yamaha AVR using the Optical Toslink cable.
HTPC (Using HDMI) ------ Sony TV KDL46V3000 (Using Optical Out) ------ Yamaha RXV 550 AVR
I am using Gefore 210 video card in my HTPC and have the latest NVIDIA drivers installed. I have also removed any previously installed drivers and disabled any other existing audio drivers. I am using Windows 7 and when I configure NVIDIA HD sound I only see the Stereo option, which means like I will need the EDID override for all the other options to show up. I want to use my Sony Tv as a passthrough while using XBMC so that content I play in XBMC which is configured as 5.1 I can get the 5.1 surround sound.
I can create my TV display INF using the MonInfo but I don't know how to create my AVR INF which is Yamaha RXV550. I will be thankful to you if you could create or help me create the required INF so that I can solve the surround sound audio issue.
Thanks again.
Palvish is offline
Old 10-09-2014, 10:53 AM
ontherocks's Avatar
I uninstalled the edid override. Then tried to install it again. This time it won't install the override. Getting error telling me that driver is not digitally signed as shown in the image below.
ontherocks is offline
Old 10-09-2014, 11:18 AM - Thread Starter
Tulli's Avatar
Quoted: 117 Post(s)
Liked: 102
Check this post.
Tulli is offline
Old 10-09-2014, 11:33 AM
ontherocks's Avatar
Check this post.
I have Windows 7 64bit. The Windows Security pop up appears and I select "Install this driver software anyway". This was exactly how it was during the first time I had installed the override.
Old 10-12-2014, 04:48 PM
Liked: 0
Hi all
i came here from another (XBMC) forum, when i was trying to solve audio streaming problems from my XBMC, to play correct DTS and DTS HD audio streams, because now it didnt recognize them.
my AVR is ONKYO HT-R548
my TV is LG 50PK-550
i found my amplifier in first post (with * marked) but i did not find my TV.
i also found a file with LG PK-350 which is similar TV to mine, (but lower model), but with different AVR than mine.
is it possible to merge these two files, to get my own correct file?
if not, is it possible for you Tulli to make one right for me?
thanks in advance
sorry for my bad english..
DarK_HumOuR is offline
Old 10-12-2014, 05:12 PM - Thread Starter
Tulli's Avatar
Quoted: 117 Post(s)
Liked: 102
The LG PK-350 - ONKYO HT-R380 mod on first post should work with your TV and AVR.
Tulli is offline
Old 10-12-2014, 05:19 PM
Liked: 0
thank you very much Tulli!!
Old 10-20-2014, 11:57 AM
TOMillr's Avatar
Any news for people using an Intel HD gpu?
TOMillr is offline
Old 11-02-2014, 01:01 AM
xstefanx42's Avatar
I had asked for a custom override a few years ago now and it work great. I'm now working to try and get my Xbox One pass through set up to take XBMC 5.1 and I'm running into the same issue as before. I can't figure out why the computer thinks it can only take stereo because it's set to take surround, but oh well. I'm providing the inf I pulled with moninfo and the custom inf you provided me with before. I believe you said audio should be the same for all overrides, but thought I'd throw it in just in case.
Code:
; INF file generated by Monitor Asset Manager (2.90.0.1000), 11/2/2014
; Copyright (c) 1995-2014, EnTech Taiwan.
; Internet: REMOVED TO POST
[Version]
Signature="$WINDOWS NT$"
Class=Monitor
ClassGUID={4d36e96e-e325-11ce-bfc1-08002be10318}
Provider=%MFG%
DriverVer=11/2/2014, 1.0.0.0
;CatalogFile=YourSignedCatalogFile.cat
[DestinationDirs]
DefaultDestDir=23
[SourceDisksNames]
1=%DISC%
[SourceDisksFiles]
;YourColorProfileFile.icm
[Manufacturer]
%VENDOR%=EDID_OVERRIDE,NTx86,NTamd64
[EDID_OVERRIDE.NTx86]
%PRODUCTID%=OVERRIDDEN-EDID.Install, MONITOR\MSH0001
[EDID_OVERRIDE.NTamd64]
%PRODUCTID%=OVERRIDDEN-EDID.Install.NTamd64, MONITOR\MSH0001
[OVERRIDDEN-EDID.Install.NTx86]
DelReg=DEL_CURRENT_REG
AddReg=OVERRIDDEN-EDID.AddReg, MODE1, DPMS
CopyFiles=OVERRIDDEN-EDID.CopyFiles
[OVERRIDDEN-EDID.Install.NTamd64]
[OVERRIDDEN-EDID.Install.NTx86.HW]
AddReg=OVERRIDDEN-EDID_AddReg
[OVERRIDDEN-EDID.Install.NTamd64.HW]
[OVERRIDDEN-EDID_AddReg]
;Base EDID
HKR,EDID_OVERRIDE,"0",0x01,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x00,0x36,0x68,0x01,0x00,0x00,0x00,0x00,0x00,0x1E,0x17,0x01,0x03,0x80,0x00,0x00,0x8C,0x0E,0xEE,0x91,0xA3,0x54,0x4C,0x99,0x26,0x0F,0x50,0x54,0x20,0x00,0x00,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x02,0x3A,0x80,0x18,0x71,0x38,0x2D,0x40,0x58,0x2C,0x45,0x00,0x00,0x00,0x00,0x00,0x00,0x1E,0x00,0x00,0x00,0xFD,0x00,0x17,0x3C,0x1A,0x46,0x0F,0x00,0x0A,0x20,0x20,0x20,0x20,0x20,0x20,0x00,0x00,0x00,0xFC,0x00,0x58,0x62,0x6F,0x78,0x20,0x4F,0x6E,0x65,0x0A,0x20,0x20,0x20,0x20,0x00,0x00,0x00,0x10,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0xDC
;Extension bloc #1, e.g., CEA-EXT, DID-EXT, etc.
HKR,EDID_OVERRIDE,"1",0x01,0x02,0x03,0x2B,0x40,0x4E,0x10,0x01,0x04,0x20,0x22,0x21,0x1F,0x13,0x03,0x02,0x12,0x11,0x05,0x14,0x26,0x09,0x07,0x07,0x15,0x07,0x50,0x83,0x0F,0x00,0x00,0x6C,0x03,0x0C,0x00,0xFF,0xFF,0x00,0x1E,0xC0,0x1A,0x1A,0x24,0x24,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x49
[DEL_CURRENT_REG]
HKR,MODES
HKR,EDID_OVERRIDE
HKR,,MaxResolution
HKR,,PreferredMode
HKR,,DPMS
HKR,,ICMProfile
[DPMS]
HKR,,DPMS,,0
HKR,,PreferredMode,,"1920,1080,60"
[MODE1]
HKR,,MaxResolution,,"1920,1080,60"
[OVERRIDDEN-EDID.AddReg]
HKR,"MODES\1920,1080,60",Mode1,,"26.0-70.0,23.0-60.0,+,+"
[OVERRIDDEN-EDID.CopyFiles]
;YourColorProfileFile.icm for non-sRGB displays
[Strings]
MFG="EnTech Taiwan"
DISC="Monitor EDID Override Installation Disk"
PRODUCTID="MSH Xbox One (MSH0001 EDID Override)"
VENDOR="MSH"
Code:
; INF file generated by Monitor Asset Manager, 3/21/2010
; Copyright (c) EnTech Taiwan, 1995-2009.
[Version]
Class=Monitor
Provider=%MFG%
DriverVer=3/21/2010, 1.0.0.0
[DestinationDirs]
DefaultDestDir=23
[SourceDisksNames]
1=%DISC%
[SourceDisksFiles]
[Manufacturer]
%PRODUCTID%=OVERRIDDEN-EDID.Install, MONITOR\SNY0B01
%PRODUCTID%=OVERRIDDEN-EDID.Install.NTamd64, MONITOR\SNY0B01
;Base EDID
HKR,EDID_OVERRIDE,"0",0x01,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x00,0x4D,0xD9,0x01,0x0B,0x01,0x01,0x01,0x01,0x1C,0x11,0x01,0x03,0x80,0x10,0x09,0x78,0x0A,0xEE,0x91,0xA3,0x54,0x4C,0x99,0x26,0x0F,0x50,0x54,0x20,0x00,0x00,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x1D,0x80,0x18,0x71,0x1C,0x16,0x20,0x58,0x2C,0x25,0x00,0xA0,0x5A,0x00,0x00,0x00,0x9E,0x01,0x1D,0x00,0x72,0x51,0xD0,0x1E,0x20,0x6E,0x28,0x55,0x00,0xA0,0x5A,0x00,0x00,0x00,0x1E,0x00,0x00,0x00,0xFD,0x00,0x17,0x3D,0x19,0x44,0x10,0x00,0x0A,0x20,0x20,0x20,0x20,0x20,0x20,0x00,0x00,0x00,0xFC,0x00,0x53,0x4F,0x4E,0x59,0x20,0x41,0x56,0x41,0x4D,0x50,0x0A,0x20,0x20,0x01,0xC7
HKR,EDID_OVERRIDE,"1",0x01,0x02,0x03,0x3E,0x74,0x45,0x85,0x04,0x03,0x10,0x20,0x32,0x61,0x7E,0x00,0x65,0x7E,0x00,0x67,0x7E,0x00,0x59,0x7E,0x01,0x5D,0x7E,0x01,0x5F,0x7E,0x01,0x35,0x09,0x7F,0x07,0x0D,0x7F,0x07,0x0F,0x7F,0x07,0x15,0x07,0x55,0x3D,0x1F,0xC0,0x57,0x06,0x00,0x4D,0x02,0x00,0x83,0x5F,0x00,0x00,0x66,0x03,0x0C,0x00,0x12,0x00,0x80,0x8C,0x0A,0xD0,0x8A,0x20,0xE0,0x2D,0x10,0x10,0x3E,0x96,0x00,0xA0,0x5A,0x00,0x00,0x00,0x18,0x02,0x3A,0x80,0x18,0x71,0x38,0x2D,0x40,0x58,0x2C,0x45,0x00,0xA0,0x5A,0x00,0x00,0x00,0x1E,0x01,0x1D,0x80,0x3E,0x73,0x38,0x2D,0x40,0x7E,0x2C,0x45,0x80,0xA0,0x5A,0x00,0x00,0x00,0x1E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x66
[DEL_CURRENT_REG]
HKR,MODES
HKR,EDID_OVERRIDE
HKR,,MaxResolution
HKR,,DPMS
HKR,,ICMProfile
[DPMS]
HKR,,DPMS,,0
[MODE1]
HKR,,MaxResolution,,"1920,1080"
HKR,"MODES\1920,1080",Mode1,,"25.0-68.0,23.0-61.0,+,+"
[Strings]
MFG="EnTech Taiwan"
PRODUCTID="SONY AVAMP (EDID Override)"
VENDOR="Sony"
xstefanx42 is offline
Old 11-02-2014, 04:18 AM - Thread Starter
Tulli's Avatar
Quoted: 117 Post(s)
Liked: 102
The audio bandwidth of the Xbox One per the posted EDID is limited to 2 channels of uncompressed audio (LPCM) and 6 channels of compressed audio (AC3). So it can pass multichannel audio only in AC3 format.
Tulli is offline
Old 11-02-2014, 11:09 AM
xstefanx42's Avatar
If I understand correctly that should mean the Dolby Digital should work. I've change the settings in xbmx to match that and when I turn on Dolby Digital (AC3) capable receiver it works, but only in stereo still. When I also turn on Enable Dolby Digital transcoding I lose audio all together.
When I check the properties of my audio device in windows it says that no compressed formats are found. I'm sure there is something very simple that I am missing. I know I don't know this stuff well.
Edit:
Thought I'd add some clarification as I'm not really trying to look for help with xbmc specifically and that's how it sounded.
The Xbox itself is outputting via bitstream compressed Dolby Digital 5.1 to the TV which passes the signal to the receiver via Optical (Dolby Digital in the settings as well). It's audio is working as expected in 5.1 for everything except the TV option, which is coming via the PC HDMI pass through.
Is there a way I can test the 5.1 compression within window easily to rule out (or in) an XBMC problem?
